BSD3C031L2
ESD Protection Diode
»Features
230Watts peak pulse power (tp = 8/20μs)
Tiny SOD323 package
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=1.4pF typ.)
Protection one data/power line
IEC 61000-4-2 ±30V contact ±30kV air
1.2/50μs 12ohm 2kV (GbE PHY side)
10/700μs 40ohm 4kV (GbE PHY side )
»Applications
»Mechanical Data
10/100/1000Ethernet
SOD323 package
Intergated Magnetics/RJ45Connectors
Molding compound flammability rating: UL 94V-0
LAN/WAN Equipment
Packaging: Tape and Reel
Notebooks, Desktops, and Servers
RoHS/WEEE Compliant
Portable Instrumentation
»Schematic & PINConfiguration
SOD-323
Revision 2018
www.born-tw.com
1/5
BSD3C031L2
»Absolute MaximumRating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
230
Watts
Peak Pulse Current ( tp =8/20μs)(note1)
Ipp
14
A
VESD
30
30
kV
Lead SolderingTemperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2(Contact)
»ElectricalCharacteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
5.0
Max
Units
3.3
V
7.8
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=3.3V,T=25℃
0.2
uA
Clamping Voltage
VC
IPP=7A,tp=8/20V
13
V
Clamping Voltage
VC
IPP=14A,tp=8/20μs
17
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
1.6
pF
1.4
V
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
I PP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ I PP
V RWM
IR
VT
IT
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
IPP
VT VC VBR VRWM IT
IR
Trigger Voltage @ I T
ITIR VRWM VBR VC VT
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/5
BSD3C031L2
»Typical Characteristics
Figure 2: Power Derating Curve
10k
110
Percent of Rated Power for Ipp
Ppp – Peak Pulse Power - Ppp(W)
Figure 1: Peak Pulse Power vs. Pulse Time
230w 8/20μs waveform
1000
100
10
0.1
1
10
100
100
90
80
70
60
50
40
30
td – Pulse Duration - µs
Figure3: Pulse Waveform
Waveform
Paramters
tr=8µs
td=20µs
90
80
Ipp
100
125
150
Clamping Voltage–VC (V)
100
Percent
75
Figure 4: Clamping Voltage vs.Ipp
110
70
e-1
60
50
Ambient Temperature - TA (℃)
50
40
30
td=Ipp/2
Test
Waveform
Paramters
tr=8µs
td=20µs
10
5
10
10
15
30
Time (µs)
Revision 2018
5
10
15
Peak Pulse Current–IPP (A)
www.born-tw.com
3/5
BSD3C031L2
»Lightning Surge Test Results for Gigabit Ethernet
During the metallic (line-to-line) surge test, the line being stressed is tied to the surge generator with the remaining lines
tied together and connected to the generator ground. Current will flow through the line transformer transferring energy to
the PHY side of the transformer. Figure 5 shows the test set-up for measuring the clamping voltage of the device. This
set up is designed to test the surge in an actual gigabit Ethernet (GbE) circuit. Two 4.7 Ohm resistors is usedfor
decoupling. The clamping voltage of the BSD3C031L 2 for a metallic mode 4KV (10/ 700μs) surge.The clamping
voltage, measured at less than 13 volts, provides sufficient clamping margin to minimize electrical stress and is well
below the failure voltage range of typical GbE PHY chips .
Ipp
R L =4.7 Ω
Vin
Vc
R L =4.7 Ω
Gigabit
Ethernet
Phy
Figure5-Clamping VoltageTestSet-Up
RJ-45
BSD3C031L2
Gigabit
Ethernet
PHY
Figure 6 - GbE Protection to Lightning, ESD, and CDE
Revision 2018
www.born-tw.com
4/5
BSD3C031L2
»Outline Drawing – SOD323
C
A
DIMENSIONS
SYMBOL
E
B
1
2
MILLIMETER
A
MIN
1.600
MAX
1.800
MIN
0.063
B
0.250
0.350
0.010
0.014
C
2.500
2.700
0.098
0.106
D
D
H
L
L1
1.000
MAX
0.071
0.039
E
1.200
1.400
0.047
0.055
F
0.080
0.150
0.003
0.006
L
F
INCHES
0.475 REF
0.019REF
L1
0.250
0.400
0.010
0.016
H
0.000
0.100
0.000
0.004
Marking
1
Ordering information
Ordercode
BSD3C031L 2
Revision 2018
Package
SOD323
3LH
2
Base qty
3k
www.born-tw.com
Deliverymode
Tape andreel
5/5
很抱歉,暂时无法提供与“BSD3C031L2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24640
- 3000+0.21780
- 国内价格
- 10+0.45100
- 100+0.38010
- 300+0.34520
- 3000+0.23330
- 6000+0.21240
- 9000+0.20190
- 国内价格
- 10+0.41620
- 100+0.35155
- 600+0.31928
- 1200+0.31449
- 3000+0.21592
- 国内价格
- 10+0.45404
- 100+0.38351
- 300+0.34830
- 3000+0.23555
- 6000+0.21438
- 9000+0.20380
