SJK-6N20000M3C0450F5
    SJK(晶科鑫)
    SMD7050_4P
    有源晶振 20MHz 3.3V ±10ppm SMD7050_4P
SJK-6N20000M3C0450F5 数据手册
Crystal oscillator SMD CMOS Output 7.0×5.0×1.3mm 6N Series ... Approved by: 刘惠光 Checked by : 李相同 Issued by: 贺丹斌 SPECIFICATION PN: SJK-6N20000M3C0450F5 深圳市晶科鑫实业有限公司 SHENZHEN CRYSTAL TECHNOLOGY INDUSTRIAL CO., LTD. Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 1 Crystal oscillator SMD CMOS Output 7.0×5.0×1.3mm 6N Series ... FEATURE l Small SMD seam sealed clock crystal oscillator units. l High precision characteristic covering up to wide frequency range. l Designed for automatic mounting and reflow soldering. l Tri-State function available. l Supply voltage range : 1.8 V ~ 5.0 V. l High stability, low jitter, low power consumption. l Main application : wireless communication set, PC, and LCDM. l RoHS Compliant / Pb Free. ELECTRICAL SPECIFICATIONS(电气参数) Condition\Model Parmeters 6N Fan Out Type CMOS Supply Voltage 3.3V±10% Frequency 20.000MHz Operating Temperature Current -40℃ to +85℃ 20mA max Frequency Stability All Conditions ±50ppm Output Voltage Vol(max) 10%VDD VoH(min) 90%VDD Rise/Fall Time AT 0.1Vdd~0.9Vdd 5ns max Load Capacitance Duty Cycle 50±10% Storge Temperature Load RANGE Start-upTime PAD Connection -55~+125℃ 5mSec max ±3ppm(1st ,year at 25 ℃) Aging Tri-State 15pF Output Active Output in High-Impedance 2.31V Min Pin 1 Tri-state 0.99V Max PIN#1 Tri-State/NC PIN#3 OUT PIN#2 GND PIN#4 Vdd Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 2 Crystal oscillator SMD CMOS Output 7.0×5.0×1.3mm 6N Series Dimension(尺寸)(Unit:mm) MARK(印字) SJK 20.000 . MHz MEASUREMENT CIRCUIT(电路) Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 3 ... Crystal oscillator SMD CMOS Output 7.0×5.0×1.3mm 6N Series WAVEFORM CONDITIONS (波形) REFLOW CONDITION(回流焊) The reflow temperature profile may vary depending on the product model, specifications and frequency range.Refer to the individual product specifications for details Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 4 ... Crystal oscillator SMD CMOS Output 7.0×5.0×1.3mm 6N Series CARRIER TYPE (载带) REEL(卷盘) Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 5 ... Crystal oscillator SMD CMOS Output 7.0×5.0×1.3mm 6N Series ... RELIABILITY TEST SPECIFICA TIONS(可靠性测试标准) Test item 1.SOLDERABILITY TEST Equipment SJK-REL001、RC-328A Condition Specification 1.Solderabiliity:235±5℃, 5±0.5S MIL-STD-883E 2.Heat resistance:260±5℃,10±1S restoration of 1 Method 2003.7 hour MIL-STD-883E Method 1014.10 2. HERMETICITY TEST HELIOT-306S Pressurized 0.4~0.5Mpa ethanol sealed tank for 10 minutes 3. VIBRATION TEST HG-V4、S&A 250B MIL-STD-883E Enable Crystal(10g) from 10-55-10Hz,X、Y、Z Method 2007.3 horizontal,1 Minute vibration/time, 1time/ 2 hours. 4. MECHANICAL SHOCK HPC-200、S&A 250B Enable Crystal 50G(490m/s2) time=11 ms speed=3.4 m/s half sine wave oscillation 5. DROP TEST HARD BOARD.S&A250B 75cm High,3 times on hard board 6. HIGH&LOW TEMP STORAGE TEST(Static test) H-PTH-80CK & HM101-3ABN, High temperature: 125℃±2℃,1000hr;Low S&A 350B/250B temperature:-40℃±3℃,1000hrs 7. TEMP &HUM CYCLING TEST H-PTH-80CK CHAMBE,S&A 350B/250B 8. HIGH TEM. & HUM. STORAGE TEST H-PTH-80CK CHAMBE, S&A350B/250B 9.AGING TEST H-PTH-80CK CHAMBE, S&A350B/250 JIS C6701 MIL-STD-202F Method 213B MIL-STD883C, METHOD 1011.8 Temperature:-10℃±2℃~65℃±2℃,Humidity:93± MIL-STD-883E Method 1005.8 3%,1 cycle need 24 hrs. 5cycles. Temperature:85℃±2,Humidity:85+3,-2%,Store 96 hrs JIS C6701 Temperature:85℃±2,Store 1000 hrs JIS C5023 Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 6
SJK-6N20000M3C0450F5 价格&库存
很抱歉,暂时无法提供与“SJK-6N20000M3C0450F5”相匹配的价格&库存,您可以联系我们找货
