PMEG3005EB,115
PMEG3005EB,115
    NEXPERIA(安世)
    SOD-523(SC-79)
    直流反向耐压(Vr):30V 平均整流电流(Io):500mA 正向压降(Vf):500mV@500mA
PMEG3005EB,115 数据手册
PMEG3005EB; PMEG3005EL 0.5 A very low VF MEGA Schottky barrier rectifiers Rev. 01 — 29 November 2006 Product data sheet 1. Product profile 1.1 General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifiers with an integrated guard ring for stress protection, encapsulated in ultra small Surface-Mounted Device (SMD) plastic packages. Table 1. Product overview Type number Package Configuration Nexperia JEITA PMEG3005EB SOD523 SC-79 single PMEG3005EL SOD882 - single 1.2 Features n n n n Forward current: IF ≤ 0.5 A Reverse voltage: VR ≤ 30 V Very low forward voltage Ultra small SMD plastic packages 1.3 Applications n n n n n Low voltage rectification High efficiency DC-to-DC conversion Switch mode power supply Reverse polarity protection Low power consumption applications 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF forward current Tsp ≤ 55 °C - - 0.5 A VR reverse voltage - - 30 V - 430 500 mV VF [1] forward voltage Pulse test: tp ≤ 300 µs; δ ≤ 0.02. IF = 500 mA [1] PMEG3005EB; PMEG3005EL Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers 2. Pinning information Table 3. Pinning Pin Description Simplified outline Symbol SOD523 1 cathode 2 anode [1] 1 1 2 2 sym001 SOD882 1 cathode 2 anode [1] 1 1 2 2 sym001 Transparent top view [1] The marking bar indicates the cathode. 3. Ordering information Table 4. Ordering information Type number Package Name Description Version PMEG3005EB SC-79 plastic surface-mounted package; 2 leads SOD523 PMEG3005EL - leadless ultra small plastic package; 2 terminals; body 1.0 × 0.6 × 0.5 mm SOD882 4. Marking Table 5. Marking codes Type number Marking code PMEG3005EB KB PMEG3005EL AM © PMEG3005EB_PMEG3005EL_1 Product data sheet Rev. 01 — 29 November 2006 Nexperia B.V. 2017. All rights reserved 2 of 10 PMEG3005EB; PMEG3005EL Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VR reverse voltage IF forward current IFRM repetitive peak forward current IFSM Ptot Conditions Min Max Unit - 30 V Tsp ≤ 55 °C - 0.5 A tp ≤ 1 ms; δ ≤ 0.25 - 1 A non-repetitive peak forward current square wave; tp = 8 ms - 3 A total power dissipation Tamb ≤ 25 °C PMEG3005EB - 310 mW PMEG3005EL - 250 mW [1] Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from junction to ambient Conditions in free air PMEG3005EB PMEG3005EL Rth(j-sp) thermal resistance from junction to solder point PMEG3005EB Typ Max Unit - - 400 K/W - - 500 K/W - - 75 K/W [3] [1] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [3] Soldering point of cathode tab. © PMEG3005EB_PMEG3005EL_1 Product data sheet Min [1][2] Rev. 01 — 29 November 2006 Nexperia B.V. 2017. All rights reserved 3 of 10 PMEG3005EB; PMEG3005EL Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol VF IR Cd [1] Parameter Conditions forward voltage reverse current diode capacitance Typ Max Unit IF = 0.1 mA - 90 180 mV IF = 1 mA - 150 200 mV IF = 10 mA - 210 270 mV IF = 100 mA - 295 360 mV IF = 500 mA - 430 500 mV VR = 10 V - 15 200 µA VR = 30 V - 70 500 µA VR = 1 V; f = 1 MHz - 24 30 pF Pulse test: tp ≤ 300 µs; δ ≤ 0.02. © PMEG3005EB_PMEG3005EL_1 Product data sheet Min [1] Rev. 01 — 29 November 2006 Nexperia B.V. 2017. All rights reserved 4 of 10 PMEG3005EB; PMEG3005EL Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers 006aaa855 104 IR (µA) IF (mA) 103 006aaa856 105 (1) 104 (2) 103 (3) 102 102 (4) 10 10 1 (1) (2) (3) (4) (5) 1 10−1 (5) 10−2 10−3 10−1 0 0.2 0.4 0.6 0.8 1.0 0 1.2 1.4 VF (V) 5 10 (1) Tamb = 150 °C (1) Tamb = 150 °C (2) Tamb = 125 °C (2) Tamb = 125 °C (3) Tamb = 85 °C (3) Tamb = 85 °C (4) Tamb = 25 °C (4) Tamb = 25 °C (5) Tamb = −40 °C (5) Tamb = −40 °C Fig 1. Forward current as a function of forward voltage; typical values 15 20 25 30 VR (V) Fig 2. Reverse current as a function of reverse voltage; typical values 006aaa857 40 Cd (pF) 30 20 10 0 0 10 20 30 VR (V) f = 1 MHz; Tamb = 25 °C Fig 3. Diode capacitance as a function of reverse voltage; typical values © PMEG3005EB_PMEG3005EL_1 Product data sheet Rev. 01 — 29 November 2006 Nexperia B.V. 2017. All rights reserved 5 of 10 PMEG3005EB; PMEG3005EL Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers 8. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig 4. Duty cycle definition 9. Package outline 0.85 0.75 0.65 0.58 0.50 0.46 0.62 0.55 1 2 0.30 0.22 1.65 1.25 1.55 1.15 1.02 0.95 0.65 0.30 0.22 1 2 0.34 0.26 0.55 0.47 0.17 0.11 Dimensions in mm 02-12-13 Fig 5. Package outline SOD523 (SC-79) cathode marking on top side Dimensions in mm 03-04-17 Fig 6. Package outline SOD882 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PMEG3005EB PMEG3005EL [1] Package SOD523 SOD882 Description 3000 8000 10000 2 mm pitch, 8 mm tape and reel - -315 - 4 mm pitch, 8 mm tape and reel -115 - -135 2 mm pitch, 8 mm tape and reel - - -315 For further information and the availability of packing methods, see Section 14. © PMEG3005EB_PMEG3005EL_1 Product data sheet Packing quantity Rev. 01 — 29 November 2006 Nexperia B.V. 2017. All rights reserved 6 of 10 PMEG3005EB; PMEG3005EL Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers 11. Soldering 2.15 0.50 0.60 1.20 solder lands solder paste 0.30 0.40 solder resist 1.80 1.90 occupied area mgs343 Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 7. Reflow soldering footprint SOD523 (SC-79) 1.30 R = 0.05 (8×) 0.30 0.60 0.70 0.80 (2×) (2×) (2×) 0.90 solder lands solder paste solder resist R = 0.05 (8×) 0.30 (2×) 0.40 (2×) 0.50 (2×) occupied area mbl872 Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 8. Reflow soldering footprint SOD882 © PMEG3005EB_PMEG3005EL_1 Product data sheet Rev. 01 — 29 November 2006 Nexperia B.V. 2017. All rights reserved 7 of 10 PMEG3005EB; PMEG3005EL Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers 12. Revision history Table 10. Revision history Document ID Release date PMEG3005EB_PMEG3005EL_1 20061129 Data sheet status Change notice Supersedes Product data sheet - - © PMEG3005EB_PMEG3005EL_1 Product data sheet Rev. 01 — 29 November 2006 Nexperia B.V. 2017. All rights reserved 8 of 10 PMEG3005EB; PMEG3005EL Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © PMEG3005EB_PMEG3005EL_1 Product data sheet Rev. 01 — 29 November 2006 Nexperia B.V. 2017. All rights reserved 9 of 10 Nexperia PMEG3005EB; PMEG3005EL 0.5 A very low VF MEGA Schottky barrier rectifiers 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics. . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information. . . . . . . . . . . . . . . . . . . . . . 6 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Contact information. . . . . . . . . . . . . . . . . . . . . . 9 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 29 November 2006
PMEG3005EB,115 价格&库存
很抱歉,暂时无法提供与“PMEG3005EB,115”相匹配的价格&库存,您可以联系我们找货
PMEG3005EB,115
    PMEG3005EB,115
    • 1+4.768621+0.61978
    • 10+2.9465210+0.38296
    • 50+2.1314850+0.27703
    • 100+1.86766100+0.24274
    • 500+1.40129500+0.18213
    PMEG3005EB,115
    • 5+7.64106
    • 10+4.47311
    • 100+2.88320
    • 500+2.13570
    • 1000+1.87467
    • 5000+1.25769
    库存:6
    PMEG3005EB,115
    • 1+2.93761
    • 100+2.79361
    • 300+2.64961
    • 500+2.50561
    • 2000+2.43361
    • 5000+2.39041
    库存:2025
    PMEG3005EB,115
    • 1+3.56585
    • 5+2.87472
    • 10+2.54892
