AO4407A
AO4407A
    JSMSEMI(杰盛微)
    SOP-8
    P沟道 VDS=30V VGS=±20V ID=13A P=2W
AO4407A 数据手册
AO4407A 30V P-Channel Fast Switching MOSFET  FEATURE  DESCRIPTION The 4407A is the P-Channel logic enhancement  -30V/-13A, RDS(ON) = 9 mΩ (typ.)@VGS=-10V mode power field effect transistor is produced using  -30V/-7.0A, RDS(ON)< 14.5mΩ (typ.)@VGS=-4.5V high cell density advanced trench technology..  Super high design for extremely low RDS(ON) This high density process is especially tailored to  Exceptional on-resistance and Maximum DC current capability minimize on-state resistance.  Full RoHS compliance PWM and gate charge for most of the synchronous  SOP8 package design CR MI JS This device is suitable for use as a load switch or in buck converter applications  APPLICATIONS  Buck Converter for MB/NB/UMPC/GA O  Newworking DC-DC Power System  Load Switch  Power Management in Note Book c du on c mi Se  PIN CONFIGURATION High Frequency Point-of-Load Synchronous r to www.jsmsemi.com 第1/8页 AO4407A 30V P-Channel Fast Switching MOSFET  ORDERING INFROMATION Package Code CR MI JS Part Number AO4407A 4407A Package Shipping SOP8 3000EA / T&R ※ Year Code : 0~9 ※ Week Code : A~Z(1-26); a~z(27~52) ※ G : Green Product. This product is RoHS compliant. O  ABSOLUTE MAXIMUM RATINGS ( TA = 25℃ Parameter VDSS Drain-Source Voltage VGSS Gate-Source Voltage ID c mi Se Symbol Unless otherwise noted ) Continuous Drain Current (TA=25℃) Pulsed Drain Current IS Continuous Source Current (Diode Conduction) PD Power Dissipation TJ Operation Junction Temperature Thermal Resistance Junction to Ambient V ±20 V -13 A -9.5 A -40 A -2.0 A TA=25℃ 2.0 TA=70℃ 1.5 W 150 ℃ -55~+150 ℃ r to RθJA -30 c du on IDM Storage Temperature Range Unit VGS=10V Continuous Drain Current (TA=70℃) TSTG Typical ℃/W 85 Note: Absolute maximum ratings are those values beyond which the device could be permanently damaged. Absolute maximum ratings are stress rating only and functional device operation is not implied  ELECTRICAL CHARACTERISTICS(TA=25℃ Unless otherwise noted) www.jsmsemi.com 第2/8页 AO4407A 30V P-Channel Fast Switching MOSFET Symbol Parameter Condition Min Typ Max Unit Static Parameters V(BR)DSS Drain-Source Breakdown Voltage VGS=0V, ID=-250uA VGS(th) Gate Threshold Voltage VDS=VGS, ID=-250uA IGSS Gate Leakage Current IDSS Zero Gate Voltage Drain Current -30 -1.0 V -1.4 -2.0 V VDS=0V, VGS=±25V ±100 nA VDS=-30V, VGS=0 -1 VDS=-30V, VGS=0 -5 TJ=55℃ VGS=-10V, ID=-10A 9 13 CR MI JS VGS=-4.5V, ID=-7.0A 14.5 17 IS=-2.3A, VGS=0V -0.75 -1.0 Total Gate Charge VDS=-15V 30 42 Qgs Gate-Source Charge VGS=-4.5V 10 14 Qgd Gate-Drain Charge ID=-10A 10.4 14.6 Ciss Input Capacitance VDS=-15V 2050 2730 Coss Output Capacitance VGS=0V 506 710 Crss Reverse Transfer Capacitance f=1MHz 420 590 VDS=-15V 9.3 19 ID=-10A 10.2 18 VGEN=-10V 117 232 RG=3.3Ω 24 46 RDS(ON) Drain-Source On-Resistance uA mΩ Source-Drain Diode VSD Diode Forward Voltage V Dynamic Parameters Tr Tf c du on Td(off) Turn-On Time c mi Se Td(on) O Qg Turn-Off Time nC pF nS Note: 1. Pulse test: pulse width
AO4407A
物料型号:AO4407A
器件简介: - 该 MOSFET 使用高密度先进沟槽技术生产,特别设计以最小化导通电阻。 - 适用于作为负载开关或在大多数同步降压转换器应用中的 PWM 和门电荷。
引脚分配: - 器件采用 SOP8 封装,从顶部视图来看,引脚配置为 D、D、D、D、Q、S。
参数特性: - 绝对最大额定值包括:漏源电压 -30V,栅源电压 +20V,连续漏电流 -13A(25°C时)等。 - 电气特性包括:漏源击穿电压 -30V,栅阈值电压 -1.4V,栅漏电流 ±100nA,零栅电压漏电流 -1uA 等。
功能详解: - 器件适用于负载开关、高频点对点同步降压转换器、移动设备和笔记本电脑的电源管理系统。
应用信息: - 适用于移动设备、笔记本电脑、UMPC、GA 新型网络设备的 DC-DC 电源系统。
封装信息: - SOP8 封装设计,符合 RoHS 标准。
AO4407A 价格&库存
很抱歉,暂时无法提供与“AO4407A”相匹配的价格&库存,您可以联系我们找货
AO4407A
  • 5+0.68000
  • 20+0.62000
  • 100+0.56000
  • 500+0.50000
  • 1000+0.47200
  • 2000+0.45200
