PESD3V3L1BA-N
PESD3V3L1BA-N
    BORN(伯恩)
    SOD-323
    ESD抑制器/TVS二极管 双向 3.3V 20A 480W SOD-323
PESD3V3L1BA-N 数据手册
PESD3V3L1BA-N ESD Protection Diode »Features ■ 480Watts peak pulse power (tp =8/20μs) ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 20A(8/20μs) »Applications »Mechanical Data ■ Microprocessor based equipment ■ SOD323 package ■ Personal Digital Assistants (PDA’s) ■ Molding compound flammability rating: UL94V-0 ■ Notebooks, Desktops, and Servers ■ Packaging: Tape and Reel ■ Portable Instrumentation ■ RoHS/WEEE Compliant ■ Pagers Peripherals »Schematic & PIN Configuration SOD-323 Revision 2018 www.born-tw.com 1/4 PESD3V3L1BA-N »Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs) PPP 480 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 20 A VESD 30 30 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 150 ℃ Storage Temperature Tstg -55 to + 150 ℃ ESD per IEC 61000-4-2(Air) ESD per IEC 61000-4-2(Contact) »Electrical Characteristics Parameter Symbol Reverse Stand-OffVoltage Conditions Min Typical VRWM Max Units 3.3 V VBR IT=1mA Reverse LeakageCurrent IR VRWM=3.0V,T=25℃ 1 uA Clamping Voltage VC IPP=20A,tp=8/20μs 24 V Junction Capacitance Cj VR = 0V, f =1MHz Reverse BreakdownVoltage 4.0 V 100 pF »Electrical Parameters (TA = 25°C unless otherwisenoted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRW M IR VBR IT I IPP Working Peak Reverse Voltage Maximum Reverse Leakage Current @ V RWM VC V BR V RWM IT IR I IT R VRWM V BR VC V Breakdown Voltage @ IT Test Current IPP Note:. 8/20μs pulsewaveform. Revision 2018 www.born-tw.com 3/4 PESD3V3L1BA-N »Typical Characteristics Figure 2: Power Derating Curve 10k 110 100 Percent of Rated Power for Ipp P pp – Peak Pulse Power - Ppp(W) Figure 1: Peak Pulse Power vs. Pulse Time 480w 8/20μs waveform 1000 100 10 0.1 1 10 100 90 80 70 60 50 40 30 20 10 0 1,000 td – Pulse Duration - µs Figure3: Pulse Waveform 90 Percent Ipp 80 e-1 50 40 td=Ipp/2 20 100 0 30 25 Test Waveform Paramters tr=8µs td=20µs 20 15 10 0 5 Revision 2018 10 15 150 35 5 10 0 125 40 Clamping Voltage–VC (V) 100 30 75 45 Waveform Paramters tr=8µs td=20µs 60 50 Ambient Temperature - TA (℃) Figure 4: Clamping Voltage vs.Ipp 110 70 25 0 Time (µs) 20 25 30 www.born-tw.com 5 10 15 20 25 30 Peak Pulse Current–IPP (A) 3/4 PESD3V3L1BA-N »Outline Drawing – SOD323 C A DIMENSIONS SYMBOL E B 1 2 MILLIMETER A MIN 1.600 MAX 1.800 MIN 0.063 MAX 0.071 B 0.250 0.350 0.010 0.014 C 2.500 2.700 0.098 D D H L L1 1.000 0.106 0.039 E 1.200 1.400 0.047 0.055 F 0.080 0.150 0.003 0.006 L F INCHES 0.475 REF 0.019REF L1 0.250 0.400 0.010 0.016 H 0.000 0.100 0.000 0.004 »Marking 1 03B 2 »Ordering information Order code PESD3V3L1BA-N Revision 2018 Package Base qty Delivery mode SOD323 3000 Tape and reel www.born-tw.com 4/4
PESD3V3L1BA-N 价格&库存
很抱歉,暂时无法提供与“PESD3V3L1BA-N”相匹配的价格&库存,您可以联系我们找货
PESD3V3L1BA-N
  • 1+0.17990
  • 100+0.17360
库存:293
PESD3V3L1BA-N
  • 10+0.38049
  • 100+0.31698
  • 300+0.28426
  • 3000+0.18890
  • 6000+0.17950
  • 9000+0.17313
库存:193175
PESD3V3L1BA-N
  • 1+0.34760
  • 200+0.22550
  • 1500+0.19470
  • 3000+0.17270
库存:23908
PESD3V3L1BA-N
  • 20+0.21351
  • 200+0.19991
  • 600+0.18631
  • 3000+0.17271
库存:21089
PESD3V3L1BA-N
  • 10+0.37710
  • 100+0.31410
  • 300+0.28150
  • 3000+0.18710
  • 6000+0.17770
  • 9000+0.17140
库存:38282
