SRV05-4-N
ESD Protection Diode Array
»Features
45Watts peak pulse power (tp = 8/20μs)
SOT23-6 package
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=0.3pF typ. IO to IO)
Protection one data/power line to:
IEC 61000-4-2 ±12kV contact ±15kV air
IEC 61000-4-4 (EFT) 40A(5/50ns)
IEC 61000-4-5 (Lightning) 3.5A(8/20μs)
»Applications
»Mechanical Data
Ethernet
SOT23-6 package
Digital Visual Interface (DVI)
Molding compound flammability rating: UL 94V-0
USB2.0
Packaging: Tape and Reel
Notebook and PC Computers
RoHS/WEEE Compliant
»Schematic & PIN Configuration
Pin 5
Pin 1
Pin 4
Pin 3
Pin 6
I/O 1
6 I/O
GND
Vcc
I/O 3
4 I/O
GND
Revision 2018
www.born-tw.com
1/4
SRV05-4-N
»Absolute Maximum Rating
Rating
Symbol
Value
Units
Peak Pulse Power ( tp =8/20μs)
PPP
45
Watts
Peak Pulse Current ( tp =8/20μs )(note1)
Ipp
3.5
A
VESD
15
12
kV
Lead SolderingTemperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
StorageTemperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2(Contact)
»Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Conditions
Min
Typical
Max
Units
5.0
V
6.8
8.5
V
50
500
nA
3.5
A
V
VRWM
VBR
IT=1mA
Reverse LeakageCurrent
IR
VRWM=5V,T=25℃
Peak Pulse Current
IPP
tp =8/20μs
Clamping Voltage
VC
IPP=3.5A,tp=8/20μs
10
13
VR = 0V, f = 1MHz
IO to IO
0.2
0.25
VR = 0V, f =1MHz
IO to GND
0.36
0.5
Reverse BreakdownVoltage
Junction Capacitance
Cj
6
pF
»Electrical Parameters (TA = 25°C unless otherwisenoted)
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
V RWM
IR
V BR
IT
I
IPP
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @ V RWM
VC VBR VRWM
Breakdown Voltage @ IT
IT
IR
IR
IT
VRWM VBR VC
V
Test Current
IPP
Note:. 8/20μs pulsewaveform.
Revision 2018
www.born-tw.com
2/4
SRV05-4-N
»Typical Characteristic Curves
Fig.1 Peak Pulse Power RatingCurve
Fig.2 Pulse DeratingCurve
110
Peak Pulse Power –PPP(KW)
10
1
45w 8/20μs waveform
0.1
0.01
0.1
1
10
100
Pulse Duration tp (μs)
1000
Fig.3 PulseWaveform-8/20μs
120
100%IPP , 8μS
150
100%
90%
30ns
80
50%IPP, 20μS
e-t
60
Percent of IPP
Percent of IPP
25
50
75
100
1
Ambient Temperature—TA(℃)
Fig.4 PulseWaveform-ESD(IEC61000-4-2)
100
40
80
r
o
) PP
(P 60
r
e
w 40
P
o
d 20
te
R
a 0
60ns
10%
10
15
30
tr 0.7 to 1ns
Time (μs)
60
Time (ns)
Fig.5 Eye Diagram - HDMI mask at 3.4Gbpsper
channel
Fig.6 Insertion Loss S21 - I/O toGND
2
2.5GHz @ -1dB
Horizontal: 50 ps/div
Vertical: 200 mV/div
Insertion Loss (dB)
-4
4GHz @ -3dB
-6
-8
-10
100k
1M
10M
100M
1G
10G
Frequency (Hz)
Revision 2018
www.born-tw.com
3/4
SRV05-4-N
»Outline Drawing – SOT23-6
DIMENSIONS
PACKAGE OUTLINE
INCHES
MIN
MAX
MILLIMETER
MIN
MAX
A
0.041
0.049
1.050
1.250
A1
0.000
0.004
0.000
0.100
A2
0.041
0.045
1.050
1.150
D
0.111
0.119
2.820
3.020
E
0.059
0.067
1.500
1.700
E1
0.104
0.116
2.650
2.950
b
0.012
0.020
0.300
0.500
SYMBOL
E
E1
b
SEE DETAIL
A
e
e
e1
D
0.2
A
0.950(BSC)
e1
0.071
0.079
1.800
2.000
L
0.012
0.024
0.300
0.600
θ
o
8
o
o
8
o
θ
A2
0.037(BSC)
c
L
A1
1.0
0.039
1.4 3.6
0.055 0.141
1.9
0.074
0.7
0.028
0.95
0.037
Notes
1.
This land pattern is for reference purposes only consult your manufacturing group to ensure your company's manufacturing guidelines are met.
Reference ipc-sm-782a..
»Marking
V5L
»Ordering information
Order code
SRV05-4-N
Revision 2018
Package
SOT23-6
Base qty
3k
www.born-tw.com
Delivery mode
Tape and reel
4/4
很抱歉,暂时无法提供与“SRV05-4-N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.33550
- 200+0.21670
- 1500+0.18920
- 3000+0.16610
- 国内价格
- 10+0.38880
- 100+0.31320
- 300+0.28080
- 3000+0.20850
- 6000+0.18690
- 9000+0.17610
- 国内价格
- 10+0.22959
- 50+0.21279
- 200+0.19879
- 600+0.18479
- 1500+0.17360
- 3000+0.16660
