SS36
SS36
    SUNMATE(森美特)
    SMA(DO-214AC)
    肖特基 VRRM=60V I(AV)=3A VF=0.7V SMA
SS36 数据手册
SS32 - SS310 SURFACE MOUNT SCHOTTKY BARRIER DIODES VOLTAGE RANGE: 20 - 100V CURRENT: 3.0 A Features ! For Surface Mounted Applications ! High Temperature Metallurgically Bonded Contacts ! Plastic Material - UL Flammability ! Classification 94V-0 ! High Reliability ! High Current Capability and Low VF   !    Submersible             Temperature             of   265°C       for                                 B              10 Seconds in Solder Bath A Mechanical Data ! ! ! ! ! ! Case: SMA(DO-214AC), Molded Plastic Terminals: Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Mounting Position: Any SMA(DO-214AC) Dim Min Max A 2.29 2.92 B 4.00 4.60 C 1.27 1.63 D 0.15 0.31 E 4.80 5.59 C D J Weight: 0.064 grams (approx.) H Maximum Ratings and Electrical Characteristics G E G 0.10 0.20 H 0.76 1.52 J 2.01 2.62 All Dimensions in mm TA = 25C unless otherwise specified Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. Characteristic Symbol Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL(see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) VRRM VRMS VDC Typical thermal resistance (NOTE 2) Operating junction temperature range RθJA Storage temperature range SS32 SS33 SS34 SS35 SS36 SS38 SS310 20 14 20 30 21 30 40 28 40 80 56 80 60 42 60 50 35 50 100 70 100 Unit V V V I(AV) 3.0 A IFSM 100.0 A VF IR CJ TJ, TSTG 0.55 0.85 0.70 0.5 20 10 500 300 -65 to +125 55.0 -65 to +150 -65 to +150 V mA pF C/W C C Note: 1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 1 of 2 www.sunmate.tw FIG. 1- FORWARD CURRENT DERATING CURVE FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 3.0 2.4 Single Phase Half Wave 60Hz Resistive or inductive Load 1.8 1.2 SS32-SS34 SS35-SS310 0.6 0 0 25 50 75 100 £PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES RATINGS AND CHARACTERISTIC CURVES SS32 THRU SS310 100 125 150 80 60 40 20 175 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 0 1 10 AMBIENT TEMPERATURE, C 100 NUMBER OF CYCLES AT 60 Hz FIG. 4-TYPICAL REVERSE CHARACTERISTICS FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 50 1,000 INSTANTANEOUS REVERSE CURRENT, MILLIAMPERES TJ=25 C INSTANTANEOUS FORWARD CURRENT,AMPERES 10.0 1 SS32-SS34 SS35-SS36 SS38-SS310 0.1 100 TJ=100 C 10 TJ=75 C 1 0.1 TJ=25 C 0.01 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% 1.6 INSTANTANEOUS FORWARD VOLEAGE, VOLTS FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE 2000 JUNCTION CAPACITANCE, pF 1000 TJ=25 C 100 SS32-SS34 SS35-SS310 100 10 1 0.1 0.01 0.1 1 10 100 10 0.1 1.0 10 100 REVERSE VOLTAGE,VOLTS t,PULSE DURATION,sec. 2 of 2 www.sunmate.tw
很抱歉,暂时无法提供与“SS36”相匹配的价格&库存,您可以联系我们找货
SS36
  • 10+0.17600
  • 50+0.16280
  • 200+0.15180
  • 600+0.14080
  • 1500+0.13200
  • 3000+0.12650
