1PS79SB17,115
1PS79SB17,115
    NEXPERIA(安世)
    SOD-523(SC-79)
    肖特基二极管 4V 1.25 x 0.85 SMT SOD523 30mA
1PS79SB17,115 数据手册
1PSxSB17 4 V, 30 mA low Cd Schottky barrier diode Rev. 06 — 4 April 2005 Product data sheet 1. Product profile 1.1 General description Planar low capacitance Schottky barrier diode encapsulated in a very small SMD plastic package. Table 1: Product overview Type number Package Configuration Nexperia JEITA 1PS66SB17 SOT666 - triple isolated diode 1PS76SB17 SOD323 SC-76 single diode 1PS79SB17 SOD523 SC-79 single diode 1.2 Features ■ Very low diode capacitance ■ Very low forward voltage ■ Very small SMD plastic packages 1.3 Applications ■ Digital applications: ◆ Ultra high-speed switching ◆ Clamping circuits. ■ RF applications: ◆ Diode ring mixer ◆ RF detector ◆ RF voltage doubler 1.4 Quick reference data Table 2: Quick reference data Symbol Parameter IF VR Cd Conditions Min Typ Max Unit continuous forward current - - 30 mA continuous reverse voltage - - 4 V diode capacitance - 0.8 1 pF 1PSxSB17 Nexperia 4 V, 30 mA low Cd Schottky barrier diode 2. Pinning information Table 3: Pinning Pin Description Simplified outline Symbol SOD323 (SC-76); SOD523 (SC-79) 1 cathode 2 anode [1] 1 1 2 2 sym001 001aab540 SOT666 1 anode (diode 1) 2 anode (diode 2) 3 anode (diode 3) 4 cathode (diode 3) 5 cathode (diode 2) 6 cathode (diode 1) [1] 6 1 5 2 4 6 5 1 2 4 3 sym046 3 The marking bar indicates the cathode. 3. Ordering information Table 4: Ordering information Type number Package Name Description Version 1PS66SB17 - plastic surface mounted package; 6 leads SOT666 1PS76SB17 SC-76 plastic surface mounted package; 2 leads SOD323 1PS79SB17 SC-79 plastic surface mounted package; 2 leads SOD523 4. Marking Table 5: Marking codes Type number Marking code 1PS66SB17 N2 1PS76SB17 S7 1PS79SB17 T2 5. Limiting values Table 6: Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Max Unit VR continuous reverse voltage - 4 V IF continuous forward current - 30 mA © 9397 750 14587 Product data sheet Min Rev. 06 — 4 April 2005 Nexperia B.V. 2017. All rights reserved 2 of 8 1PSxSB17 Nexperia 4 V, 30 mA low Cd Schottky barrier diode Table 6: Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C 6. Thermal characteristics Table 7: Thermal characteristics Symbol Parameter Rth(j-a) Conditions thermal resistance from junction to ambient; in free air Min Typ Max Unit [1] SOD323 [2] - - 450 K/W SOD523 [3] - - 450 K/W SOT666 [4] - - 700 K/W [1] For Schottky barrier diodes, thermal run-away has to be considered as in some applications the reverse power losses PR are a significant part of the total power losses. Nomograms for determining the reverse power losses PR and IF(AV) rating will be available on request. [2] Refer to SOD323 (SC-76) standard mounting conditions. [3] Refer to SOD523 (SC-79) standard mounting conditions. [4] Refer to SOT666 standard mounting conditions. 7. Characteristics Table 8: Characteristics Tamb = 25 °C unless otherwise specified. Symbol VF Parameter Conditions forward voltage Min Typ Max Unit IF = 0.1 mA - 300 350 mV IF = 1 mA - 360 450 mV IF = 10 mA - 470 600 mV - - 250 nA VR = 0 V; f = 1 MHz - 0.8 1 pF VR = 0.5 V; f = 1 MHz - 0.65 - pF see Figure 1; IR reverse current VR = 3 V; see Figure 2 Cd diode capacitance see Figure 3; [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. © 9397 750 14587 Product data sheet [1] Rev. 06 — 4 April 2005 Nexperia B.V. 2017. All rights reserved 3 of 8 1PSxSB17 Nexperia 4 V, 30 mA low Cd Schottky barrier diode 006aaa077 102 IR (nA) IF (mA) 006aaa078 105 (1) 104 103 10 (2) 102 (1) (2) (3) (4) (3) 10 1 1 (4) 10−1 10−1 10−2 10−3 10−2 0 0.2 0.4 0.6 0 0.8 1 2 3 4 VR (V) VF (V) (1) Tamb = 150 °C (1) Tamb = 150 °C (2) Tamb = 85 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (3) Tamb = 25 °C (4) Tamb = −40 °C (4) Tamb = −40 °C Fig 1. Forward current as a function of forward voltage; typical values. Fig 2. Reverse current as a function of reverse voltage; typical values. mlc797 0.8 Cd (pF) 0.7 0.6 0.5 0.4 0 1 2 3 VR (V) 4 Tamb = 25 °C; f = 1 MHz Fig 3. Diode capacitance as a function of reverse voltage; typical values. © 9397 750 14587 Product data sheet Rev. 06 — 4 April 2005 Nexperia B.V. 2017. All rights reserved 4 of 8 1PSxSB17 Nexperia 4 V, 30 mA low Cd Schottky barrier diode 8. Package outline 0.85 0.75 1.35 1.15 0.65 0.58 1 1.1 0.8 0.45 0.15 1 2.7 2.3 1.65 1.25 1.55 1.15 1.8 1.6 2 2 0.34 0.26 0.40 0.25 0.17 0.11 Dimensions in mm 02-12-13 Fig 4. Package outline SOD523 (SC-79) 0.25 0.10 Dimensions in mm 03-12-17 Fig 5. Package outline SOD323 (SC-76) 1.7 1.5 6 0.6 0.5 5 4 0.3 0.1 1.7 1.5 1.3 1.1 pin 1 index 1 2 3 0.18 0.08 0.27 0.17 0.5 1 Dimensions in mm 04-11-08 Fig 6. Package outline SOT666 9. Packing information Table 9: Packing methods The indicated -xxx are the last three digits of the 12NC ordering code. [1] Type number Package Description Packing quantity 3000 4000 -115 10000 1PS66SB17 SOT666 4 mm pitch, 8 mm tape and reel - 1PS76SB17 SOD323 4 mm pitch, 8 mm tape and reel -115 -135 1PS79SB17 SOD523 4 mm pitch, 8 mm tape and reel -115 -135 [1] - For further information and the availability of packing methods, see Section 14. © 9397 750 14587 Product data sheet Rev. 06 — 4 April 2005 Nexperia B.V. 2017. All rights reserved 5 of 8 1PSxSB17 Nexperia 4 V, 30 mA low Cd Schottky barrier diode 10. Revision history Table 10: Revision history Document ID Release date Data sheet status Change notice Doc. number 1PSXSB17_6 20170404 - 9397 750 14587 1PS76SB17_1 PS79SB17_5 Modifications: • Product data sheet Supersedes Type number 1PS66SB17 added 1PS76SB17_1PS79SB17_5 20171028 Product data sheet - 9397 750 13733 1PS76SB17_4 1PS76SB17_4 20170126 Product data sheet - 9397 750 12618 1PS76SB17_3 1PS76SB17_3 20020809 Product data sheet - 9397 750 10174 1PS76SB17_2 1PS76SB17_2 19990525 Preliminary data sheet - 9397 750 05893 1PS76SB17_1 1PS76SB17_1 19961014 Preliminary data sheet - 9397 750 01342 - © 9397 750 14587 Product data sheet Rev. 06 — 4 April 2005 Nexperia B.V. 2017. All rights reserved 6 of 8 1PSxSB17 Nexperia 4 V, 30 mA low Cd Schottky barrier diode 11. Data sheet status Level Data sheet status [1] Product status [2] [3] Definition I Objective data Development This data sheet contains data from the objective specification for product development. Nexperia reserves the right to change the specification in any manner without notice. II Preliminary data Qualification This data sheet contains data from the preliminary specification. Supplementary data will be published at a later date. Nexperia reserves the right to change the specification without notice, in order to improve the design and supply the best possible product. IIIProduct dataProduction This data sheet contains data from the product specification. Nexperia reserves the right to make changes at any time in order to improve the design, manufacturing and supply. Relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). [1] Please consult the most recently issued data sheet before initiating or completing a design. [2] The product status of the device(s) described in this data sheet may have changed since this data sheet was published. The latest information is available on the Internet at URL http://www.nexperia.com. [3] For data sheets describing multiple type numbers, the highest-level product status determines the data sheet status. 12. Definitions 13. Disclaimers Short-form specification — The data in a short-form specification is extracted from a full data sheet with the same type number and title. For detailed information see the relevant data sheet or data handbook. Life support — These products are not designed for use in life support appliances, devices, or systems where malfunction of these products can reasonably be expected to result in personal injury. Nexperia customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Nexperia for any damages resulting from such application. Limiting values definition — Limiting values given are in accordance with the Absolute Maximum Rating System (IEC 60134). Stress above one or more of the limiting values may cause permanent damage to the device. These are stress ratings only and operation of the device at these or at any other conditions above those given in the Characteristics sections of the specification is not implied. Exposure to limiting values for extended periods may affect device reliability. Application information — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia make no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Right to make changes — Nexperia reserves the right to make changes in the products - including circuits, standard cells, and/or software - described or contained herein in order to improve design and/or performance. When the product is in full production (status ‘Production’), relevant changes will be communicated via a Customer Product/Process Change Notification (CPCN). Nexperia assumes no responsibility or liability for the use of any of these products, conveys no license or title under any patent, copyright, or mask work right to these products, and makes no representations or warranties that these products are free from patent, copyright, or mask work right infringement, unless otherwise specified. 14. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © 9397 750 14587 Product data sheet Rev. 06 — 4 April 2005 Nexperia B.V. 2017. All rights reserved 7 of 8 1PSxSB17 Nexperia 4 V, 30 mA low Cd Schottky barrier diode 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 14 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description. . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data. . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics. . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information. . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 2 2 2 2 3 3 5 5 6 7 7 7 7 © Nexperia B.V. 2017 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Date of release: 4 April 2005 Document number: 9397 750 14587 Published in The Netherlands
1PS79SB17,115 价格&库存
很抱歉,暂时无法提供与“1PS79SB17,115”相匹配的价格&库存,您可以联系我们找货
