TOM0530-1R0M
TOM0530-1R0M
    TOMIISHI(富石)
    SMD,5.4x5.2mm
    功率电感 1µH ±20% 14mΩ IND_5.4X5.2MM_SM
TOM0530-1R0M 数据手册
Molded SMD Power Inductor - TOM Series Operating Temp. : -55℃ ~ +125℃ (Including self-heating) TOM Series FEATURES l Halogen Free ,ROHS compliance. l High rated current. l Low loss realized with low DCR. l Low core loss. l ℃ maximum total temperature operation. l Ultra low buzz noise due to molding construction. l High performance (Isat) realized by metal dust core. APPLICATIONS l Laptops and PCs l Base stations l DC/DC converter l SSD modules l Battery powered devices l Switch and servers PRODUCT IDENTIFICATION . Series Name : Molded SMD Power Inductor TOM R M . Size Code : Dimensions (unit:mm) . Nominal Inductance Value : R . Inductance Tolerance : N=± = . μH, R = . μH, %, M=± = μH % DIMENSIONS MARKING B E C A D Series TOM A . ± . B . ± . C . ± . D . E ± . . ± . RECOMMEND LAND PATTERN a c b 深圳市艾本特科技有限公司 SHENZHEN IBT TECHNOLOGY CO., LTD Series TOM a typ b typ c typ . . . TEL : +86-755-2103-8425 Specifications subject to change without notice. Please check our website for latest TOMIISHI information. FAX : +86-755-2103-9491 Revised / / E-mail : ibt@tomiishi.com WWW.TOMIISHI.COM Molded SMD Power Inductor - TOM Series Operating Temp. : -55℃ ~ +125℃ (Including self-heating) APPLICATIONS Inductance Part NO. ▪ TOM Test Condition L (μH) Tolerance DCR (mΩ) Isat (A) Irms (A) (%) Max. Typ. Typ. Series TOM -R M . kHz/ V ± . . . TOM -R M . kHz/ V ± . . . TOM -R M . kHz/ V ± . . . TOM -R M . kHz/ V ± . . . TOM -R M . kHz/ V ± . . . TOM - R M . kHz/ V ± . . . TOM - R M . kHz/ V ± . . . TOM - R M . kHz/ V ± . . . TOM - R M . kHz/ V ± . . . TOM - R M . kHz/ V ± . . . TOM - R M . kHz/ V ± . . . TOM - R M . kHz/ V ± . . . TOM - kHz/ V ± . . M Notes . All test data is referenced to °C ambient . Operating temperature range - . Irms (A):DC current (A) that will cause an approximate ΔT of . Isat(A):DC current (A) that will cause L to drop approximately . The part temperature (ambient + temp rise) should not exceed °C to + °C °C(reference ambient temperature is °C) % °C under worst case operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. 深圳市艾本特科技有限公司 SHENZHEN IBT TECHNOLOGY CO., LTD TEL : +86-755-2103-8425 Specifications subject to change without notice. Please check our website for latest TOMIISHI information. FAX : +86-755-2103-9491 Revised / / E-mail : ibt@tomiishi.com WWW.TOMIISHI.COM Molded SMD Power Inductor - TOM Series Operating Temp. : -55℃ ~ +125℃ (Including self-heating) MECHANICAL RELIABILITY TEST ITEM SPECIFICATION TEST DETAILS 1. Acceleration : 100G Mechanical shock 1. No case deformation or change in 2. Pulse time : 6ms apperarance 3. Direction : ±X ±Y ±Z 2. △L/Lo≦±10% 4. 3 times in each positive and negative direction of 3 mutual perpendicular directions . Reflow : times Mechanical vibration . No case deformation or change in apperarance . △L/Lo≦± . Frequency : . Amplitude : . % HZ〜 HZ, Min/Cycles mm . Directions : X,Y,Z . Time : . No case deformation or change in Solderability HZ〜 apperarance cycle / direction . Preheat: ℃± ℃ , S± S . Tin : lead-free. . New solder coverage More than % . Temperature : ℃± ℃,flux . S± . S. ENDURANCE RELIABILITY TEST ITEM SPECIFICATION TEST DETAILS . First - ℃ for minutes,last Go through ℃ for minutes as cycles . Max transfer time is minutes . Measured at room temperature after placing for Inductance change : Thermal Shock Within ± NO. Temperature - % Without distinct damage in appearance ± ℃(Themostat No. ) Standard atmospheric Standard atmospheric Resistance Low temperature storage High temperature storage Inductance change : Within ± % Without distinct damage in appearance Inductance change : Within ± % Without distinct damage in appearance Inductance change : Within ± % Without distinct damage in appearance 深圳市艾本特科技有限公司 SHENZHEN IBT TECHNOLOGY CO., LTD ± hours Duration min. Within minutes No. →No. ± ℃(Themostat No. ) Humidity cycle. min. Within minutes No. →No. 1. Reflow 2 times 2. 85℃,85%RH,1000 hours 3. Measured at room temperature after placing for 24±2 hours . Temperature : . Time : ± ℃ hours . Measured at room temperature after placing for . Temperature : + . Time : ± ℃ hours . Measured at room temperature after placing for TEL : +86-755-2103-8425 Specifications subject to change without notice. Please check our website for latest TOMIISHI information. ± hours FAX : +86-755-2103-9491 Revised / / ± hours E-mail : ibt@tomiishi.com WWW.TOMIISHI.COM Molded SMD Power Inductor - TOM Series Operating Temp. : -55℃ ~ +125℃ (Including self-heating) PACKAGING INFORMATION REEL DIMENSION (mm) TOMIISHI Thickness . 330 Max Tape width TAPING DIMENSIONS (mm) Type Series TOM0530 Tape dimensions (mm) W P P0 P2 D0 D1 T A0 B0 K0 E F 12± 8± 4.0± 2.0± 1.5± 1.5± 0.35± 5.4± 5.9± 3.3± 1.75± 5.5± 0.3 0.1 0.1 0.1 0.1 0.1 0.05 0.1 0.1 0.1 0.1 0.1 PACKAGING QUANTITY (Standard) Type Reel TOM pcs / Reel Inner Box Carton Box Reel / Box ( pcs) Middle boxes ( , pcs) PEEL FORCE OF TOP COVER TAPE The peel speed shall be about mm/minute The peel force of top cover tape shall be between . to . N 深圳市艾本特科技有限公司 SHENZHEN IBT TECHNOLOGY CO., LTD TEL : +86-755-2103-8425 Specifications subject to change without notice. Please check our website for latest TOMIISHI information. FAX : +86-755-2103-9491 Revised / / E-mail : ibt@tomiishi.com WWW.TOMIISHI.COM
TOM0530-1R0M 价格&库存
很抱歉,暂时无法提供与“TOM0530-1R0M”相匹配的价格&库存,您可以联系我们找货
TOM0530-1R0M
  • 5+0.57750
  • 20+0.52500
  • 100+0.47250
  • 500+0.42000
  • 1000+0.39550
  • 2000+0.37800
