AGM405A
● General Description
Product Summary
The AGM405A combines advanced trench MOSFET
technology with a low resistance package to provide
extremely low RDS(ON) .
BVDSS
RDSON
ID
40V
5.1mΩ
72A
This device is ideal for load switch and battery
protection applications.
PDFN5*6 Pin Configuration
● Features
■ Advance
high cell density Trench technology
■ Low
RDS(ON) to minimize conductive loss
■ Low Gate Charge for fast switching
■ Low
Thermal resistance
■ 100%
Avalanche tested
DVDS tested
■ 100%
● Application
■ MB/VGA Vcore
■ SMPS
■ POL
2nd Synchronous Rectifier
application
■ BLDC
Motor driver
Package Marking and Ordering Information
Device Marking
Device
Device Package
Reel Size
Tape width
Quantity
AGM405A
AGM405A
PDFN5*6
330mm
12mm
3000
Table 1.
Absolute Maximum Ratings (TA=25℃)
Parameter
Symbol
Value
Unit
VDS
Drain-Source Voltage (VGS=0V)
40
V
VGS
Gate-Source Voltage (VDS=0V)
±20
V
Drain Current-Continuous(Tc=25℃) (Note 1)
72
A
Drain Current-Continuous(Tc=100℃)
52
A
Drain Current-Pulsed (Note 2)
288
A
Maximum Power Dissipation(Tc=25℃)
27
w
Maximum Power Dissipation(Tc=100℃)
11
w
Avalanche energy (Note 3)
196
mJ
-55 To 150
Typ
Max
Unit
ID
IDM (pluse)
PD
EAS
TJ,TSTG
Table 2.
Operating Junction and Storage Temperature Range
Thermal Characteristic
Symbol
Parameter
RθJA
Thermal Resistance Junction-ambient (Steady State)1
℃/W
RθJC
Thermal Resistance Junction-Case1
4.5
℃/W
www.agm-mos.com
1
VER2.72
AGM405A
Table 3.
Electrical Characteristics (TJ=25℃unless otherwise noted)
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
On/Off States
BVDSS
Drain-Source Breakdown Voltage
VGS=0V ID=250μA
40
V
IDSS
Zero Gate Voltage Drain Current
VDS=40V,VGS=0V
1
μA
IGSS
Gate-Body Leakage Current
VGS=±20V,VDS=0V
±100
nA
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=250μA
1.2
1.6
2.2
V
gFS
Forward Transconductance
VDS=5V,ID=10A
S
RDS(on)
Drain-Source On-State Resistance
VGS=10V, ID=20A
5.1
6.8
mΩ
VGS=4.5V, ID=10A
7.0
10
mΩ
1820
pF
190
pF
152
pF
2.2
Ω
6.9
nS
1.7
nS
30
nS
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
VDS=20V,VGS=0V
,F=1MHZ
VGS=0V,
VDS=0V,f=1.0MHz
Switching Times
td(on)
Turn-on Delay Time
tr
Turn-on Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
15
nS
Qg
Total Gate Charge
29
nC
Qgs
Gate-Source Charge
4.5
nC
Qgd
Gate-Drain Charge
6.4
nC
72
A
VGS=10V,VDS=15V,
RL=0.75Ω,RGEN=3.3Ω
VGS=10V, VDS=20V,
ID=20A
Source-Drain Diode Characteristics
ISD
Source-Drain Current(Body Diode)
VSD
Forward on Voltage
VGS=0V,IS=20A
1.2
V
trr
Reverse Recovery Time
IF=20A , dI/dt=100A/µs ,
ns
Qrr
Reverse Recovery Charge
TJ=25℃
nc
Notes 1.The maximum current rating is package limited.
Notes 2.Repetitive Rating: Pulse width limited by maximum junction temperature
Notes 3.EAS condition: TJ=25℃,VDD=25V,Vgs=10V,ID=28A,L=0.5mH,RG=25ohm
www.agm-mos.com
2
VER2.72
AGM405A
Typical Performance Characteristics
Figure 2: Typical Transfer Characteristics
Figure1: Output Characteristics
150
ID (A)
120
10V 5V
100
VDS=5V
4V
80
6V
3.5V
90
25℃
60
40
60
125℃
VGS=3V
30
ID (A)
0.5
1.0
1.5
2.0
VDS(V)
2.5 3.0 3.5 4.0 4.5 5.0
VGS(V)
2.5
3
3.5
4
4.5
Figure 4: Body Diode Characteristics
Figure 3:On-resistance vs. Drain Current
RDS(ON) (mΩ)
IS(A)
1.0E+02
15
1.0E+01
12.5
VGS=4.5V
125℃
1.0E+00
10
1.0E-01
25℃
7.5
1.0E-02
VGS=10V
5.0
1.0E-03
2.5
1.0E-04
ID(A)
40
50
1.0E-05
0.0
60
Figure 5: Gate Charge Characteristics
10
8
0.2
0.4
VSD(V)
0.6
0.8
1.0
1.2
Figure 6: Capacitance Characteristics
VGS(V)
C(pF)
VDS=20V
ID=30A
10000
6
1000
Ciss
Coss
4
100
Crss
2
Qg(nC)
www.agm-mos.com
10
15
10
3
VDS(V)
10
40
VER2.72
AGM405A
Figure 7: Normalized Breakdown Voltage vs.
Junction Temperature
Figure 8: Normalized on Resistance vs.
V BR(DSS)(V)
1.3
R DS (on)(mΩ)
2.5
1.2
2.0
1.1
1.5
1.0
1.0
0.9
-50
Tj (℃ )
50
100
150
0.5
-100
200
Figure 9: Maximum Safe Operating Area
100
150
200
Figure 10: Maximum Continuous Drain Current
vs. Case Temperature
ID (A )
1000
Tj (℃ )
-50
80
Limited by R DS(on)
ID (A )
70
60
10μs
100μs
100
50
1ms
40
10
10ms
30
100ms
DC
T A=25 ℃
Single pulse
1
10
V DS (V)
0.1
0.1
1
10
50
Tc (℃ )
75
100
125
150
175
Figure.11: Maximum Effective
Transient Thermal Impedance, Junction-to-Case
(TO-251S,TO-252)
101
Zth J-C (℃ /W)
10-1
D=0.5
D=0.3
D=0.1
D=0.05
D=0.02
D=0.01
Single pulse
10-2
10-3 -6
10
10-5
www.agm-mos.com
10-4
T P (s)
10-3
PDM
100
t1
t2
Notes:
1.Duty factor D=t1/t2
2.Peak T J=P DM *ZthJC +T C
10-2
10 -1
100
4
VER2.72
AGM405A
Figure1:Gate Charge Test Circuit & Waveform
Figure 2: Resistive Switching Test Circuit & Waveforms
Figure 3:Unclamped Inductive Switching Test Circuit & Waveforms
www.agm-mos.com
5
VER2.72
AGM405A
H
D2
D
L1
●Dimensions(PDFN5*6)
MILLIMETER
SYMBOL
A
1.100
0.254 REF.
L
k
0~0.05
D
4.824
4.900
4.976
D1
3.910
4.010
4.110
D2
4.924
5.000
5.076
E
5.924
6.000
6.076
E1
3.375
3.475
3.575
E2
5.674
5.750
5.826
b
0.350
0.400
0.450
e
e
θ
1.270 TYP.
L
0.534
0.610
0.686
L1
0.424
0.500
0.576
L2
A2
d
MAX
1.000
A2
E2
E
b
Typ.
0.900
A1
E1
L2
D1
MIN
1.800 REF.
k
1.190
1.290
1.390
H
0.549
0.625
0.701
θ
8°
10°
12°
Φ
1.100
1.200
1.300
8
7
6
5
5
6
7
8
H
L2
0.100
A
A1
d
P
D1
1.200
E2
E
E1
K
N
Millimeters
Symbol
MIN.
NOM.
MAX.
A
0.90
1.05
1.20
B
0.35
0.40
0.50
C
0.20
0.25
0.35
D
4.90
5.05
5.20
D1
3.72
3.82
3.92
E
6.00
6.15
6.30
E1
5.60
5.75
5.90
E2
3.47
3.57
3.67
e
1
L1
2
e
3
4
4
3
b
2
1
L
1.27 BSC.
H
0.48
0.58
0.68
K
1.17
1.27
1.37
L
0.64
0.74
0.84
L1/L2
θ
8°
M
θ
M
0.20 REF.
N
A
10°
12°
0.08 REF.
O
0.25 REF.
P
1.28 REF.
C
D
www.agm-mos.com
6
VER2.72
AGM405A
PDFN5*6
Marking Instructions:
Model1:
Model2:
www.agm-mos.com
7
VER2.72
AGM405A
Disclaimer:
The information provided in this document is believed to be accurate and reliable.
however,Shenzhen Core Control Electronics Technology Co., Ltd. does not assume
any responsibility for the following consequences.Do not consider the use of such
information or use beyond its scope.
The information mentioned in this document may be changed at any time without
notice.
The products and information provided in this document do not infringe patents.
Shenzhen Core Control Electronics Technology Co., Ltd. assumes no responsibility
for any infringement of any other rights of third parties.The result of using such
products and information.
This document is the fifth version issued on March 10th, 2024. This document
replaces all previously provided information.
It is a registered trademark of Shenzhen Core Control Electronics
Copyright © 2017 Shenzhen Core Control Electronics Technology Co., Ltd. all rights
reserved.
www.agm-mos.com
8
VER2.72
很抱歉,暂时无法提供与“AGM405A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.38726
- 50+1.10181
- 150+0.97950
- 500+0.82687
- 3000+0.72493
- 6000+0.68410
