DW01A
General Description
Ordering Information
The DW01A battery protection IC is designed to
protect lithium-ion/polymer battery from damage or
degrading the lifetime due to overcharge,
overdischarge, and/or overcurrent for one-cell
lithium-ion/polymer battery powered systems, such as
cellular phones.
DW01A
PACKAGE TYPE
SOT-23-6
TEMPERATURE RANGE
-40°C~+85°C
The ultra-small package and less required external
components make it ideal to integrate the DW01A
into the limited space of battery pack. The accurate
±50mV overcharging detection voltage ensures safe
and full utilization charging. The very low standby
current drains little current from the cell while in
storage.
OVERCHARGE PROTECTION
4.3V± 50mV
Features
Applications
Reduction in Board Size due to Miniature
Package SOT-23-6.
Protection IC for One-Cell Lithium-Ion /
Lithium-Polymer Battery Pack
Ultra-Low Quiescent Current at 3μA
(Vcc=3.6V).
Overdischarge Current at 4 μA
(Vcc=1.8 V).
Precision Overcharge Protection Voltage
4.3V ± 50mV
Two Detection Levels for Overcurrent
Protection.
Delay times are generated by internal circuits.
No external capacitors required.
Rev B
- 1-
2016-4-12
DW01A
Product Name List
Overcharge Overcharge Overdischarge Overdischarge Overcurrent
0V
detection
battery
release
detection
release
detection
Product Package
voltage
charge
voltage
voltage
voltage
voltage
[VOCP] (V) [VOCR] (V) [VODP] (V)
[VODR] (V) [VOI1] (mV) function
DW01A SOT-23-6 4.300±0.050 4.100±0.050
2.90 ±0.1
2.50±0.1
150±20
available
Stand by
function
release
Auto
Recovery
Pin Configuration
Pin No. Symbol
Description
6
1
OD
MOSFET gate connection pin for discharge control
2
VM
Input pin for current sense, charger detect
3
OC
MOSFET gate connection pin for charge control
4
TD
Test pin for reduce delay time
5
VCC
Power supply, through a resistor (R1)
6
GND
Ground pin
5
4
SOT-23-6
TOP VIEW
1
2
3
TD
Functional Block Diagram
VCC
Short circuit
Detector
VSS
Overcharge
Detector
Over current
Detector
VSS
Divider
Control
Logic
Overdischarg
e Detector
VM
Charger
Detector
GND
VSS
Control
Logic
OC
OD
VSS
Rev B
VSS
Oscillator
Control
Circuit
- 1 -2
2016-4-12
DW01A
Typical Application Circuit
BATT+
R1
100Ω
VCC
C1
0.1μF
DW01A
GND
OC
VM
OD
TD
R2
1kΩ
M1
M2
BATT-
Absolute Maximum Ratings
(VSS=0V, Ta=25°C unless otherwise specified)
Item
Symbol
Rating
Input voltage between VDD and VSS
VDD
OC output pin voltage
VOC
VDD-24 to VDD+0.3
V
OD output pin voltage
VOD
VSS-0.3 to VDD+0.3
V
CS input pin voltage
VCS
VDD-24 to VDD+0.3
V
Operating Temperature Range
TOP
-40 to +85
°C
Storage Temperature Range
TST
-40 to +125
°C
Rev B
- 3-
0.3 to 10
Unit
V
2016-4-12
DW01A
Electrical Characteristics
(Ta=25°C unless otherwise specified)
PARAMETER
TEST CONDITIONS SYMBOL
Supply Current
VCC=3.6V
ICC
Power-Down Current
VCC=1.8V
IPD
Typ
Max
UNIT
3.0
6.0
μA
4
μA
0V Battery Charge Starting Charger
Voltage
V0CHA
1.2
VOC
4.25
4.30
4.35
V
Overcharge Release Voltage
VOCR
4.05
4.10
4.15
V
Overdischarge Protection Voltage
VOD
2.40
2.50
2.60
V
Overdischarge Release Voltage
VODR
2.80
2.90
3.00
V
Overcurrent Protection Voltage
VEDI
130
150
170
mV
Short Current Protection Voltage
Vshort
0.82
1.36
1.75
V
TOC
110
200
ms
TOD
55
200
ms
Overcurrent Delay Time (1)
T EDI
7
ms
Overcurrent Delay Time (2)
T short
400
600
μs
Overcharge Delay Time
Overdischarge Delay Time
Rev B
Min
VCC=3.6V to 2.4V
OD Pin Output “H” Voltage
VCC=3.9V
ICO =10uA
DoutH
OD Pin Output “L” Voltage
VCC=2V
IDO =10uA
DoutL
OC Pin Output “H” Voltage
VCC=3.9V
ICO =10uA
CoutH
- 4-
V
VCC-0.4 VCC-0.2
0. 2
VCC-0.1 VCC-0 02
V
0.5
V
V
2016-4-12
DW01A
Timing Diagram
1.
Overcharge Condition
Load Discharging
Normal Condition
Charger
Load
Battery Voltage
VOC
VOCR
VODR
VOD
OC Pin
VCC
VM
OD Pin
VCC
GND
VM Pin
VCC
VEDI
GND
VOCH
TOC
Rev B
TOC
- 5-
2016-4-12
DW01A
2.
Overdischarge Condition
Charging by a Charger
Normal Condition
Charger
Load
Battery Voltage
VOC
VOCR
VODR
VOD
OC Pin
VCC
VM
OD Pin
VCC
GND
VM Pin
VCC
Vshort
GND
VOCH
TOD
Rev B
TOD
- 6-
2016-4-12
DW01A
3.
Over Current Condition
Normal Condition
Charger
Load
Battery Voltage
VOC
VOCR
VODR
VOD
OC Pin
VCC
VM
OD Pin
VCC
GND
VM Pin
VCC
Vshort
VEDI
GND
T EDI
Rev B
T short
- 7-
2016-4-12
很抱歉,暂时无法提供与“DW01A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.27746
- 200+0.22140
- 600+0.19030
- 3000+0.15455
- 9000+0.13835
- 21000+0.12960
- 国内价格
- 50+0.12000
- 500+0.10800
- 5000+0.10000
- 10000+0.09600
- 30000+0.09200
- 50000+0.08960
