ESD5Z5.0T1G
ESD Protection Diode Array
»Features
250Watts peak pulse power (tp =8/20μs)
Unidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
IEC 61000-4-2 ±30kV contact ±30kVair
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 15A(8/20μs)
»Applications
»Mechanical Data
Microprocessor based equipment
SOD523 package
Personal Digital Assistants (PDA’s)
Molding compound flammability rating: UL 94V-0
Notebooks, Desktops, and Servers
Packaging: Tape and Reel
Portable Instrumentation
RoHS/WEEE Compliant
Pagers Peripherals
»Schematic & PIN Configuration
SOD-523
Revision 2018
www.born-tw.com
1/4
ESD5Z5.0T1G
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
250
Watts
Peak Pulse Current ( tp =8/20μs ) (note1)
Ipp
15
A
VESD
30
30
kV
Lead SolderingTemperature
TL
260(10seconds)
JunctionTemperature
TJ
-55 to + 150
StorageTemperature
Tstg
-55 to + 150
ESD per IEC 61000-4-2(Air)
ESD per IEC 61000-4-2(Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-OffVoltage
Reverse BreakdownVoltage
Conditions
Min
Typical
VRWM
IT=1mA
VBR
Max
Units
5.0
V
6.0
V
Reverse LeakageCurrent
IR
VRWM=5.0V,T=25℃
Clamping Voltage
VC
IPP=15A,tp=8/20μs
12
Junction Capacitance
Cj
VR = 0V, f =1MHz
80
0.5
uA
18
V
pF
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
I PP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ I PP
V RW M
IR
V BR
IT
I
IF
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RW M
VC VBR VRWM
IR VF
IT
Breakdown Voltage @ IT
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
ESD5Z5.0T1G
»Typical Characteristics
Figure 1: Peak Pulse Power vs. Pulse Time
Figure 2: Power Derating Curve
110
100
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(KW )
10
270w 8/20µs waveform
1
0.1
0.01
0.1
1
10
td – Pulse Duration - µs
100
Ipp
80
Percent
50
40
30
50
75
100
125
Ambient Temperature - TA (℃)
150
40
Clamping Voltage–VC (V)
90
e-1
50
40
td=Ipp/2
45
Waveform
Paramters
tr=8µs
td=20µs
100
30
70
Figure 4: Clamping Voltage vs.Ipp
110
60
80
1,000
Figure3: Pulse Waveform
70
90
Test
Waveform
Paramters
tr=8µs
td=20µs
35
30
25
10
5
10
Revision 2018
10
15
Time (µs)
30
4
6
8
10
12
14
16
Peak Pulse Current–IPP (A)
www.born-tw.com
3/4
ESD5Z5.0T1G
»Outline Drawing – SOD523
D
-X-YE
1
DIMENSIONS
2
SYMBOL
b 2x
0.08 (0.0032)
X
Y
A
C
HE
L
A
b
C
D
E
HE
L
MILLIMETER
MIN
0.50
0.25
0.07
1.10
0.70
1.50
0.15
MAX
0.70
0.35
0.20
1.30
0.90
1.70
0.25
INCHES
MIN
0.020
0.010
0.0028
0.043
0.028
0.059
0.006
MAX
0.028
0.014
0.0079
0.051
0.035
0.067
0.010
»Ordering information
Order code
ESD5Z5.0T1G
Revision 2018
Package
Base qty
Delivery mode
SOD523
5000
Tape and reel
www.born-tw.com
4/4
很抱歉,暂时无法提供与“ESD5Z5.0T1G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.08450
- 5000+0.06950
- 国内价格
- 20+0.15606
- 200+0.12399
- 600+0.10617
- 5000+0.08705
- 10000+0.07776
- 20000+0.07280
- 国内价格
- 20+0.14305
- 500+0.09732
- 2000+0.09586
- 5000+0.07979
