APM32F103CBT6
APM32F103CBT6
    GEEHY(极海半导体)
    LQFP-48(7x7)
    32位MCU微控制器 ARM Cortex-M3 LQFP48_7X7MM
APM32F103CBT6 数据手册
  - - -   - 4 - - - / -   - ( - -  - RTC -   - -  -  - - -   - -  - 1 2 3 4 5 6 7 8 9 VDD_3 VSS_3 PE1 PE0 PB9 PB8 BOOT0 PB7 PB6 PB5 PB4 PB3 PD7 PD6 PD5 PD4 PD3 PD2 PD1 PD0 PC12 PC11 PC10 PA15 PA14 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 64 63 62 61 60 59 58 57 56 55 54 53 52 51 46 47 48 49 50 PE15 PB10 PB11 VSS_1 VDD_1 LQFP100 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 PA3 VSS_4 VDD_4 PA4 PA5 PA6 PA7 PC4 PC5 PB0 PB1 PB2 PE7 PE8 PE9 PE10 PE11 PE12 PE13 PE14 PE2 PE3 PE4 PE5 PE6 VBAT PC13-TAMPER-RTC PC14-OSC32_IN PC15-OSC32_OUT VSS_5 VDD_5 OSC_IN OSC_OUT NRST PC0 PC1 PC2 PC3 VSSA VREFVREF+ VDDA PA0-WKUP PA1 PA2 VDD_2 VSS_2 NC PA13 PA12 PA11 PA10 PA9 PA8 PC9 PC8 PC7 PC6 PD15 PD14 PD13 PD12 PD11 PD10 PD9 PD8 PB15 PB14 PB13 PB12 10 VDD_3 VSS_3 PB9 PB8 BOOT0 PB7 PB6 PB5 PB4 PB3 PD2 PC12 PC11 PC10 PA15 PA14 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 38 37 36 35 34 33 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 LQFP64 VDD_2 VSS_2 PA13 PA12 PA11 PA10 PA9 PA8 PC9 PC8 PC7 PC6 PB15 PB14 PB13 PB12 PA3 VSS_4 VDD_4 PA4 PA5 PA6 PA7 PC4 PC5 PB0 PB1 PB2 PB10 PB11 VSS_1 VDD_1 VBAT PC13-TAMPER-RTC PC14-OSC32_IN PC15-OSC32_OUT PD0 OSC_IN PD1 OSC_OUT NRST PC0 PC1 PC2 PC3 VSSA VDDA PA0-WKUP PA1 PA2 11 VDD_3 VSS_3 PB9 PB8 BOOT0 PB7 PB6 PB5 PB4 PB3 PA15 PA14 48 47 46 45 44 43 42 41 40 39 38 37 1 2 3 4 5 6 7 8 9 36 35 34 33 32 31 30 29 28 27 10 26 11 25 12 13 14 15 16 17 18 19 20 21 22 23 24 LQFP48 VDD_2 VSS_2 PA13 PA12 PA11 PA10 PA9 PA8 PB15 PB14 PB13 PB12 PA3 PA4 PA5 PA6 PA7 PB0 PB1 PB2 PB10 PB11 VSS_1 VDD_1 VBAT PC13-TAMPER-RTC PC14-OSC32_IN PC15-OSC32_OUT PD0 OSC_IN PD1 OSC_OUT NRST VSSA VDDA PA0-WKUP PA1 PA2 12 PA14 28 27 VDD_2 2 26 VSS_2 OCS_OUT/PD1 3 25 PA13 NRST 4 24 PA12 VSSA 5 23 PA11 VDDA 6 22 PA10 PA0-WKUP 7 21 PA9 PA1 8 20 PA8 PA2 9 10 12 13 14 15 16 17 19 18 VDD_1 11 QFN36 VSS_1 PA15 OCS_IN/PD0 29 PB2 PB4 30 PB1 PB4 31 PB0 PB5 32 PA7 PB6 33 PA6 PB7 34 PA5 BOOT0 35 PA4 VSS_3 36 1 PA3 VDD_3 13 14 15 16 17 18 19 Ibus Flash Cortex - M 3 CPU Dbus Fmax: 96 MHz NVIC System GP DMA 7 channels FPU CLK/SS_N/IO[3:0] as AF QSPI @ VDDA SUPPLY SUPERVISION NRST VDDA VSSA POR/PDR Rst PVD Int GPIOA PB[ 15:0] GPIOB PC[ 15:0] GPIOC PD[ 15:0] GPIOD PE[ 15:0] 4 Channels 3 compl . Channels ETR and BKIN MOSI/ MISO/ SCK / NSS as AF GPIOE TIM1 SPI1 USART1 @ VDDA 16AF V REF+ V REF- PCLK1 PCLK2 HCLK FCLK IF 12 bit ADC2 IF Vss @ VDD XTAL OSC 4-16MHz PLL&CLOCK MANAGT RC 8 MHz RC 40 KHz @ VDDA IWDG Stand by interface OSC_ IN OSC_ OUT V BAT @ VBAT AHB2 APB2 XTAL 32 KHz AHB2 APB1 Backup RTC reg AWU Backup interface OSC 32_ IN OSC 32_ OUT TAMPER- RTC TIM2 4 Channels TIM3 4 Channels TIM4 USART2 USART3 4 Channels RX /TX /CTS/RTS/CK/ SmartCard as AF RX /TX /CTS/RTS/CK/ SmartCard as AF I2C1/I2C3 MOSI /MISO/SCK / NSS as AF SCL /SDA / SMBA as AF I2C2/I2C4 SCL /SDA as AF SPI2 bxCAN 12 bit ADC1 V DD = 2 to 3.6v @ VDD SRAM 20 KB APB1:Fmax=24/48MHz PA[ 15:0] RX /TX /CTS/RTS/CK / SmartCard as AF Flash 128 KB 64 bit EXTI WAKEUP APB2:Fmax=48/96MHz 80 AF VOLT.REG. 3.3V TO 1.8V obI SW/ JTAG TM POWER Trace Controller pbus Interface Trace/ trig AHB:Fmax=48/96MHz NJTRST JTDI JTCK/SWCLK JTMS/ SWDIO JTDO as AF TPIU BusMatrix TRACECLK TRACED[0:3] as AS USB2. 0 FS ( USB2 ) 2.0 FS USBDP /CAN _ TX USBDM/ CAN _ RX SRAM 512B Temp sensor WWDG 20 FLITFCLK to flash programming interface 8 MHz HSI RC USB Prescaler 1/1.5/2 HSI 48 MHz FPU Prescaler 1/2 /2 PLLSRC USBCLK to USB interface PLLMUL HCLK to AHB bus , core, memory and DMA 96 MHz max SW Clock . . .,×16 ×2,×3,×4 PLL SYSCLK 96MHz max HSI PLLCLK HSE AHB Prescaler /1,2. .512 /8 to Cortex System timer Enable(3bits) FCLK Cortex Free running clock CSS APB1 Prescaler /1,2,4,8,16 PLLXTPRE OSC_ OUT OSC_IN OSC32_OUT OSC32_IN /2 LSE OSC 32.768KHz TIM 2,3,4 If( APB1 prescaler=1) ×1 else × 2 To RTC /128 LSE RTCCLK RTCSEL[1:0] to independent watchdog( IWDG) LSI /2 MCO PLLCLK HSI HSE SYSCLK to TIM2,3 and 4 TIMXCLK Peripheral Clock Enable (3bits) APB2 Prescaler /1,2,4,8,16 96 MHz max IWDGCLK Main Clock Output PCLK1 to APB1 Peripheral Clock peripherals Enable(13bits) 4-16MHz HSE OSC LSI RC 40KHz MCO 48 MHz max to APB2 Peripheral Clock peripherals Enable(11bits) TIM1 timer If( APB2 prescaler=1) ×1 else × 2 ADC Prescaler /2,4,6,8 PCLK2 to TIM 1 TIM 1CLK Peripheral Clock Enable(1bits) to ADC ADCCLK Legend : HSE= high-speed external clock signal HSI = high- speed internal clock signal LSE = low - speed external clock signal LSI = low - speed internal clock signal 21 APB memory space 0xFFFF FFFF 7 0xE010 0000 ARM® Cortex®-M3 Internal 0xE000 0000 Peripherals 6 0xC000 0000 5 0xA000 0000 0x1FFF FFFF 0x1FFF F80F 4 reserved Option Bytes 0x8000 0000 0x1FFF F800 System memory 3 0x1FFF F000 0x6000 0000 2 0x4000 0000 reserved Peripherals 1 0x2000 0000 SRAM 0x0801 FFFF Flash memory 0 0x0800 0000 Aliased to Flash or 0x0000 0000 0x0000 0000 Reserved system memory depending on BOOT pins 0xFFFF 0x4002 0x4002 0x4002 0x4002 0x4002 0x4002 0x4002 0x4002 0x4002 0x4002 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4001 0x4000 0x4000 0x4000 0x4000 0x4000 FFFF reserved 43FF FPU 4000 reserved 3400 CRC 3000 reserved 2400 Flash Interface 2000 reserved 1400 RCC 1000 reserved 0400 DMA 0000 reserved 3C00 USART1 3800 reserved 3400 SPI1 3000 TIM1 2C00 ADC2 2800 ADC1 2400 reserved 1C00 Port E 1800 Port D 1400 Port C 1000 Port B 0C00 Port A 0800 EXTI 0400 AFIO 0000 reserved 7400 PWR 7000 BKP 6C00 reserved 6800 bxCAN 6400 Shared 512 byte 0x4000 6000 USB/CAN SRAM USB/USB2 Registers 0x4000 5C00 I2C2/I2C4 0x4000 5800 I2C1/I2C3 0x4000 5400 reserved 0x4000 4C00 USART3 0x4000 4800 USART2 0x4000 4400 reserved 0x4000 3C00 SPI2 0x4000 3800 reserved 0x4000 3400 IWDG 0x4000 3000 WWDG 0x4000 2C00 RTC 0x4000 2800 reserved 0x4000 0C00 TIM4 0x4000 0800 TIM3 0x4000 0400 TIM2 0x4000 0000 22    11    23    24 25            26     27 28     29   30    31 32 APM32F103XXPIN C=50 PF A: APM32F103XXPIN VIN B: IDD_VBAT VBAT AFM32F103XXPIN IDD VDD Vref VDDA C: (IDD+Vref) 33 34 35 36      37 VBAT 供电开关 1.8-3.6V 输出 通用I/O端口 输入 后备电路 (32KHz振荡器,RTC 唤醒电路,后备寄存器) 电 IO 平 逻辑 转 电路 换 VDD VDD 1/2/3/4/5 5 × 100 nF + 1 × 4.7 µF 核心电路 CPU 数字电路 和存储器 调压器 VSS 1/2/3/4/5 VDD VDDA VREF 10 nF + 1 µF 10 nF + 1 µF VREF+ VREF- ADC 模拟电路 RC振荡器 PLL等 VSSA 38 39 40 41 42 43   44 45 46   47 90% 外部输出 负载是50pF 10% 50% 50% 90% 10% tr(IO)OUT tr(IO)OUT T 如果(tr+tf)小于等于(2/3)T,并且占空比是(45~55%) 当负载为50pf时,达到最大的频率 48 49 50 (𝟏) VDD 4.7KΩ I²C总线 VDD 4.7KΩ 100Ω { 100Ω SDA APM32F103XX SCL 重复的开始条件 开始条件 SDA tf(STA) tsu(STA) tr(SDA) th(STA) tsu(SDA) tw(SCKL) th(SDA) 停止条件 开始条件 tsu(STA;STO) SCL tw(SCKH) tf(SCK) tf(SCK) tsu(STO) 51 52 NSS输入 tSU(NSS) CPHA=0 CPOL=0 CPHA=0 CPOL=1 tc(SCK) th(NSS) th(SCKH) tW(SCKL) SCK输入 tV(SO) ta(SO) MISO输出 tr(SCK) tf(SCK) th(SO) 输出最高位 tdls(SO) 输出最低位 输出第6~1位 tSU(SI) MOSI输入 输入最低位 输入第6~1位 输入最高位 th(SI) 𝟏(𝟏) NSS输入 tc(SCK) tSU(NSS) CPHA=1 CPOL=0 CPHA=1 CPOL=1 SCK输入 MISO输出 th(NSS) tW(SCKH) tW(SCKL) tr(SCK) tf(SCK) tV(SO) ta(SO) 输出最高位 tdls(SO) th(SO) 输出第6~1位 输出最低位 th(SI) tSU(SI) 输入最高位 输入第6~1位 输入最低位 MOSI输入 53 (𝟏) 高电平 tc(SCK) NSS输入 CPHA=0 CPOL=0 CPHA=0 CPOL=1 SCK输入 CPHA=1 CPOL=0 CPHA=1 CPOL=1 SCK输入 tSU(MI) MISO输入 tW(SCKH) tW(SCKL) 输入最高位 输入最低位 输入第6~1位 th(MI) MOSI输出 输出最高位 输出第6~1位 tv(MO) 输出最低位 th(MO) 54 USB 交叉点 差分数据线 VCRS V SS tf tf 55 56 57 58 59 60 61 +0.05 -0.06 62 63 +0.05 -0.06 64 65 +0.05 -0.06 66 例如: APM32 F 103 C 8 T 6 XXX 产品系列 APM32=基于ARM的32位微控制器 产品类型 F=通用类型 E=增强类型 产品子系列 103=基础型 引脚数目 T=36脚 C=48脚 R=64脚 V=100脚 闪存存储器容量 4=16Kbytes 6=32Kbytes 8=64Kbytes B=128Kbytes 封装 T=LQFP U=QFN 温度范围 6=-40℃~85℃ 7=-40℃~105℃ 选项 XXX=已编程的器件代号 TB=卷带式包装 67 68 69 70
APM32F103CBT6 价格&库存
很抱歉,暂时无法提供与“APM32F103CBT6”相匹配的价格&库存,您可以联系我们找货
APM32F103CBT6
    • 1+9.42590
    • 10+8.39740
    • 30+7.41730
    • 250+6.69130
    • 500+6.40090
    • 1000+6.24360
    库存:7683
    APM32F103CBT6
    • 1+7.63420
    • 10+6.80120
    • 30+6.00740
    库存:215
    APM32F103CBT6
      • 2500+7.46665
      库存:15000
      APM32F103CBT6
        • 343+7.46665
        库存:343
