SPECIFICATION FOR APPROVAL
承
认
书
Description
蜂鸣器
Vender’s Part No.
cy-12085G-3016-P4
Cstomer name
常州超音电子有限公司
Supplier name
1.1
Version No.
CUSTOMER’S APPROVED SIGNATURE
ADD:江苏常州武进庙桥新联工业集中区 58 号
TEL: +86-519-88298758
FAX: +86-519-86464158
Http://www.smdbuzzer.net
Approved By
Checked By
Made By
Nong
2014/08/12
A. SCOPE
This specification applies magnetic buzzer, cy-12085G-3016-P4
B. SPECIFICATION
No.
Item
Unit
1
Oscillation Frequency
KHz
2.048
2
Operating Voltage
VO-P
2-5
3
Rated Voltage
VO-P
3.3
4
Current Consumption
mA
MAX. ≤35
at Rated Voltage
5
Sound Pressure Level
dB
MIN.85
at 10cm at Rated Voltage
Ω
16±4
6
Coil Resistance
Specification
Condition
7
Operating Temperature
-20~ +70
8
Storage Temperature
-30 ~ +80
9
Dimension
mm
Φ12* H8.5
10
Weight (MAX)
gram
1.2
11
Housing Material
PPO 高温( Black )
支持波峰焊 260 度
12
Leading Pin
Tin Plated Brass(Sn)
针长 4.0MM
13
Environmental
Protection Regulation
RoHS
See appearance drawing
C. APPEARANCE DRAWING
4
理员请求和您通话
(本系统由TQ 提供)
D.TESTING METHOD
Standard Measurement conditions
Temperature:25±2℃ Humidity:45-65%
In the measuring test, buzzer is placed as follows:
E. RELIABILITY TEST
NO.
ITEM
1
High Temperature
Test (Storage)
2
Low Temperature
Test (Storage)
3
Humidity Test
TEST CONDITION AND REQUIREMENT
After being placed in a chamber with 802ºC for 96 hours and then
being placed in normal condition for 2 hours.
Allowable variation of SPL after test: 10dB.
After being Placed in a chamber with -302ºC for 96 hours and then
After being Placed in a chamber with 90-95% R.H. at 402ºC for 96
hours and then being placed in normal condition for 2 hours.
The part shall be subjected to 5 cycles. One cycle shall be consist of:
+70ºC
+25ºC
4
Temperature Cycle
Test
5
Drop Test
6
Vibration Test
7
Solderability
Test
8
Terminal Strength
Pulling Test
+25ºC
- 20ºC
Drop on a hard wood board of 4cm thick, any directions ,6 times,
at the height of 75cm .
After being applied vibration of amplitude of 1.5mm with 10 to 55 Hz
band of vibration frequency to each of 3 perpendicular directions for
2 hours .
Lead terminals are immersed in rosin for 5 seconds and then
immersed in solder bath of +3005ºC for 31 seconds .
90% min. lead terminals shall be wet with solder
(Except the edge of terminals).
The force of 9.8N(1.0kg) is applied to each terminal in axial direction for
10 seconds.
No visible damage and cutting off.
TEST CONDITION.
Standard Test Condition
一般测试条件
Judgment Test Condition
争议时测试条件
a) Temperature : +5 ~ +35℃
a) 温度 : +5 ~ +35℃
a) Temperature : +25 ± 2℃
a) 温度 : +25 ± 2℃
b) Humidity : 45-85%
b) 湿度 : 45-85%
b) Humidity : 60-70%
b) 湿度 : 60-70%
c) Pressure : 860-1060mbar
c) 气压 : 860-1060mbar
F. PACKING STANDARD
10PCSx10=100PCS
Foam Tray
顶层加一块上盖
Plastic Bag
(10PCS Foam Tray)
Carton Box
(5PCS Plastic Bag)
Foam Tray
240mmx160mmx30mm
10x100PCS=1000PCS
Plastic Bag
Carton Box
1x100PCS=100PCS
520mmx420mmx280mm
5x1000PCS=5,000PCS
很抱歉,暂时无法提供与“CY-12085G-3016-P4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.41740
- 50+1.11813
- 200+0.98172
- 500+0.82156
- 2000+0.75028
