SJK-7I08000MAB3550F5
    SJK(晶科鑫)
    SMD5032_4P
    无源晶振 8MHz 80Ω 12pF ±30ppm -40℃~+105℃ SMD5032_4P
SJK-7I08000MAB3550F5 数据手册
Crystal Resonators SMD Seam 5.0×3.2×0.9mm 7I Series . Approved by: 刘惠光 Checked by : 李相同 Issued by: 贺丹斌 SPECIFICATION PN: SJK-7I08000MAB3550F5 深圳市晶科鑫实业有限公司 SHENZHEN CRYSTAL TECHNOLOGY INDUSTRIAL CO., LTD. Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 1 Crystal Resonators SMD Seam 5.0×3.2×0.9mm 7I Series FEATURE l Reliable seam sealed ceramic package. l Wide operating temperature range. l Superior performance and stringent reliability in harsh environment. l Application: TPMS, ECM, ABS and sensor modules. l Compact size. l RoHS Compliant / Pb Free. ELECTRICAL SPECIFICATIONS(电气参数) Output Frequency Range 8.000MHz Mode AT/Fundamental Frequency Tolerance (at 25°C) ±30ppm Frequency Stability Over Operating ±50ppm Temperature Characteristics Operating Temperature Range -40℃ to +105℃ Storage Temperature Range -55℃ to +125℃ Shunt Capacitance (C0) 3.0 PF Max Driver Level (DL) 100µW Typical Load Capacitance(CL) 12PF Equivalent Series Resistance(ESR) 80Ω Max Aging @25°C 1st year (Max) ±3ppm/year REMARK: SPECIFICATIONS SUBJECT TO CHANGE WITHOUT PRIOR NOTICE. PLEASE CONFIRM WITH OUR SALES ENGINEER. Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 2 . Crystal Resonators SMD Seam 5.0×3.2×0.9mm 7I Series Dimension(尺寸)(Unit:mm) MARK(印字) SJK 8.000 REFLOW CONDITION(回流焊) The reflow temperature profile may vary depending on the product model, specifications and frequency range.Refer to the individual product specifications for details Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 3 . Crystal Resonators SMD Seam 5.0×3.2×0.9mm 7I Series CARRIER TYPE (载带) REEL(卷盘) Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 4 . Crystal Resonators SMD Seam 5.0×3.2×0.9mm 7I Series . RELIABILITY TEST SPECIFICA TIONS(可靠性测试标准) Test item 1.SOLDERABILITY TEST Equipment SJK-REL001、RC-328A Condition 1.Solderabiliity:235±5℃, 5±0.5S 2.Heat resistance:260±5℃,10±1S restoration of 1 hour Specification MIL-STD-883E Method 2003.7 MIL-STD-883E Method 1014.10 2. HERMETICITY TEST HELIOT-306S Pressurized 0.4~0.5Mpa ethanol sealed tank for 10 minutes 3. VIBRATION TEST HG-V4、S&A 250B Enable Crystal(10g) from 10-55-10Hz,X、Y、Z MIL-STD-883E Method 2007.3 horizontal,1 Minute vibration/time, 1time/ 2 hours. 4. MECHANICAL SHOCK HPC-200、S&A 250B Enable Crystal 50G(490m/s2) time=11 ms speed=3.4 m/s half sine wave oscillation 5. DROP TEST HARD BOARD.S&A250B 75cm High,3 times on hard board 6. HIGH&LOW TEMP STORAGE TEST(Static test) H-PTH-80CK & HM101-3ABN, High temperature: 125℃±2℃,1000hr;Low S&A 350B/250B temperature:-40℃±3℃,1000hrs 7. TEMP &HUM CYCLING TEST H-PTH-80CK CHAMBE,S&A 350B/250B 8. HIGH TEM. & HUM. STORAGE TEST H-PTH-80CK CHAMBE, S&A350B/250B 9.AGING TEST H-PTH-80CK CHAMBE, S&A350B/250 JIS C6701 MIL-STD-202F Method 213B MIL-STD883C, METHOD 1011.8 Temperature:-10℃±2℃~65℃±2 ℃,Humidity:93±3%,1 cycle need 24 hrs. 5cycles. MIL-STD-883E Method 1005.8 Temperature:85℃±2,Humidity:85+3,2%,Store 96 hrs JIS C6701 Temperature:85℃±2,Store 1000 hrs JIS C5023 Add: 12F, Bldg. 3C, TianAn Cloud Park Phase 1, Bantian, Longgang, Shenzhen, China 88352810 Tel: (86) 755 88352809 Fax: (86) 755 88353718 88352499 E-mail: sjk@q-crystal.com HTTP://www.q-crystal.com Page 5
SJK-7I08000MAB3550F5 价格&库存
很抱歉,暂时无法提供与“SJK-7I08000MAB3550F5”相匹配的价格&库存,您可以联系我们找货
