Liown Semiconductor Co.,Ltd.
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
SMBJ Series Datasheet
Description
The SMBJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced
by lightning and other transient voltage events. For surface mounted applications in order to optimize board space.
Features
Halogen free and RoHS compliant
Low profile package
Built-in strain relief Design
Low inductance
Excellent clamping capability
600W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time: typically less than 1.0ps from 0V to VB min
Typical IR less than 1μA above 10V devices
Peak 260℃ high temperature Reflow Soldering withstanding
Meet MSL level1, per J-STD-020
IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)
Unit Weight: 0.10g/PCS
Applications
TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in
telecom, computer, Industrial and consumer electronic applications.
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 600
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
5.0
Watts
VF
3.5/5.0
V
IFSM
100
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
℃/W
Typical thermal resistance junction to ambient
RθJA
100
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Maximum Instantaneous Forward Voltage at 50A for
Unidirectional Only
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Ranges.
Notes: 1. Non-repetitive current pulse, per Fig.3 and Derating above TA=25℃ per Fig.2.
2. Each terminal is surface Mounted on the 5.0mm×5.0mm (0.03mm thick) copper pads.
3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum.
4. VF < 3.5V for single die parts and VF< 5.0V for stacked-die parts.
www.liownsemi.com
掌握芯技术 Core Technology
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Dimensions (SMB/DO-214AA)
Electrical Characteristics (TA=25℃)
Device
Code
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni
Bi
UNI
BI
VR(V)
Min(V)
Max(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMBJ5.0A
SMBJ5.0CA
KE
AE
5.0
6.40
7.00
10
9.2
65.3
800
SMBJ6.0A
SMBJ6.0CA
KG
AG
6.0
6.67
7.37
10
10.3
58.3
800
SMBJ6.5A
SMBJ6.5CA
KK
AK
6.5
7.22
7.98
10
11.2
53.6
500
SMBJ7.0A
SMBJ7.0CA
KM
AM
7.0
7.78
8.60
10
12.0
50.0
200
SMBJ7.5A
SMBJ7.5CA
KP
AP
7.5
8.33
9.21
1
12.9
46.6
100
SMBJ8.0A
SMBJ8.0CA
KR
AR
8.0
8.89
9.83
1
13.6
44.2
50
SMBJ8.5A
SMBJ8.5CA
KT
AT
8.5
9.44
10.40
1
14.4
41.7
SMBJ9.0A
SMBJ9.0CA
KV
AV
9.0
10.00
11.10
1
15.4
39.0
10
SMBJ10A
SMBJ10CA
KX
AX
10.0
11.10
12.30
1
17.0
35.3
5
SMBJ11A
SMBJ11CA
KZ
AZ
11.0
12.20
13.50
1
18.2
33.0
1
SMBJ12A
SMBJ12CA
LE
BE
12.0
13.30
14.70
1
19.9
30.2
1
SMBJ13A
SMBJ13CA
LG
BG
13.0
14.40
15.90
1
21.5
28.0
1
SMBJ14A
SMBJ14CA
LK
BK
14.0
15.60
17.20
1
23.2
25.9
1
SMBJ15A
SMBJ15CA
LM
BM
15.0
16.70
18.50
1
24.4
24.6
1
SMBJ16A
SMBJ16CA
LP
BP
16.0
17.80
19.70
1
26.0
23.1
1
SMBJ17A
SMBJ17CA
LR
BR
17.0
18.90
20.90
1
27.6
21.8
1
SMBJ18A
SMBJ18CA
LT
BT
18.0
20.00
22.10
1
29.2
20.6
1
SMBJ20A
SMBJ20CA
LV
BV
20.0
22.20
24.50
1
32.4
18.6
1
SMBJ22A
SMBJ22CA
LX
BX
22.0
24.40
26.90
1
35.5
16.9
1
SMBJ24A
SMBJ24CA
LZ
BZ
24.0
26.70
29.50
1
38.9
15.5
1
SMBJ26A
SMBJ26CA
ME
CE
26.0
28.90
31.90
1
42.1
14.3
1
www.liownsemi.com
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Device
Code
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni
Bi
UNI
BI
VR(V)
Min(V)
Max(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMBJ28A
SMBJ28CA
MG
CG
28.0
31.10
34.40
1
45.4
13.3
1
SMBJ30A
SMBJ30CA
MK
CK
30.0
33.30
36.80
1
48.4
12.4
1
SMBJ33A
SMBJ33CA
MM
CM
33.0
36.70
40.60
1
53.3
11.3
1
SMBJ36A
SMBJ36CA
MP
CP
36.0
40.00
44.20
1
58.1
10.4
1
SMBJ40A
SMBJ40CA
MR
CR
40.0
44.40
49.10
1
64.5
9.3
1
SMBJ43A
SMBJ43CA
MT
CT
43.0
47.80
52.80
1
69.4
8.7
1
SMBJ45A
SMBJ45CA
MV
CV
45.0
50.00
55.30
1
72.7
8.3
1
SMBJ48A
SMBJ48CA
MX
CX
48.0
53.30
58.90
1
77.4
7.8
1
SMBJ51A
SMBJ51CA
MZ
CZ
51.0
56.70
62.70
1
82.4
7.3
1
SMBJ54A
SMBJ54CA
NE
DE
54.0
60.00
66.30
1
87.1
6.9
1
SMBJ58A
SMBJ58CA
NG
DG
58.0
64.40
71.20
1
93.6
6.5
1
SMBJ60A
SMBJ60CA
NK
DK
60.0
66.70
73.70
1
96.8
6.2
1
SMBJ64A
SMBJ64CA
NM
DM
64.0
71.10
78.60
1
103.0
5.9
1
SMBJ70A
SMBJ70CA
NP
DP
70.0
77.80
86.00
1
113.0
5.3
1
SMBJ75A
SMBJ75CA
NR
DR
75.0
83.30
92.10
1
121.0
5.0
1
SMBJ78A
SMBJ78CA
NT
DT
78.0
86.70
95.80
1
126.0
4.8
1
SMBJ85A
SMBJ85CA
NV
DV
85.0
94.40
104.0
1
137.0
4.4
1
SMBJ90A
SMBJ90CA
NX
DX
90.0
100.0
111.0
1
146.0
4.1
1
SMBJ100A
SMBJ100CA
NZ
DZ
100.0
111.00
123.00
1
162.0
3.7
1
SMBJ110A
SMBJ110CA
PE
EE
110.0
122.0
135.0
1
177.0
3.4
1
SMBJ120A
SMBJ120CA
PG
EG
120.0
133.0
147.0
1
193.0
3.1
1
SMBJ130A
SMBJ130CA
PK
EK
130.0
144.0
159.0
1
209.0
2.9
1
SMBJ150A
SMBJ150CA
PM
EM
150.0
167.0
185.0
1
243.0
2.5
1
SMBJ160A
SMBJ160CA
PP
EP
160.0
178.0
197.0
1
259.0
2.3
1
SMBJ170A
SMBJ170CA
PR
ER
170.0
189.0
209.0
1
275.0
2.2
1
SMBJ180A
SMBJ180CA
PT
ET
180.0
201.0
222.0
1
292.0
2.1
1
SMBJ190A
SMBJ190CA
PA
EC
190.0
211.0
233.0
1
308.0
2.0
1
SMBJ200A
SMBJ200CA
PV
EV
200.0
224.0
247.0
1
324.0
1.9
1
SMBJ210A
SMBJ210CA
PB
ED
210.0
237.0
263.0
1
340.0
1.8
1
SMBJ220A
SMBJ220CA
PX
EX
220.0
246.0
272.0
1
356.0
1.7
1
SMBJ250A
SMBJ250CA
PZ
EZ
250.0
279.0
309.0
1
405.0
1.5
1
SMBJ300A
SMBJ300CA
QE
FE
300.0
335.0
371.0
1
486.0
1.3
1
SMBJ350A
SMBJ350CA
QG
FG
350.0
391.0
432.0
1
567.0
1.1
1
SMBJ400A
SMBJ400CA
QK
FK
400.0
447.0
494.0
1
648.0
0.9
1
SMBJ440A
SMBJ440CA
QM
FM
440.0
492.0
543.0
1
713.0
0.9
1
www.liownsemi.com
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Ratings and Characteristic Curves (Ta=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
100
10
1
100
60
Tjmax=150
40
1
10
100
td-Pulse Width (µs)
175
100000
10000
Uni-directional
Cj (pF)
Peak Pulse Current, %IRSM
50
75
100 125 150
TA-Ambient Temperature ( )
Peak Value IPPM
100
Half Value IPPM (IPPM/2)
1000
100
Bi-directional
50
10/1000µs Waveform
as defined by R.E.A
10
TJ=25
1MHz,100mV,0V Bias
td
1.0
2.0
Time (ms)
3.0
1
4.0
Figure 5. Steady State Power Dissipation Derating
Curve
10
100
Reverse Breakdown Voltage (V)
1000
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
7
200
Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
25
Figure 4. Typical Junction Capacitance
TJ=25
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPP M
tr=10µs
Figure 3. Pulse Waveform
150
Tjmax=175
80
6
5
Tjmax=175
4
3
Tjmax=150
2
1
50
75
100
125
www.liownsemi.com
150
175
Tj = Tj max.
8.3 ms Single Half Sine-Wave
180
160
140
120
100
80
60
40
1
10
5
50
Number of Cycles at 60Hz
100
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Marking Code
Cathode Marking
YYWW
YYWW
XX
XX
Logo
Device Code
Tracing Code
Logo
Device Code
Tracing Code
Part Number Code
SMBJ XX C A
A:5% VBR Tolerance
C:Bidirectional;No C:Unidirectional
VR Voltage
600W Series Code
Soldering Parameters
www.liownsemi.com
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Packaging Specification
Tape
For Uni-Devices
13 Inches Reel
D
Φ330.0±2.0
d
Φ13.5±0.5
W
16.0±2.0
d
D
www.liownsemi.com
W
Quantity: 3000PCS/Reel
(V1)
很抱歉,暂时无法提供与“SMBJ5.0A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.17550
- 10+0.16200
- 30+0.15930
- 100+0.15120
- 国内价格
- 10+0.29077
- 100+0.23096
- 300+0.20110
- 3000+0.17351
- 6000+0.15555
- 9000+0.14652
