ES3A - ES3J
SURFACE MOUNT SUPER FAST RECOVERY DIODES
VOLTAGE RANGE: 50 - 600V
CURRENT: 3.0 A
Features
Glass Passivated Die Construction
Ideally Suited for Automatic Assembly
Low Forward Voltage Drop, High Efficiency
! Low Power Loss
! Super-Fast Recovery Time
! Plastic
Case
Material
has
UL
Flammability
B
SMB(DO-214AA)
Classification Rating 94V-O
A
Mechanical Data
Case: SMB/DO-214AA, Molded Plastic
Terminals: Solder Plated, Solderable
per MIL-STD-750, Method 2026
Polarity: Cathode Band or Cathode Notch
Dim
Min
Max
A
3.30
3.94
C
D
J
Marking: Type Number
G
E
H
Weight: 0.093 grams (approx.)
Maximum Ratings and Electrical Characteristics
B
4.06
4.70
C
1.91
2.21
D
0.15
0.31
E
5.00
5.59
G
0.10
0.20
H
0.76
1.52
J
2.00
2.62
All Dimensions in mm
TA = 25C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Characteristic
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
RMS Reverse Voltage
Average Rectified Output Current
ES3A
ES3B
ES3C
ES3D
ES3E
ES3G
ES3J
Unit
VRRM
VRWM
VR
50
100
150
200
300
400
600
V
VR(RMS)
35
70
105
140
210
280
420
V
IO
3.0
A
Non-Repetitive Peak Forward Surge Current
8.3ms Single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
100
A
Forward Voltage
@IF = 3.0A
VFM
@TA = 25°C
@TA = 100°C
IRM
5.0
500
µA
Reverse Recovery Time (Note 1)
trr
35
nS
Typical Junction Capacitance (Note 2)
Cj
45
pF
RJL
16
°C/W
Tj, TSTG
-65 to +150
°C
Peak Reverse Current
At Rated DC Blocking Voltage
@TL = 75°C
Symbol
Typical Thermal Resistance (Note 3)
Operating and Storage Temperature Range
0.95
1.25
1.7
V
Note: 1. Measured with IF = 0.5A, IR = 1.0A, Irr = 0.25A. See figure 5.
2. Measured at 1.0 MHz and applied reverse voltage of 4.0 V DC.
3. Mounted on P.C. Board with 8.0mm2 land area.
1 of 2
www.sunmate.tw
FIG. 1- FORWARD CURRENT DERATING CURVE
3.0
2.4
1.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
0.6
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES ES3A THRU ES3J
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
100
80
60
40
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
1
0.1
ES3A-ES3D
ES3E-ES3G
ES3J
0.01
0.8
1.2
1.6
1.8
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
10
1,000
100
10
TJ=100 C
1
TJ=25 C
0.1
0.01
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
60
80
100
200
100
10
TJ=25 C
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENTAGE OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
t,PULSE DURATION,sec.
2 of 2
www.sunmate.tw
很抱歉,暂时无法提供与“ES3J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.18400
- 50+0.17020
- 200+0.15870
- 600+0.14720
- 1500+0.13800
- 3000+0.13225
