15.50±0.30
H
Specifications
Material
Insulator: LCP, UL 94V-0, Black
Contact: Copper Alloy
Shell: Stainless Steel
Latch: Stainless Steel
EMI Spring: Stainless Steel
8.00
G
B1
0.84+0.25
-0.04
B12
A
12.50±0.20
1.00
7.40±0.20
8.80
2.50
8.25±0.03
0.81+0.15
-0.10
0.15
0.90
1.30
0.18 Min.
D
1.30±0.05
2.90
A1
Plating
Contact
Contact Area: 3u" Au over Nickel
Solder Tails: Matte Tin over Nickel
Shell: Nickel
Latch& EMI Spring: Cleaning
2.40±0.03
A12
E
6.83±0.05
2x 0.35
A
0.80±0.05
F
C
Electrical
Current Rating:
5.00A collectively for VBUS pins
6.25A collectively for GND pins
1.25A for B5 pin
0.25A per pin for all other pins
Voltage Rating: 20V DC
Contact Resistance: 40mΩ max initial.
50mΩ max after test
Dielectric Withstanding Voltage: 100V AC
Insulation Resistance 100MΩ min
Mechanical & Environmental
Operating Temperature: -30°C to +85°C
Mating Force: 5 to 20 N.
Unmated Force: 6 to 20 N after test
Durability: 10,000 cycles
0.10
Ordering Grid
2.64±0.10
USB4155
4.64±0.05
Section A-A
B
03
Contact Plating
03 = 3u" Gold
C
Request Samples
and Quotation
Packing Options
C = Tape & Reel with Cap
(1000 per reel)
A
0.50±0.05
0.20
Part Number
Product Description
USB4155
USB3.2 Gen2 Type C Plug, Horizontal, SMT
Drawing Date
12th April 2021
5.50±0.05
By
Detail
1
2
3
4
Revision
Date
5
CC
Drawing
Release
A1
27/05/21
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/4
H
7.40
5.50
1.075
0.25
2x 1.00
2x 0.50
A12
0.825
0.50
0.30
A1
5.05
4.60
4.27
0.5 ref.
F
0.825
1.075
1.075
USB4155
(Plug)
USB4115
(Receptacle)
1.70
2.50
B12
1.00
PCB Edge
B1
0.20
2x 1.80
2x 1.30
2.30
G
PCB
Panel
6.55 min.
PCB
Plug and Receptacle Mating View
E
Recommended PCB Layout
Thickness 0.8 to 1.0 mm
Tolerance: ±0.05mm
Pin
C
B
A
Component Outline
Signal
Description
Pin
Ground return
Positive half of first SuperSpeed
TX differential pair
A1
GND
A2
SSTXp1
A3
SSTXn1
A4
VBUS
A5
CC1
Negative half of first SuperSpeed
Bus Power
Configuration Channel
9.85
Solder Area
Signal
Description
B12
GND
B11
SSRXp1
Ground return
RX differential pair
B10
SSRXn1
B9
VBUS
B8
SBU2
B7
Dn2
Positive half of the USB 2.0
differential pair - Position 2
Dp2
Negative half of the USB 2.0
A6
Dp1
differential pair - Position 1
A7
Dn1
B6
A8
SBU1
Sideband Use (SBU)
B5
CC2
A9
VBUS
B4
VBUS
A10
SSRXn2
Bus Power
Negative half of second
SuperSpeed RX differential pair
Bus Power
SuperSpeed TX differential pair
A11
SSRXp2
Positive half of second
A12
GND
Ground return
SHELL
1
GND
B3
SSTXn2
B2
SSTXp2
B1
GND
Ground return
SHELL
2
16.35
Bus Power
Sideband Use (SBU)
2.40
D
Cap Information
Part Number
Product Description
USB4155
Drawing Date
12th April 2021
By
GND
3
Detail
4
Revision
Date
5
CC
Drawing
Release
A1
27/05/21
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/4
H
1.8 max.
Weight
0.05 min.
PCB
G
5g min. force apply on the product
Weight
Tray
PCB
Tray
F
Proposal 1: Recommended Jig(Tray, Weight) be used in IR Reflow Process
E
1.80 max.
Weight
D
0.05 min.
PCB
C
Weight
PCB
Tray
Tray
B
Proposal 2: Recommended Jig(Tray, Weight) be used in IR Reflow Process
Part Number
Product Description
USB4155
Drawing Date
A
12th April 2021
By
Detail
1
2
3
4
Revision
Date
5
CC
Drawing
Release
A1
27/05/21
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
3/4
H
Folder
Paper Board
Unloaded Section
(20 Pockets)
1000 PCS
Unloaded Section
(20 Pockets)
Paper Board
G
Vacuum Bag
F
Peeling
Angle
165°~180°
E
Reel and Tape
Direction of Unreeling
Carton
Ø330
Reel and Tape
325
D
Ø13
W+0.5
Label
35
C
16.00±0.10
4.00
2.00
Ø1.50
Paper Board
Pcs /
Reel
1000
32.00±0.30
B
Product Description
USB4155
12th April 2021
By
Detail
1
2
Total
Quantity
8,000 pcs
Part Number
Drawing Date
A
Reels /
Carton
8
3
4
Revision
Date
5
CC
Drawing
Release
A1
27/05/21
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
4/4
很抱歉,暂时无法提供与“USB4155-03-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+8.955831000+1.15924
- 2000+8.528532000+1.10393
- 3000+8.288123000+1.07281
- 5000+7.994995000+1.03487
- 7000+7.807597000+1.01061
- 10000+7.6138010000+0.98553
- 国内价格
- 1+14.83920
- 10+12.33360
- 30+10.75680
- 100+9.15840
