PART NUMBER
ITEM
Q'TY
1
1
3XX-F
T-1 (3mm) Flanged LED, See Page 2
2
1
ELM 7-XXX
Extruded, Self-Retaining LED Spacer
REV.
PART DESCRIPTION
B
C
D
E
F
G
H
1
SHORT LEAD
Flat Edge
Cathode ID
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
M. C.
M. C.
M. C.
T. Y.
T. Y.
T. Y.
J. C.
0.100 [2.5mm]
0.100 [2.5mm]
0.120 [3.0mm]
Spacer Dia.
0.020 [0.5mm] SQ.
Recommended Mounting Holes
MIN.
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
APPROVED
Ø.032+.003
TYP.-.002
L
Ø.150 [Ø3.8mm]
Flange Dia.
LED Dia.
DATE
04/05/06
08/22/06
09/03/08
06/07/11
11/21/11
09/24/13
05/25/16
2
0.207 [5.3mm]
Ø.118 [Ø3.0mm]
DESCRIPTION
Changed "L" Dimemsion
Update LED, EMN-ELMXXXX3XX
Removed Tolerance Note.
Added Tape & Reel Options.
Tape & Reel Design Update.
Corrected P/N Typo in BOM.
Engineering Update w/o Changes
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
STORAGE TEMPERATURE
DESIGNED:
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
CHECKED:
± .1
± .02
± .010
D. Green
T. Yin
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
EXTRUDED VERTICAL T-1 (3mm)
LED STANDARD PROFILE SPACER ASSY
DATE:
12/23/04
DATE:
12/23/04
PART NO:
REVISION:
ELM7XXX3XX
CAGE CODE : 32559
H
SHEET # 1 OF 3
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1.
LED Assy. No.
STANDARD
ELM7XXX3BWD
ELM7XXX3GD
ELM7XXX3YD
ELM7XXX3HD
ELM7XXX3RD
ELM7XXX3SRD
LOW CURRENT
ELM7XXX3GDL
ELM7XXX3YDL
ELM7XXX3HDL
5 VOLT
ELM7XXX3GD5V
ELM7XXX3YD5V
ELM7XXX3HD5V
Electro-Optical Data
Peak Wave
Length
λ p(nm )
Em itted Color
Lens
Appearance
430
565
585
635
655
660
BLUE
GREEN
YELLOW
HE RED
RED
SUPER RED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
View ing
Angle
Vf
2 ½
If
Iv
(V)
(m A)
(m cd) (Deg)
TYP
TYP MAX TYP
Data @ 20m A
4.5
20.0
45
2.6
30.0
45
2.6
20.0
45
2.6
30.0
45
2.0
6.0
45
2.6
90.0
45
Data @ 2m A
5
1.9
2.2
6.0
45
5
1.9
2.2
4.0
45
5
1.8
2.2
6.0
45
Data @ 5V
8
5.0
30.0
45
8
5.0
20.0
45
8
5.0
30.0
45
LED P/N
3BWD-F
3GD-F
3YD-F
3HD-F
3RD-F
3SRD-F
3GDL-F
3YDL-F
3HDL-F
3GD5V-F
3YD5V-F
3HD5V-F
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
D. Green
CHECKED:
T. Yin
DATE:
12/23/04
DATE:
12/23/04
PART NO:
REVISION:
ELM7XXX3XX
CAGE CODE : 32559
H
SHEET # 2 OF 3
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
0.250 [6.4mm]
TYP.
0.500 [12.7mm]
TYP.
0.709 [18.0mm]
CARBOARD REEL
(.020" THICK)
0.650 + XXX*
XXX* = ELM SPACER HEIGHT
0.650 [16.5mm]
0.511 [13.0mm]
MASKING TAPE
Ø.158 [Ø4.0mm]
TYP.
0.100 [2.5mm]
TYP.
0.500 [12.7mm]
TYP.
LONG LEAD
ANODE
TYP.
0.058 [1.5mm]
MAX.
DIRECTION OF FEED
LABEL
16.5 [420mm] REF.
14" X 2" REEL
13.5 [345mm] REF.
2.5 [63.5mm] REF.
STANDARD PACKAGING TRAY
TAPE & REEL
1,000 pcs / reel
AMMO PACK
2,000 pcs / box
STANDARD TOLERANCE
DECIMALS
NOTE:
1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS
2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL)
3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX)
4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
D. Green
CHECKED:
T. Yin
ANGULAR
X°
± 1°
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: EXTRUDED VERTICAL T-1 (3mm)
DATE:
12/23/04
DATE:
12/23/04
PART NO:
REVISION:
ELM7XXX3XX
CAGE CODE : 32559
H
SHEET # 3 OF 3
很抱歉,暂时无法提供与“ELM70303GD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.42952
- 10+3.94874
- 100+2.96156
- 国内价格
- 1+3.47760
- 200+1.39320
- 500+1.33920
- 1000+1.31760
