SMF24CA
SMF24CA
    LIOWN(里阳)
    SOD-123FL
    TVS二极管 双向 Vr=24V Vc=38.9V
SMF24CA 数据手册
TVS Diodes SMF Series Description The SMF series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. SMF package is 50% smaller in footprint when compare to SMA package and deliverying one of the low height profiles (1.2mm) in the industry. Features       IEC-61000-4-2 ESD 15kV(Air), 8kV (Contact) SOD-123FL surface mount package Protects one I/O line Peak power dissipation of 1000W under 8/20μs waveform Low leakage current Solid-state silicon avalanche technology    RoHS compliant Solder reflow temperature: Pure Tin-Sn, 260~270℃ Flammability rating UL 94V-0  Meet MSL level1, per J-STD-020 Applications SMF devices are ideal for the protection of I/O interfaces, VCC bus and other vulnerable circuit used in cellular phones, portable devices, business machines, power supplies and other consumer applications. Maximum Ratings and Characteristics (TA=25℃) Rating Symbol Value Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM 200W Peak pulse power (tp=8/20μs waveform) PPPM 1000W Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table(A) PM(AV) 1.0W VF 3.5V IFSM 20A TJ,TSTG -55℃ to +150℃ Typical thermal resistance junction to lead RθJL 100℃/W Typical thermal resistance junction to ambient RθJA 220℃/W Steady state power dissipation at TL=75℃ (Fig.5) Maximum Instantaneous Forward Voltage at 12A for Unidirectional Only Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Ranges Notes:1. Non-repetitive current pulse, per Fig.3 and derating above TA=25℃ per Fig.2. 2. Each terminal is surface Mounted on the 5.0mm×5.0mm (0.03mm thick) copper pads. 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum. www.liownsemi.com 掌握芯技术Core Technology (V3) TVS Diodes SMF Series Electrical Characteristics (TA=25℃) Device Marking Code Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VR Uni. Bi. Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) SMF5.0A SMF5.0CA KE AE 5 6.4 7 10 9.2 21.8 500 SMF6.0A SMF6.0CA KG AG 6 6.67 7.37 10 10.3 19.4 400 SMF6.5A SMF6.5CA KK AK 6.5 7.22 7.98 10 11.2 17.9 350 SMF7.0A SMF7.0CA KM AM 7 7.78 8.6 10 12.0 16.7 200 SMF7.5A SMF7.5CA KP AP 7.5 8.33 9.21 1 12.9 15.5 100 SMF8.0A SMF8.0CA KR AR 8 8.89 9.83 1 13.6 14.7 50 SMF8.5A SMF8.5CA KT AT 8.5 9.44 10.4 1 14.4 13.9 20 SMF9.0A SMF9.0CA KV AV 9 10 11.1 1 15.4 13.0 10 SMF10A SMF10CA KX AX 10 11.1 12.3 1 17.0 11.8 5 SMF11A SMF11CA KZ AZ 11 12.2 13.5 1 18.2 11.0 3 SMF12A SMF12CA LE BE 12 13.3 14.7 1 19.9 10.1 1 SMF13A SMF13CA LG BG 13 14.4 15.9 1 21.5 9.3 1 SMF14A SMF14CA LK BK 14 15.6 17.2 1 23.2 8.6 1 SMF15A SMF15CA LM BM 15 16.7 18.5 1 24.4 8.2 1 SMF16A SMF16CA LP BP 16 17.8 19.7 1 26.0 7.7 1 SMF17A SMF17CA LR BR 17 18.9 20.9 1 27.6 7.3 1 SMF18A SMF18CA LT BT 18 20 22.1 1 29.2 6.9 1 SMF20A SMF20CA LV BV 20 22.2 24.5 1 32.4 6.2 1 SMF22A SMF22CA LX BX 22 24.4 26.9 1 35.5 5.7 1 SMF24A SMF24CA LZ BZ 24 26.7 29.5 1 38.9 5.2 1 SMF26A SMF26CA ME CE 26 28.9 31.9 1 42.1 4.8 1 SMF28A SMF28CA MG CG 28 31.1 34.4 1 45.4 4.4 1 SMF30A SMF30CA MK CK 30 33.3 36.8 1 48.4 4.2 1 SMF33A SMF33CA MM CM 33 36.7 40.6 1 53.3 3.8 1 SMF36A SMF36CA MP CP 36 40 44.2 1 58.1 3.5 1 www.liownsemi.com 掌握芯技术Core Technology (V3) TVS Diodes SMF Series Electrical Characteristics (TA=25℃) Device Marking Code Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VR Uni. Bi. Uni. Bi. VR(V) VB MIn.(V) VB Max.(V) IT(mA) VC(V) IPP(A) IR(μA) SMF40A SMF40CA MR CR 40 44.4 49.1 1 64.5 3.1 1 SMF43A SMF43CA MT CT 43 47.8 52.8 1 69.4 2.9 1 SMF45A SMF45CA MV CV 45 50 55.3 1 72.7 2.8 1 SMF48A SMF48CA MX CX 48 53.3 58.9 1 77.4 2.6 1 SMF51A SMF51CA MZ CZ 51 56.7 62.7 1 82.4 2.5 1 SMF54A SMF54CA NE DE 54 60 66.3 1 87.1 2.3 1 SMF58A SMF58CA NG DG 58 64.4 71.2 1 93.6 2.2 1 SMF60A SMF60CA NK DK 60 66.7 73.7 1 96.8 2.1 1 SMF64A SMF64CA NM DM 64 71.1 78.6 1 103.0 2.0 1 SMF70A SMF70CA NP DP 70 77.8 86 1 113.0 1.8 1 SMF75A SMF75CA NR DR 75 83.3 92.1 1 121.0 1.7 1 SMF78A SMF78CA NT DT 78 86.7 95.8 1 126.0 1.6 1 SMF85A SMF85CA NV DV 85 94.4 104 1 137.0 1.5 1 SMF90A SMF90CA NX DX 90 100 111 1 146.0 1.4 1 SMF100A SMF100CA NZ DZ 100 111 123 1 162.0 1.3 1 SMF110A SMF110CA PE EE 110 122 135 1 177.0 1.2 1 SMF120A SMF120CA PG EG 120 133 147 1 193.0 1.1 1 SMF130A SMF130CA PK EK 130 144 159 1 209.0 1.0 1 SMF150A SMF150CA PM EM 150 167 185 1 243.0 0.8 1 SMF160A SMF160CA PP EP 160 178 197 1 259.0 0.8 1 SMF170A SMF170CA PR ER 170 189 209 1 275.0 0.8 1 www.liownsemi.com 掌握芯技术Core Technology (V3) TVS Diodes SMF Series Ratings and Characteristic Curves (TA=25℃) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve Figure 3. Pulse Waveform Figure 4. Typical Junction Capacitance 150 tr=10µs 1000 Peak Value IPPM Uni-directional V=0V Cj (pF) 100 Half Value IPPM (IPPM/2) 50 0 10000 TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM 10/1000µs Waveform as defined by R.E.A 1 1.0 2.0 3.0 Bi-directional V=0V 10 td 0 100 4.0 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 Time (ms) Figure 5. Steady State Power Dissipation Derating Curve www.liownsemi.com 10 100 VBR-Reverse Breakdown Voltage (V) 1000 Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 掌握芯技术Core Technology (V3) TVS Diodes SMF Series Soldering Parameters Reflow Soldering Profile Feature Pb-Free Assembly Average ramp-up rate (TL to TP) 3℃/second max. Preheat -Temperature Min (TS min) -Temperature Max (TS max) -Time (min to max) ( tS) 150℃ 200℃ 60-180 seconds TS max to TL -Ramp-up Rate 3℃/second max. Time maintained above: -Temperature (TL) -Time (tL) 217℃ 60-150 seconds Peak Temperature (TP) 260℃ Time within 5℃ of actual Peak Temperature (tP) Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature www.liownsemi.com 20-40 seconds 8 minutes max. 掌握芯技术Core Technology (V3) TVS Diodes SMF Series Part Number Code and Marking Code Dimensions (SOD-123FL) Symbol Cathode Band E 1.00 Max. Min. Max. A 3.50 3.90 0.138 0.154 B 2.60 3.00 0.102 0.118 C 0.75 1.10 0.030 0.043 D 1.60 2.00 0.063 0.079 E h 0.80Typ. 0.031Typ. 2.00 Recommended Soldering Pad Layout www.liownsemi.com Inches Min. (for uni-directional products only) B A Millimeters H 0.90 1.35 0.035 0.053 h 0.12 0.22 0.005 0.009 掌握芯技术Core Technology (V3) TVS Diodes SMF Series Packaging Specification Tape For Uni-Devices 7 Inches Reel Quantity:3000pcs/reel www.liownsemi.com 掌握芯技术Core Technology (V3)
SMF24CA 价格&库存
很抱歉,暂时无法提供与“SMF24CA”相匹配的价格&库存,您可以联系我们找货
SMF24CA
  • 1+0.12090
  • 10+0.11160
  • 30+0.10974
  • 100+0.10416
