GBU806
GBU806
    MDD(辰达半导体)
    GBU
    桥式整流器/整流桥 电压:600V 电流:8A GBU
GBU806 数据手册
GBU8005 THRU GBU810 Reverse Voltage - 50 to 1000 Volts Forward Current - 8.0 Amperes GLASS PASSIVATED BRIDGE RECTIFIERS Features GBU  Surge overload rating -200 amperes peak .437(11.1) .430(10.9)  Ideal for printed circuit board  Reliable low cost construction utilizing molded plastic technique  Plastic material has U/L lammability classification 94V-0 .154(3.9) .146(3.7) .752(19.1) .720(18.3) .232(5.9) .224(5.7) .401(10.2) .392(9.80) .073(1.85) .057(1.45) Mechanical Data .100(2.54) .085(2.16) .720(18.29) .680(17.27) .047(1.2) .035(0.9) Case : JEDEC GBU Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any .080(2.03) .065(1.65) .210 .210 .190 .190 (5.3) (5.3) (4.8) (4.8) Maximum Ratings And Electrical Characteristics .139(3.53) .133(3.37) .126(3.2)*45° CHAMFER .874(22.2) .860(21.8) .106(2.7) .091(2.3) .022(.56) .018(.46) .210 .190 (5.3) (4.8) Dimensions in inches and (millimeters) Ratings at 25°C ambient temperature unless otherwisespecified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward(with heatsink NOTE 2) Rectified current @T c =100°C(without heatsink) Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Rating for Fusing(t
GBU806
PDF文档涉及的物料型号为GBU8005至GBU810,是玻璃钝化桥式整流器。
以下是文档中提供的关键信息的中文概述:
器件简介: - 这些整流器可以承受反向电压50至1000伏特,正向电流为8.0安培。
- 它们具有浪涌过载额定值,峰值为200安培。
- 适合印刷电路板,采用模塑塑料技术,成本低廉且可靠。
- 塑料材料符合94V-0的UL可燃性分类。
引脚分配: - 封装类型为JEDEC GBU模塑塑料体。
- 引脚为电镀锡,符合MIL-STD-750标准方法2026的可焊接性。
- 极性符号标记在本体上。
- 可任意位置安装。
参数特性: - 工作温度范围为-55至+150摄氏度。
- 存储温度范围也为-55至+150摄氏度。
- 最大重复峰值反向电压(VRRM)从50V到1000V不等。
- 最大有效值电压(VRMS)从35V到700V不等。
- 最大直流阻断电压(Voc)与VRRM相同。
- 最大平均正向电流(在散热器条件下)为8.0A。
- 典型结电容(CJ)在1.0MHz和4.0V直流反偏下测量。
- 典型热阻(ROJA)在散热器条件下测量。
功能详解: - 提供了正向电流降额曲线、最大非重复浪涌电流、典型正向特性、典型结电容和典型反向特性的图表。
应用信息: - 这些整流器适用于单相半波60Hz的电阻性或感性负载,对于电容性负载,电流需要降额20%。
封装信息: - 提供了详细的机械数据,包括尺寸和引脚信息。
注意:文档中的数据仅供参考,具体参数可能会有所不同。
更多详细信息和应用实例,建议访问Microdiode公司网站。
GBU806 价格&库存
很抱歉,暂时无法提供与“GBU806”相匹配的价格&库存,您可以联系我们找货
GBU806
  • 5+1.69690
  • 50+1.35832
  • 150+1.21328
  • 500+0.90224
  • 2500+0.82156
  • 5000+0.77328
库存:5275
GBU806
    • 10+3.00280
    • 100+1.79120
    • 200+1.25380
    • 500+0.89560
    • 1000+0.85090
    • 5000+0.78810
    GBU806
    • 5+1.53978
    库存:18
