BIWIN /
DTS/A/H Series—Tri-State DIP Switch
RoHS Compliant
Features
Twin contacts designed to ensure stable contact
Highly resistant to physical shock & vibration
Tape sealed version available to ensure washability
Low profile to save PCB space
Tri-State(+,0,-) setting function
8
8 poles=(3 )=6,561 codes
10
10 poles=(3 )=59,049 codes
◆ Light click feeling
◆ Heat resistance: 260°C for 10 sec.
DTS
SMD SOLDERING PAD
6.90±0.10
1 2 3 4
N
9.70±0.3
DTA/H
DRILLING PLAN
DTA
DTH
1 2 3 4
Materials
Actuator
Cover & Base: Thermoplastic UL 94V-0, Black
Actuator: Thermoplastic UL 94-HB, White
Movable Contact: Copper Alloy, Gold- or Pure-Tin-plated
Terminal & Terminal Contact: Copper Alloy, Gold- or
Pure-Tin-plated
◆ Tape Sealed: Polyimide film
Packaging lnformation
6.00±0.10
6.00±0.10
L/T type
6.00±0.10
M type
G type
Wiring Diagram
◆ Tube: DTS/ DTA/ DTH
◆ Tape & Reel: DTS
◆ Actuators all in "OFF" position
1
2
3
4
N
Soldering lnformation
◆ Hand Soldering
Soldering Iron of 30W or under at 350°C for 3 sec. max. or at 270°C for 5 sec. max.
◆ Wave Soldering
260±5°C for 10 sec. max.
◆ Reflow Soldering
Peak temperature: 245 or 250°C max. The time above 240 or 245°C must be 30 sec. max.
◆ Keep all actuators in "OFF" position during soldering and cleaning process
Tri-State Type
S
08
Terminal:
S=SMD
A=Auto-insert
H=Straight
Positions:
06=6 Position
08=8 Position
G
01
Finished:
Actuator:
01=1u" Gold
G=Raise Actuator
M=Medium Actuator 03=3u" Gold
E=Tin Plated
L=Flat Actuator
T=Tape Sealed
"G, M & L types: un-washable"
http://www.biwin.com
http://www.sab.com.tw
Package
P/N
No. Of
Pole
Dim.
A
Quantity
per Tube
DTS/A/H02
DTS/A/H03
DTS/A/H04
DTS/A/H06
DTS/A/H07
DTS/A/H08
DTS/A/H09
DTS/A/H10
DTS/A/H12
2
3
4
6
7
8
9
10
12
5.52mm
8.06mm
10.60mm
15.68mm
18.22mm
20.76mm
23.30mm
25.84mm
30.92mm
95
65
48
33
28
25
22
Order lnformation
DT
0.70±0.05
◆ Contact Rating
Switching ………………………………
25mA, 24VDC
Non-Switching ……………………………
100mA, 50VDC
◆ Contact Resistance
Initial ……………………………………
50mΩ Max.
After Life Test ……………………………
100mΩ Max.
◆ Insulation Resistance …………………
100MΩ min at 500VDC
◆ Dielectric Strength ……………………
500VAC/ 1 minute
◆ Operating Force………………………
1,000g Max.
◆ Mechanical Life…………… 3,000 cycles
◆ Electrical Life……………… 2,000 cycles
0.40±0.05
Specifications
N
R
U
Package:
None=Tube
R=Tape & Reel
None=Standard
U=Halogen Free
http://www.sab-switch.com.cn
Oct. 2016
很抱歉,暂时无法提供与“DTH08GE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.71482
- 10+5.19156
- 25+4.74012
- 100+4.41180
- 500+4.26816
- 1000+4.19634
