Liown Semiconductor Co.,Ltd.
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
SMAJ Series Datasheet
Description
The SMAJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced
by lightning and other transient voltage events. For surface mounted applications in order to optimize board space.
Features
Halogen free and RoHS compliant
Low profile package
Built-in strain relief Design
Low inductance
Excellent clamping capability
400W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time: typically less than 1.0ps from 0V to VB min
Typical IR less than 1μA above 10V devices
Peak 260℃ high temperature Reflow Soldering withstanding
Meet MSL level1, per J-STD-020
IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)
Unit Weight: 0.07g/PCS
Applications
TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in
telecom, computer, Industrial and consumer electronic applications.
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 400
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
3.3
Watts
VF
3.5/5.0
V
IFSM
60
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
30
℃/W
Typical thermal resistance junction to ambient
RθJA
120
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Maximum Instantaneous Forward Voltage at 25A for
Unidirectional Only
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Ranges.
Notes: 1. Non-repetitive current pulse, per Fig.3 and Derating above TA=25℃ per Fig.2.
2. Each terminal is surface Mounted on the 5.0mm×5.0mm (0.03mm thick) copper pads.
3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum.
4. VF < 3.5V for single die parts and VF< 5.0V for stacked-die parts.
www.liownsemi.com
掌握芯技术 Core Technology
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Dimensions (SMA/DO-214AC)
Electrical Characteristics (TA=25℃)
Device
Marking
Code
Part Number
Reverse
StandOff
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Unial
Bi
UNI
BI
VR(V)
Min(V)
Max(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMAJ5.0A
SMAJ5.0CA
AE
WE
5.0
6.40
7.00
10
9.2
43.5
800
SMAJ6.0A
SMAJ6.0CA
AG
WG
6.0
6.67
7.37
10
10.3
38.8
800
SMAJ6.5A
SMAJ6.5CA
AK
WK
6.5
7.22
7.98
10
11.2
35.7
500
SMAJ7.0A
SMAJ7.0CA
AM
WM
7.0
7.78
8.60
10
12.0
33.3
200
SMAJ7.5A
SMAJ7.5CA
AP
WP
7.5
8.33
9.21
1
12.9
31.0
100
SMAJ8.0A
SMAJ8.0CA
AR
WR
8.0
8.89
9.83
1
13.6
29.4
50
SMAJ8.5A
SMAJ8.5CA
AT
WT
8.5
9.44
10.40
1
14.4
27.8
SMAJ9.0A
SMAJ9.0CA
AV
WV
9.0
10.00
11.10
1
15.4
26.0
10
SMAJ10A
SMAJ10CA
AX
WX
10.0
11.10
12.30
1
17.0
23.5
5
SMAJ11A
SMAJ11CA
AZ
WZ
11.0
12.20
13.50
1
18.2
22.0
1
SMAJ12A
SMAJ12CA
BE
XE
12.0
13.30
14.70
1
19.9
20.1
1
SMAJ13A
SMAJ13CA
BG
XG
13.0
14.40
15.90
1
21.5
18.6
1
SMAJ14A
SMAJ14CA
BK
XK
14.0
15.60
17.20
1
23.2
17.2
1
SMAJ15A
SMAJ15CA
BM
XM
15.0
16.70
18.50
1
24.4
16.4
1
SMAJ16A
SMAJ16CA
BP
XP
16.0
17.80
19.70
1
26.0
15.4
1
SMAJ17A
SMAJ17CA
BR
XR
17.0
18.90
20.90
1
27.6
14.5
1
SMAJ18A
SMAJ18CA
BT
XT
18.0
20.00
22.10
1
29.2
13.7
1
SMAJ20A
SMAJ20CA
BV
XV
20.0
22.20
24.50
1
32.4
12.3
1
SMAJ22A
SMAJ22CA
BX
XX
22.0
24.40
26.90
1
35.5
11.3
1
www.liownsemi.com
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Device
Marking
Code
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni
Bi
UNI
BI
VR(V)
Min(V)
Max(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMAJ24A
SMAJ24CA
BZ
XZ
24.0
26.70
29.50
1
38.9
10.3
1
SMAJ26A
SMAJ26CA
CE
YE
26.0
28.90
31.90
1
42.1
9.5
1
SMAJ28A
SMAJ28CA
CG
YG
28.0
31.10
34.40
1
45.4
8.8
1
SMAJ30A
SMAJ30CA
CK
YK
30.0
33.30
36.80
1
48.4
8.3
1
SMAJ33A
SMAJ33CA
CM
YM
33.0
36.70
40.60
1
53.3
7.5
1
SMAJ36A
SMAJ36CA
CP
YP
36.0
40.00
44.20
1
58.1
6.9
1
SMAJ40A
SMAJ40CA
CR
YR
40.0
44.40
49.10
1
64.5
6.2
1
SMAJ43A
SMAJ43CA
CT
YT
43.0
47.80
52.80
1
69.4
5.8
1
SMAJ45A
SMAJ45CA
CV
YV
45.0
50.00
55.30
1
72.7
5.5
1
SMAJ48A
SMAJ48CA
CX
YX
48.0
53.30
58.90
1
77.4
5.2
1
SMAJ51A
SMAJ51CA
CZ
YZ
51.0
56.70
62.70
1
82.4
4.9
1
SMAJ54A
SMAJ54CA
RE
ZE
54.0
60.00
66.30
1
87.1
4.6
1
SMAJ58A
SMAJ58CA
RG
ZG
58.0
64.40
71.20
1
93.6
4.3
1
SMAJ60A
SMAJ60CA
RK
ZK
60.0
66.70
73.70
1
96.8
4.1
1
SMAJ64A
SMAJ64CA
RM
ZM
64.0
71.10
78.60
1
103.0
3.9
1
SMAJ70A
SMAJ70CA
RP
ZP
70.0
77.80
86.00
1
113.0
3.5
1
SMAJ75A
SMAJ75CA
RR
ZR
75.0
83.30
92.10
1
121.0
3.3
1
SMAJ78A
SMAJ78CA
RT
ZT
78.0
86.70
95.80
1
126.0
3.2
1
SMAJ85A
SMAJ85CA
RV
ZV
85.0
94.40
104.0
1
137.0
2.9
1
SMAJ90A
SMAJ90CA
RX
ZX
90.0
100.0
111.0
1
146.0
2.7
1
SMAJ100A
SMAJ100CA
RZ
ZZ
100.0
111.0
123.0
1
162.0
2.5
1
SMAJ110A
SMAJ110CA
SE
VE
110.0
122.0
135.0
1
177.0
2.3
1
SMAJ120A
SMAJ120CA
SG
VG
120.0
133.0
147.0
1
193.0
2.1
1
SMAJ130A
SMAJ130CA
SK
VK
130.0
144.0
159.0
1
209.0
1.9
1
SMAJ150A
SMAJ150CA
SM
VM
150.0
167.0
185.0
1
243.0
1.6
1
SMAJ160A
SMAJ160CA
SP
VP
160.0
178.0
197.0
1
259.0
1.5
1
SMAJ170A
SMAJ170CA
SR
VR
170.0
189.0
209.0
1
275.0
1.5
1
SMAJ180A
SMAJ180CA
ST
VT
180.0
201.0
222.0
1
292.0
1.4
1
SMAJ190A
SMAJ190CA
SU
YU
190.0
211.0
233.0
1
308.0
1.3
1
SMAJ200A
SMAJ200CA
SV
VV
200.0
224.0
247.0
1
324.0
1.2
1
SMAJ210A
SMAJ210CA
SW
YW
210.0
237.0
263.0
1
340.0
1.2
1
SMAJ220A
SMAJ220CA
GE
VX
220.0
246.0
272.0
1
356.0
1.1
1
SMAJ250A
SMAJ250CA
SZ
VZ
250.0
279.0
309.0
1
405.0
1.0
1
SMAJ300A
SMAJ300CA
TE
UE
300.0
335.0
371.0
1
486.0
0.8
1
SMAJ350A
SMAJ350CA
TG
UG
350.0
391.0
432.00
1
567.0
0.7
1
SMAJ400A
SMAJ400CA
TK
UK
400.0
447.0
494.00
1
648.0
0.6
1
SMAJ440A
SMAJ440CA
TM
UM
440.0
492.0
543.00
1
713.0
0.6
1
www.liownsemi.com
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Ratings and Characteristic Curves (Ta=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
10
1
0.1
1
10
100
100
Tjmax=175
80
60
Tjmax=150
40
td-Pulse Width (µs)
175
10000
150
TJ=25
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPP M
tr=10µs
Bi-directional V=0V
1000
Uni-directional V=0V
Peak Value IPPM
100
Cj (pF)
Peak Pulse Current, %IRSM
50
75
100 125 150
TA-Ambient Temperature ( )
Figure 4. Typical Junction Capacitance
Figure 3. Pulse Waveform
Half Value IPPM (IPPM/2)
100
50
10
10/1000µs Waveform
as defined by R.E.A
td
TJ=25
f=1.0MHz
Vsig=50mVp-p
1
1.0
2.0
3.0
1
4.0
Figure 5. Steady State Power Dissipation Derating
Curve
3.0
60
Peak Forward Surve Current (A)
70
Tjmax=175
2.0
1.5
Tjmax=150
1.0
0.5
50
75
100
125
www.liownsemi.com
100
1000
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
3.5
2.5
10
VBR-Reverse Breakdown Voltage (V)
Time (ms)
PM(AV), Steady State Power Dissipation (W)
25
150
175
50
Tj = Tj max.
8.3 ms Single Half Sine-Wave
40
30
1
10
5
50
Number of Cycles at 60Hz
100
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Marking Code
Cathode Marking
YYWW
YYWW
XX
XX
Logo
Device Code
Tracing Code
Logo
Device Code
Tracing Code
Part Number Code
SMAJ XX C A
A:5% VBR Tolerance
C:Bidirectional;No C:Unidirectional
VR Voltage
400W Series Code
Soldering Parameters
www.liownsemi.com
(V1)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Packaging Specification
Tape
For Uni-Devices
13 Inches Reel
D
Φ330.0±2.0
d
Φ13.5±0.5
W
16.0±2.0
d
D
www.liownsemi.com
W
Quantity: 5000PCS/Reel
(V1)
很抱歉,暂时无法提供与“SMAJ13A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15600
- 10+0.14400
- 30+0.14160
- 100+0.13440
- 国内价格
- 10+0.16058
- 100+0.12785
- 300+0.11152
- 1000+0.09928
- 5000+0.08949
- 10000+0.08463
