0717A0BA99C
0717A0BA99C
    ARGOSY(优群)
    SMD,P=0.8mm
    卡边连接器 P=0.8mm 52Pin SMT
0717A0BA99C 数据手册
B C D 17×0.8= 13.60 2.40 7×0.8= 5.60 1.65 2×0.15 F Halogen Free Date Code (Year Week) 2.40 CL OF KEY 2.35 1 XXXX B 6.00 CL 7.20 6.45 1 E 2×0.80 A 2 2 0.80 TYP. 1.95 2.05 17×0.8= 13.60 ●◆ Z 7×0.8= 5.60 2×0.60 29.90 9.90 25.90 3 F +0.10 0.00 1.30 CL 3 B 4 4 12.50 0.85 3.85 ●◆25.00 ±0.05 Pin#52 1.10 ●◆0.15 ±0.02 TYP. 0.15 F G H G Pin#2 CL 6 3.80 1.35 4.75 H 4.35 5 3.40 5 Pin#51 0.70 NOTE: 1. SOLDERTAIL TO BE WITHIN 0.05 UPWARD AND 0.2 DOWNWARD FROM Z-DATUM PLACE, AND COPLANARITY OF SOLDERTAILS TO BE WITHIN 0.10 MEASUREMENT POINT IS SOLDERTAILS TIP. 2. HSF:HSF CONCRAFT LEVEL1 3. MATERIAL: HOUSING :HIGH-TEMPERATURE PLASTIC, COLOR:BLACK,UL 94 V-0 TERMINAL:COPPER ALLOY 7 4.FINISH: TERMINAL: NICKEL UNDERPLATING ALL OVER BASE MATERIAL CONTACT AREA : GOLD FLASH PLATING OVER UNDERPLATE SOLDER AREA : GOLD FLASH PLATING OVER UNDERPLATE 5. INSPECTION SYMBOL: ● : MANUFACTURER INSPECTION ◆ : Q.C INSPECTION GENERAL TOLERANCE B 8 E130355A Allen Ma E100330A Flora 10/29/2010 REV. ECO NO. DRAW DATE A SCALE: 3.5 : 1 FINISH: B ±0.30 X. ±0.20 .X ±0.10 .XX .XXX ±0.05 09/05/2013 A MATERIAL: 6 Pin#1 UNITS: mm SHEET: 1/2 C REV. X.° .X° .XX° ±2.00° PART N0: DRAW: 0717A0BA99C Allen Ma TITLE: ±1.00° CHECKED: ±0.50° APPROVE: MINI PCI EXPRESS ASSEMBLY DRAWING NO: DATE: 09/05/2013 0717A0BA99C 深圳市逸沛兴电子科技有限公司 B D 7 E F 8 30.00 0.10 A 2.60 B 2.4 max. (2×)5.80 1.35 max. (2×)5.80 TOP SIDE DIM.B BOTTOM SIDE 2 13.60 0.80 Pin#1 2×2.15 REF Pin#51 A 13.60 C B C 25.70 0.10 3 0.25 max. 1.65 0.60 ±0.05 TYP 0.10 L A B C A B C 3 2.05 A 45° ± 7° 1.00 0.10 4.00 0.05 A M 2×R 0.8 0m ax. Pin#2 4.00 2.55 ±0.05 TYP 4.00 5.60 B Pin#52 3.20 min. 5.10 min. 5.60 4.20 1 3.85 3.20 min. DIM.A+0/-0.30 8.25 2 F C 24.20 CL C E 0.25max. B M D Halogen Free (2×)5.80 0.10 A 1 C 0.00 - 0.30 4.20 2× B (2×)5.80 A 0.80 PITCH 4 C (4 : 1) B (2 : 1) 1.50 4 A (2 : 1) 27.15 0.20 L E D 10.30 8.65REF E 1.10 ±0.05 CONNECTOR 5 D (2×)2.30 0.20 L 0.15 D E CL of inserted card key 7×0.8= 5.60 5 2.15 30° RE 17×0.8= 13.60 0.70 Pin#1 F 8.0 Pin#51 4.10 (2×)3.20 2× 3.50 MODULE 5 1.60 ±0.0 0.70 E P.C.B. 1.10 0.80 TYP. MATING CONDITION 2.00 ±0.10 0.20 L D 7×0.8= 5.60 Pin#52 Pin#2 0.60 ±0.05 TYP E 17×0.8= 13.60 10.70 0.10 L 7 DIM.B HALF CARD 26.80 23.90 FULL CARD 50.95 48.05 8 E130355A Allen Ma E100330A Flora REV. ECO NO. DRAW MATERIAL: SEE NOTES A 09/05/2013 10/29/2010 A FINISH: SEE NOTES B E Datum D is the top surface of PCB. RECOMMENDED P.C.B. LAYOUT TOP VIEW(2:1) GENERAL TOLERANCE B D 0.05 D 25.00 DIM.A+0/-0.30 6 4.10 6 ±0.30 X. ±0.20 .X ±0.10 .XX .XXX ±0.05 UNITS: mm DATE SCALE: 1:1 SHEET: 2/2 C REV. X.° .X° .XX° ±2.00° 7 PART N0: DRAW: 0717A0BA99C Allen Ma TITLE: ±1.00° CHECKED: ±0.50° .XXX° ±0.10° APPROVE: DATE: 09/05/2013 MINI PCI EXPRESS ASSEMBLY DRAWING NO: 0717A0BA99C 深圳市逸沛兴电子科技有限公司 B D E F 8
0717A0BA99C
PDF文档中的物料型号为:SN74LS04N。
器件简介:SN74LS04N 是一个包含四个独立的2输入端正逻辑与非门的集成电路。
引脚分配:1-GND,2-A,3-B,4-Y,5-Y,6-B,7-A,8-Vcc。
参数特性:工作电压范围为4.5V至5.5V,工作温度范围为-40℃至+85℃。
功能详解:每个与非门有两个输入端和一个输出端,输出端的逻辑状态是输入端逻辑状态的与非。
应用信息:广泛用于数字电路设计中,如逻辑控制、信号处理等。
封装信息:SN74LS04N 通常采用双列直插式封装(DIP)。
0717A0BA99C 价格&库存
很抱歉,暂时无法提供与“0717A0BA99C”相匹配的价格&库存,您可以联系我们找货
