Liown Semiconductor Co.,Ltd.
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
SMCJ Series Datasheet
Description
The SMCJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced
by lightning and other transient voltage events. For surface mounted applications in order to optimize board space.
Features
Halogen free and RoHS compliant
Low profile package
Built-in strain relief Design
Low inductance
Excellent clamping capability
1500W peak pulse power capability at 10/1000μs waveform,
repetition rate (duty cycle): 0.01%
Fast response time: typically less than 1.0ps from 0V to VB min
Typical IR less than 1μA above 10V devices
Peak 260℃ high temperature Reflow Soldering withstanding
Meet MSL level1, per J-STD-020
IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact)
Unit Weight: 0.259g/PCS
Applications
TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in
telecom, computer, Industrial and consumer electronic applications.
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 1500
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
6.5
Watts
VF
3.5/5.0
V
IFSM
200
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
15
℃/W
Typical thermal resistance junction to ambient
RθJA
75
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Maximum Instantaneous Forward Voltage at 100A for
Unidirectional Only
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Ranges.
Notes: 1. Non-repetitive current pulse, per Fig.3 and Derating above TA=25℃ per Fig.2.
2. Each terminal is surface Mounted on the 8.0mm×8.0mm copper pads.
3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum.
4. VF < 3.5V for single die parts and VF< 5.0V for stacked-die parts.
www.liownsemi.com
掌握芯技术 Core Technology
(V0)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Dimensions (SMC/DO-214AB)
Electrical Characteristics (TA=25℃)
Device
Marking
Code
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Uni
Bi
UNI
BI
VRWM(V)
Min(V)
Max(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMCJ5.0A
SMCJ5.0CA
GDE
BDE
5.0
6.40
7.00
10
9.2
163.0
800
SMCJ6.0A
SMCJ6.0CA
GDG
BDG
6.0
6.67
7.37
10
10.3
145.7
800
SMCJ6.5A
SMCJ6.5CA
GDK
BDK
6.5
7.22
7.98
10
11.2
134.0
500
SMCJ7.0A
SMCJ7.0CA
GDM
BDM
7.0
7.78
8.60
10
12.0
125.0
200
SMCJ7.5A
SMCJ7.5CA
GDP
BDP
7.5
8.33
9.21
1
12.9
116.3
100
SMCJ8.0A
SMCJ8.0CA
GDR
BDR
8.0
8.89
9.83
1
13.6
110.3
50
SMCJ8.5A
SMCJ8.5CA
GDT
BDT
8.5
9.44
10.40
1
14.4
104.2
SMCJ9.0A
SMCJ9.0CA
GDV
BDV
9.0
10.00
11.10
1
15.4
97.4
10
SMCJ10A
SMCJ10CA
GDX
BDX
10.0
11.10
12.30
1
17.0
88.3
5
SMCJ11A
SMCJ11CA
GDZ
BDZ
11.0
12.20
13.50
1
18.2
82.5
1
SMCJ12A
SMCJ12CA
GEE
BEE
12.0
13.30
14.70
1
19.9
75.4
1
SMCJ13A
SMCJ13CA
GEG
BEG
13.0
14.40
15.90
1
21.5
69.8
1
SMCJ14A
SMCJ14CA
GEK
BEK
14.0
15.60
17.20
1
23.2
64.7
1
SMCJ15A
SMCJ15CA
GEM
BEM
15.0
16.70
18.50
1
24.4
61.5
1
SMCJ16A
SMCJ16CA
GEP
BEP
16.0
17.80
19.70
1
26.0
57.7
1
SMCJ17A
SMCJ17CA
GER
BER
17.0
18.90
20.90
1
27.6
54.4
1
SMCJ18A
SMCJ18CA
GET
BET
18.0
20.00
22.10
1
29.2
51.4
1
SMCJ20A
SMCJ20CA
GEV
BEV
20.0
22.20
24.50
1
32.4
46.3
1
SMCJ22A
SMCJ22CA
GEX
BEX
22.0
24.40
26.90
1
35.5
42.3
1
SMCJ24A
SMCJ24CA
GEZ
BEZ
24.0
26.70
29.50
1
38.9
38.6
1
www.liownsemi.com
(V0)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Device
Marking
Code
Part Number
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VR
Uni
Bi
UNI
BI
VR(V)
Min(V)
Max(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
SMCJ26A
SMCJ26CA
GFE
BFE
26.0
28.90
31.90
1
42.1
35.7
1
SMCJ28A
SMCJ28CA
GFG
BFG
28.0
31.10
34.40
1
45.4
33.1
1
SMCJ30A
SMCJ30CA
GFK
BFK
30.0
33.30
36.80
1
48.4
31.0
1
SMCJ33A
SMCJ33CA
GFM
BFM
33.0
36.70
40.60
1
53.3
28.2
1
SMCJ36A
SMCJ36CA
GFP
BFP
36.0
40.00
44.20
1
58.1
25.9
1
SMCJ40A
SMCJ40CA
GFR
BFR
40.0
44.40
49.10
1
64.5
23.3
1
SMCJ43A
SMCJ43CA
GFT
BFT
43.0
47.80
52.80
1
69.4
21.7
1
SMCJ45A
SMCJ45CA
GFV
BFV
45.0
50.00
55.30
1
72.7
20.6
1
SMCJ48A
SMCJ48CA
GFX
BFX
48.0
53.30
58.90
1
77.4
19.4
1
SMCJ51A
SMCJ51CA
GFZ
BFZ
51.0
56.70
62.70
1
82.4
18.2
1
SMCJ54A
SMCJ54CA
GGE
BGE
54.0
60.00
66.30
1
87.1
17.3
1
SMCJ58A
SMCJ58CA
GGG
BGG
58.0
64.40
71.20
1
93.6
16.1
1
SMCJ60A
SMCJ60CA
GGK
BGK
60.0
66.70
73.70
1
96.8
15.5
1
SMCJ64A
SMCJ64CA
GGM
BGM
64.0
71.10
78.60
1
103.0
14.6
1
SMCJ70A
SMCJ70CA
GGP
BGP
70.0
77.80
86.00
1
113.0
13.3
1
SMCJ75A
SMCJ75CA
GGR
BGR
75.0
83.30
92.10
1
121.0
12.4
1
SMCJ78A
SMCJ78CA
GGT
BGT
78.0
86.70
95.80
1
126.0
11.9
1
SMCJ85A
SMCJ85CA
GGV
BGV
85.0
94.40
104.00
1
137.0
11.0
1
SMCJ90A
SMCJ90CA
GGX
BGX
90.0
100.0
111.0
1
146.0
10.3
1
SMCJ100A
SMCJ100CA
GGZ
BGZ
100.0
111.0
123.0
1
162.0
9.3
1
SMCJ110A
SMCJ110CA
GHE
BHE
110.0
122.0
135.0
1
177.0
8.5
1
SMCJ120A
SMCJ120CA
GHG
BHG
120.0
133.0
147.0
1
193.0
7.8
1
SMCJ130A
SMCJ130CA
GHK
BHK
130.0
144.0
159.0
1
209.0
7.2
1
SMCJ150A
SMCJ150CA
GHM
BHM
150.0
167.0
185.0
1
243.0
6.2
1
SMCJ160A
SMCJ160CA
GHP
BHP
160.0
178.0
197.0
1
259.0
5.8
1
SMCJ170A
SMCJ170CA
GHR
BHR
170.0
189.0
209.0
1
275.0
5.5
1
SMCJ180A
SMCJ180CA
GHT
BHT
180.0
201.0
222.0
1
292.0
5.1
1
SMCJ190A
SMCJ190CA
GHU
BHU
190.0
211.0
233.0
1
308.0
4.8
1
SMCJ200A
SMCJ200CA
GHV
BHV
200.0
224.0
247.0
1
324.0
4.6
1
SMCJ210A
SMCJ210CA
GHW
BHW
210.0
237.0
263.0
1
340.0
4.4
1
SMCJ220A
SMCJ220CA
GHX
BHX
220.0
246.0
272.0
1
356.0
4.2
1
SMCJ250A
SMCJ250CA
GHZ
BHZ
250.0
279.0
309.0
1
405.0
3.7
1
SMCJ300A
SMCJ300CA
GJE
BJE
300.0
335.0
371.0
1
486.0
3.1
1
SMCJ350A
SMCJ350CA
GJG
BJG
350.0
391.0
432.0
1
567.0
2.6
1
SMCJ400A
SMCJ400CA
GJK
BJK
400.0
447.0
494.0
1
648.0
2.3
1
SMCJ440A
SMCJ440CA
GJM
BJM
440.0
492.0
543.0
1
713.0
2.1
1
www.liownsemi.com
(V0)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Ratings and Characteristic Curves (Ta=25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
10
1
0.1
1
10
100
td-Pulse Width (µs)
60
Tjmax=150
40
50
75
100 125 150
TA-Ambient Temperature ( )
TJ=25
Pulse Width(td ) is defined as
the point where the peak
current decays to 50% of IPP M
tr=10µs
100000
Bi-directional V=0V
10000
Peak Value IPPM
Uni-directional V=0V
Cj (pF)
100
175
Figure 4. Typical Junction Capacitance
150
Half Value IPPM (IPPM/2)
1000
100
50
10/1000µs Waveform
as defined by R.E.A
10
td
TJ=25
f=1.0MHz
Vsig=50mVp-p
1
1.0
2.0
3.0
1
4.0
10
100
1000
VBR-Reverse Breakdown Voltage (V)
Time (ms)
Figure 5. Steady State Power Dissipation Derating
Curve
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
7
200
Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
Tjmax=175
80
1000
Figure 3. Pulse Waveform
Peak Pulse Current, %IRSM
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM - Peak Pulse Power (kW)
100
6
5
Tjmax=175
4
3
Tjmax=150
2
1
www.liownsemi.com
50
75
100 125 150
175
Tj = Tj max.
8.3 ms Single Half Sine-Wave
180
160
140
120
100
80
60
40
1
10
5
50
Number of Cycles at 60Hz
100
(V0)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Marking Code
Cathode Marking
YYWW
YYWW
XX
XX
Logo
Device Code
Tracing Code
Logo
Device Code
Tracing Code
Part Number Code
SMCJ XX C A
A:5% VBR Tolerance
C:Bidirectional;No C:Unidirectional
VR Voltage
1.5KW Series Code
Soldering Parameters
www.liownsemi.com
(V0)
里阳半导体有限公司
浙江省玉环市半导体科技产业园
Tel:0576-8071-1338
Fax:0576-8071-1339
Packaging Specification
Tape
For Uni-Devices
13 Inches Reel
D
Φ330.0±2.0
d
Φ13.5±0.5
W
20.0±2.0
d
D
www.liownsemi.com
W
Quantity: 3000PCS/Reel
(V0)
很抱歉,暂时无法提供与“SMCJ6.0CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.59800
- 10+0.55200
- 30+0.54280
- 100+0.51520
- 国内价格
- 5+0.93859
- 50+0.74898
- 150+0.65418
- 500+0.58307
- 3000+0.50254
- 6000+0.47402
