STS-30-DIS
STS-30-DIS
    SENSIRION(盛思锐)
    VFDFN8_EP
    HIGHACCURACYDIGITALTEMPSENSO
STS-30-DIS 数据手册
Datasheet STS3x-DIS High-Accuracy Digital Temperature Sensor IC  Fully calibrated and linearized digital output  Wide supply voltage range, from 2.4 V to 5.5 V  I2C Interface with communication speeds up to 1 MHz and two user selectable addresses  Typical accuracy of  0.3 °C  Very fast start-up and measurement time  Tiny 8-Pin DFN package Product Summary The STS3x-DIS is Sensirion’s new high accuracy digital temperature sensor. It relies on the industry proven CMOSens® technology, providing for increased intelligence, reliability and improved accuracy specifications compared to its predecessors. Its functionality includes enhanced signal processing, two distinctive and user selectable I2C addresses and communication speeds of up to 1 MHz. The DFN package has a footprint of 2.5 x 2.5 mm2 while keeping a height of 0.9 mm. This allows for integration of the STS3x-DIS into a great variety of applications. Additionally, the wide supply voltage range of 2.4 V to 5.5 V guarantees compatibility with a wide range of applications. All in all, the STS3x-DIS incorporates more than 15 years of Sensirion’s digital sensor know-how. Benefits of Sensirion’s CMOSens® Technology  High reliability and long-term stability  Industry-proven technology with a track record of more than 15 years  Designed for mass production  High process capability  High signal-to-noise ratio Content 1 Sensor Performance.............................................2 2 Specifications .......................................................3 3 Pin Assignment ....................................................5 4 Operation and Communication .............................6 5 Packaging...........................................................12 6 Shipping Package ..............................................14 7 Quality ................................................................15 8 Ordering Information...........................................15 9 Further Information .............................................15 www.sensirion.com Figure 1 Functional block diagram of the STS3x-DIS. The CMOSens™ technology allows providing for a fully calibrated I2C signal. November 2016 - Version 1 1/17 Datasheet STS3x-DIS 1 1.1 Sensor Performance Temperature Sensor Performance Parameter Accuracy tolerance1 Accuracy tolerance1 Condition Value Units STS30-DIS typ., 0°C to 65°C 0.3 °C STS31-DIS typ., -40°C to 90°C 0.3 0.24 0.12 0.06 0.015 -40 to 125 °C >2 s
STS-30-DIS
物料型号:STS3x-DIS
器件简介:SENSIRION STS3x-DIS是一款高精度数字温度传感器,采用CMOSens®技术,提供线性化的数字输出。其特点包括高达1MHz的通信速度、2.4V至5.5V的宽供电电压范围、具有两个用户可选地址的I2C接口、典型精度±0.3°C、快速启动和测量时间以及小型8引脚DFN封装。
引脚分配:STS3x-DIS采用8引脚DFN封装,包括串行数据(SDA)、地址(ADDR)、报警(ALERT)、串行时钟(SCL)、供电电压(VDD)、复位(nRESET)、无电气功能(R)和地(VSS)。
参数特性: - 供电电压:2.4V至5.5V - 电源电流:待机状态(单次测量模式)0.2μA至2.0μA,测量时800μA至1500μA - 测量时间:低重复性2.5ms至15ms - 分辨率:典型值0.015℃ - 响应时间:t63%大于2秒 - 长期漂移:最大0.03℃/年
功能详解:STS3x-DIS支持单次数据采集模式和周期性数据采集模式。单次测量模式下,一个测量命令触发一个16位温度值的采集。周期性测量模式下,一个测量命令产生一系列16位温度值。
应用信息:由于其高精度和小尺寸,STS3x-DIS适用于需要精确温度测量的多种应用,例如工业自动化、医疗设备、环境监测等。
封装信息:传感器采用无引线(DFN)封装,尺寸为2.5mm x 2.5mm,高度为0.9mm。封装遵循JEDEC标准,并具有1级的湿度敏感度等级(MSL)。
STS-30-DIS 价格&库存
很抱歉,暂时无法提供与“STS-30-DIS”相匹配的价格&库存,您可以联系我们找货
STS-30-DIS
  • 1+4.03300
