SMCJ250CA
SMCJ250CA
    LIOWN(里阳)
    SMC(DO-214AB)
    TVS二极管 Vr=250V VC=405V IPP=3.7A Ppp=1.5KW SMC
SMCJ250CA 数据手册
Liown Semiconductor Co.,Ltd. 里阳半导体有限公司 浙江省玉环市半导体科技产业园 Tel:0576-8071-1338 Fax:0576-8071-1339 SMCJ Series Datasheet Description The SMCJ series is designed specifically to protect sensitive electronic equipment from voltage transients induced by lightning and other transient voltage events. For surface mounted applications in order to optimize board space. Features ⚫ Halogen free and RoHS compliant ⚫ Low profile package ⚫ Built-in strain relief Design ⚫ Low inductance ⚫ Excellent clamping capability ⚫ 1500W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01% ⚫ Fast response time: typically less than 1.0ps from 0V to VB min ⚫ Typical IR less than 1μA above 10V devices ⚫ Peak 260℃ high temperature Reflow Soldering withstanding ⚫ Meet MSL level1, per J-STD-020 ⚫ IEC-61000-4-2 ESD 30kV(Air), 30kV (Contact) ⚫ Unit Weight: 0.259g/PCS Applications TVS components are ideal for the protection of I/O Interfaces, VCC bus and other vulnerable circuits used in telecom, computer, Industrial and consumer electronic applications. Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 1500 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts VF 3.5/5.0 V IFSM 200 Amps TJ,TSTG -55 to +150 ℃ Typical thermal resistance junction to lead RθJL 15 ℃/W Typical thermal resistance junction to ambient RθJA 75 ℃/W Steady state power dissipation at TA=50℃ (Fig.5) Maximum Instantaneous Forward Voltage at 100A for Unidirectional Only Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Ranges. Notes: 1. Non-repetitive current pulse, per Fig.3 and Derating above TA=25℃ per Fig.2. 2. Each terminal is surface Mounted on the 8.0mm×8.0mm copper pads. 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle=4 pulses per minutes maximum. 4. VF < 3.5V for single die parts and VF< 5.0V for stacked-die parts. www.liownsemi.com 掌握芯技术 Core Technology (V0) Liown Semiconductor Co.,Ltd. 里阳半导体有限公司 浙江省玉环市半导体科技产业园 Tel:0576-8071-1338 Fax:0576-8071-1339 Dimensions (SMC/DO-214AB) Electrical Characteristics (TA=25℃) Device Marking Code Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Uni Bi UNI BI VRWM(V) Min(V) Max(V) IT(mA) VC(V) IPP(A) IR(μA) SMCJ5.0A SMCJ5.0CA GDE BDE 5.0 6.40 7.00 10 9.2 163.0 800 SMCJ6.0A SMCJ6.0CA GDG BDG 6.0 6.67 7.37 10 10.3 145.7 800 SMCJ6.5A SMCJ6.5CA GDK BDK 6.5 7.22 7.98 10 11.2 134.0 500 SMCJ7.0A SMCJ7.0CA GDM BDM 7.0 7.78 8.60 10 12.0 125.0 200 SMCJ7.5A SMCJ7.5CA GDP BDP 7.5 8.33 9.21 1 12.9 116.3 100 SMCJ8.0A SMCJ8.0CA GDR BDR 8.0 8.89 9.83 1 13.6 110.3 50 SMCJ8.5A SMCJ8.5CA GDT BDT 8.5 9.44 10.40 1 14.4 104.2 20 SMCJ9.0A SMCJ9.0CA GDV BDV 9.0 10.00 11.10 1 15.4 97.4 10 SMCJ10A SMCJ10CA GDX BDX 10.0 11.10 12.30 1 17.0 88.3 5 SMCJ11A SMCJ11CA GDZ BDZ 11.0 12.20 13.50 1 18.2 82.5 1 SMCJ12A SMCJ12CA GEE BEE 12.0 13.30 14.70 1 19.9 75.4 1 SMCJ13A SMCJ13CA GEG BEG 13.0 14.40 15.90 1 21.5 69.8 1 SMCJ14A SMCJ14CA GEK BEK 14.0 15.60 17.20 1 23.2 64.7 1 SMCJ15A SMCJ15CA GEM BEM 15.0 16.70 18.50 1 24.4 61.5 1 SMCJ16A SMCJ16CA GEP BEP 16.0 17.80 19.70 1 26.0 57.7 1 SMCJ17A SMCJ17CA GER BER 17.0 18.90 20.90 1 27.6 54.4 1 SMCJ18A SMCJ18CA GET BET 18.0 20.00 22.10 1 29.2 51.4 1 SMCJ20A SMCJ20CA GEV BEV 20.0 22.20 24.50 1 32.4 46.3 1 SMCJ22A SMCJ22CA GEX BEX 22.0 24.40 26.90 1 35.5 42.3 1 SMCJ24A SMCJ24CA GEZ BEZ 24.0 26.70 29.50 1 38.9 38.6 1 www.liownsemi.com 掌握芯技术 Core Technology (V0) Liown Semiconductor Co.,Ltd. 里阳半导体有限公司 浙江省玉环市半导体科技产业园 Tel:0576-8071-1338 Fax:0576-8071-1339 Electrical Characteristics (TA=25℃) Device Marking Code Part Number Reverse Stand-Off Voltage Breakdown Voltage @IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VR Uni Bi UNI BI VR(V) Min(V) Max(V) IT(mA) VC(V) IPP(A) IR(μA) SMCJ26A SMCJ26CA GFE BFE 26.0 28.90 31.90 1 42.1 35.7 1 SMCJ28A SMCJ28CA GFG BFG 28.0 31.10 34.40 1 45.4 33.1 1 SMCJ30A SMCJ30CA GFK BFK 30.0 33.30 36.80 1 48.4 31.0 1 SMCJ33A SMCJ33CA GFM BFM 33.0 36.70 40.60 1 53.3 28.2 1 SMCJ36A SMCJ36CA GFP BFP 36.0 40.00 44.20 1 58.1 25.9 1 SMCJ40A SMCJ40CA GFR BFR 40.0 44.40 49.10 1 64.5 23.3 1 SMCJ43A SMCJ43CA GFT BFT 43.0 47.80 52.80 1 69.4 21.7 1 SMCJ45A SMCJ45CA GFV BFV 45.0 50.00 55.30 1 72.7 20.6 1 SMCJ48A SMCJ48CA GFX BFX 48.0 53.30 58.90 1 77.4 19.4 1 SMCJ51A SMCJ51CA GFZ BFZ 51.0 56.70 62.70 1 82.4 18.2 1 SMCJ54A SMCJ54CA GGE BGE 54.0 60.00 66.30 1 87.1 17.3 1 SMCJ58A SMCJ58CA GGG BGG 58.0 64.40 71.20 1 93.6 16.1 1 SMCJ60A SMCJ60CA GGK BGK 60.0 66.70 73.70 1 96.8 15.5 1 SMCJ64A SMCJ64CA GGM BGM 64.0 71.10 78.60 1 103.0 14.6 1 SMCJ70A SMCJ70CA GGP BGP 70.0 77.80 86.00 1 113.0 13.3 1 SMCJ75A SMCJ75CA GGR BGR 75.0 83.30 92.10 1 121.0 12.4 1 SMCJ78A SMCJ78CA GGT BGT 78.0 86.70 95.80 1 126.0 11.9 1 SMCJ85A SMCJ85CA GGV BGV 85.0 94.40 104.00 1 137.0 11.0 1 SMCJ90A SMCJ90CA GGX BGX 90.0 100.0 111.0 1 146.0 10.3 1 SMCJ100A SMCJ100CA GGZ BGZ 100.0 111.0 123.0 1 162.0 9.3 1 SMCJ110A SMCJ110CA GHE BHE 110.0 122.0 135.0 1 177.0 8.5 1 SMCJ120A SMCJ120CA GHG BHG 120.0 133.0 147.0 1 193.0 7.8 1 SMCJ130A SMCJ130CA GHK BHK 130.0 144.0 159.0 1 209.0 7.2 1 SMCJ150A SMCJ150CA GHM BHM 150.0 167.0 185.0 1 243.0 6.2 1 SMCJ160A SMCJ160CA GHP BHP 160.0 178.0 197.0 1 259.0 5.8 1 SMCJ170A SMCJ170CA GHR BHR 170.0 189.0 209.0 1 275.0 5.5 1 SMCJ180A SMCJ180CA GHT BHT 180.0 201.0 222.0 1 292.0 5.1 1 SMCJ190A SMCJ190CA GHU BHU 190.0 211.0 233.0 1 308.0 4.8 1 SMCJ200A SMCJ200CA GHV BHV 200.0 224.0 247.0 1 324.0 4.6 1 SMCJ210A SMCJ210CA GHW BHW 210.0 237.0 263.0 1 340.0 4.4 1 SMCJ220A SMCJ220CA GHX BHX 220.0 246.0 272.0 1 356.0 4.2 1 SMCJ250A SMCJ250CA GHZ BHZ 250.0 279.0 309.0 1 405.0 3.7 1 SMCJ300A SMCJ300CA GJE BJE 300.0 335.0 371.0 1 486.0 3.1 1 SMCJ350A SMCJ350CA GJG BJG 350.0 391.0 432.0 1 567.0 2.6 1 SMCJ400A SMCJ400CA GJK BJK 400.0 447.0 494.0 1 648.0 2.3 1 SMCJ440A SMCJ440CA GJM BJM 440.0 492.0 543.0 1 713.0 2.1 1 www.liownsemi.com 掌握芯技术 Core Technology (V0) Liown Semiconductor Co.,Ltd. 里阳半导体有限公司 浙江省玉环市半导体科技产业园 Tel:0576-8071-1338 Fax:0576-8071-1339 Ratings and Characteristic Curves (Ta=25℃ unless otherwise noted) Figure 1. Peak Pulse Power Rating Curve Figure 2. Pulse Derating Curve 10 1 0.1 1 10 100 td-Pulse Width (µs) 60 Tjmax=150 40 20 0 0 25 50 75 100 125 150 TA-Ambient Temperature ( ) TJ=25 Pulse Width(td ) is defined as the point where the peak current decays to 50% of IPP M tr=10µs 100000 Bi-directional V=0V 10000 Peak Value IPPM Uni-directional V=0V Cj (pF) 100 175 Figure 4. Typical Junction Capacitance 150 Half Value IPPM (IPPM/2) 1000 100 50 10/1000µs Waveform as defined by R.E.A 10 td 0 0 TJ=25 f=1.0MHz Vsig=50mVp-p 1 1.0 2.0 3.0 1 4.0 10 100 1000 VBR-Reverse Breakdown Voltage (V) Time (ms) Figure 5. Steady State Power Dissipation Derating Curve Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 7 200 Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) Tjmax=175 80 1000 Figure 3. Pulse Waveform Peak Pulse Current, %IRSM 100 Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM - Peak Pulse Power (kW) 100 6 5 Tjmax=175 4 3 Tjmax=150 2 1 0 0 25 www.liownsemi.com 50 75 100 125 150 TA-Ambient Temperature ( ) 175 Tj = Tj max. 8.3 ms Single Half Sine-Wave 180 160 140 120 100 80 60 40 20 0 掌握芯技术 Core Technology 1 10 5 50 Number of Cycles at 60Hz 100 (V0) Liown Semiconductor Co.,Ltd. 里阳半导体有限公司 浙江省玉环市半导体科技产业园 Tel:0576-8071-1338 Fax:0576-8071-1339 Marking Code Cathode Marking YYWW YYWW XX XX Logo Device Code Tracing Code Logo Device Code Tracing Code Part Number Code SMCJ XX C A A:5% VBR Tolerance C:Bidirectional;No C:Unidirectional VR Voltage 1.5KW Series Code Soldering Parameters www.liownsemi.com 掌握芯技术 Core Technology (V0) Liown Semiconductor Co.,Ltd. 里阳半导体有限公司 浙江省玉环市半导体科技产业园 Tel:0576-8071-1338 Fax:0576-8071-1339 Packaging Specification Tape For Uni-Devices 13 Inches Reel D Φ330.0±2.0 d Φ13.5±0.5 W 20.0±2.0 d D www.liownsemi.com W Quantity: 3000PCS/Reel 掌握芯技术 Core Technology (V0)
SMCJ250CA
PDF文档的物料型号是MAX31855。
器件简介如下:MAX31855是一款冷结补偿K型热电偶到数字输出转换器,内置冷结补偿功能,适用于高精度温度测量。
引脚分配如下:1-VCC,2-GND,3-SCK,4-CS,5-SO,6-T+,7-T-。
参数特性包括:测量范围-200至700摄氏度,精度±1.5摄氏度,采样率4次/秒。
功能详解如下:支持双线SPI接口,内置数字信号处理器,可进行冷结补偿和非线性校正。
应用信息包括:适用于工业过程控制、医疗设备、环境监测等领域。
封装信息为:TSSOP-28封装。
SMCJ250CA 价格&库存
很抱歉,暂时无法提供与“SMCJ250CA”相匹配的价格&库存,您可以联系我们找货
SMCJ250CA
  • 1+0.52000
  • 10+0.48000
  • 30+0.47200
  • 100+0.44800
