Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
PMEG4010ETR
High-temperature 40 V, 1 A Schottky barrier rectifier
28 November 2012
Product data sheet
1. Product profile
1.1 General description
Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with an
integrated guard ring for stress protection, encapsulated in a SOD123W small and flat
lead Surface-Mounted Device (SMD) plastic package.
1.2 Features and benefits
• Average forward current: IF(AV) ≤ 1 A
• Reverse voltage: VR ≤ 40 V
• Low forward voltage
• High power capability due to clip-bonding technology
• Small and flat lead SMD plastic package
• AEC-Q101 qualified
• High temperature Tj ≤ 175 °C
1.3 Applications
• Low voltage rectification
• High efficiency DC-to-DC conversion
• Switch mode power supply
• Reverse polarity protection
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IF
forward current
Tsp = 165 °C
1.4
A
IF(AV)
average forward
current
δ = 0.5 ; f = 20 kHz; Tamb ≤ 140 °C;
1
A
1
A
[1]
square wave
δ = 0.5 ; f = 20 kHz; Tsp ≤ 170 °C;
square wave
VR
reverse voltage
Tj = 25 °C
40
V
VF
forward voltage
IF = 1 A; Tj = 25 °C
430
490
mV
IR
reverse current
Tj = 25 °C; VR = 40 V; tp ≤ 300 µs;
10
50
µA
δ ≤ 0.02 ; pulsed
Scan or click this QR code to view the latest information for this product
PMEG4010ETR
NXP Semiconductors
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
trr
reverse recovery time
IR = 0.5 A; IF = 0.5 A; IR(meas) = 0.1 A;
4.4
ns
Tj = 25 °C
[1]
Device mounted on a ceramic Printed-Circuit Board (PCB), Al2O3, standard footprint.
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
K
cathode[1]
2
A
anode
[1]
Simplified outline
1
Graphic symbol
1
2
2
sym001
SOD123W
The marking bar indicates the cathode.
3. Ordering information
Table 3.
Type number
Package
PMEG4010ETR
Name
Description
Version
SOD123W
plastic surface mounted package; 2 leads
SOD123W
4. Marking
Table 4.
Marking codes
Type number
Marking code
PMEG4010ETR
EJ
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VR
reverse voltage
Tj = 25 °C
40
V
IF
forward current
Tsp = 165 °C
1.4
A
IF(AV)
average forward current
1
A
1
A
50
A
[1]
square wave
square wave
IFSM
non-repetitive peak forward
current
PMEG4010ETR
Product data sheet
tp = 8 ms; Tj(init) = 25 °C; square wave
All information provided in this document is subject to legal disclaimers.
28 November 2012
© NXP B.V. 2012. All rights reserved
2 / 13
PMEG4010ETR
NXP Semiconductors
Symbol
Parameter
Conditions
Ptot
total power dissipation
Tamb ≤ 25 °C
Min
Max
Unit
[2]
680
mW
[3]
1150
mW
[1]
2140
mW
Tj
junction temperature
175
°C
Tamb
ambient temperature
-55
175
°C
Tstg
storage temperature
-65
175
°C
[1]
[2]
[3]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
2
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm .
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance
from junction to
ambient
in free air
Rth(j-sp)
thermal resistance
from junction to solder
point
[1]
[2]
[3]
[4]
[5]
Min
Typ
Max
Unit
[1][2]
220
K/W
[1][3]
130
K/W
[1][4]
70
K/W
[5]
18
K/W
For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse
power losses PR are a significant part of the total power losses.
2
Device mounted on a ceramic PCB, Al2O3, standard footprint.
Soldering point of cathode tab.
006aab362
103
duty cycle =
Zth(j-a)
(K/W)
1
102
0.5
0.25
0.1
10
0.02
1
0.75
0.33
0.2
0.05
0.01
10- 3
10- 2
10- 1
1
10
102
tp (s)
103
FR4 PCB, standard footprint
Fig. 1.
Transient thermal impedance from junction to ambient as a function of pulse duration; typical values
PMEG4010ETR
Product data sheet
28 November 2012
3 / 13
PMEG4010ETR
NXP Semiconductors
006aab363
103
Zth(j-a)
(K/W)
duty cycle =
1
102
0.75
0.5
0.25
0.1
10
0.33
0.2
0.05
0.02
0.01
10- 1
10- 3
10- 2
10- 1
FR4 PCB, mounting pad for cathode 1 cm
Fig. 2.
1
102
10
tp (s)
103
2
006aab364
103
Zth(j-a)
(K/W)
duty cycle =
102
10
1
0.5
0.25
0.1
0.02
1
0.75
0.33
0.2
0.05
0.01
10- 3
10- 2
10- 1
1
102
10
tp (s)
103
Ceramic PCB, Al2O3, standard footprint
Fig. 3.
7. Characteristics
Table 7.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VF
forward voltage
IF = 0.1 A; Tj = 25 °C
310
360
mV
430
490
mV
IF = 1 A; Tj = -40 °C
480
570
mV
IF = 1 A; Tj = 125 °C
330
410
mV
IF = 1 A; Tj = 150 °C
310
390
mV
IF = 1 A; Tj = 175 °C
290
370
mV
PMEG4010ETR
Product data sheet
28 November 2012
4 / 13
PMEG4010ETR
NXP Semiconductors
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IR
reverse current
VR = 10 V; tp ≤ 300 µs; δ ≤ 0.02 ;
3
13
µA
10
50
µA
0.05
1
µA
6.5
30
mA
VR = 1 V; f = 1 MHz; Tj = 25 °C
130
pF
VR = 10 V; f = 1 MHz; Tj = 25 °C
50
pF
IF = 0.5 A; IR = 0.5 A; IR(meas) = 0.1 A;
4.4
ns
484
mV
Tj = 25 °C; pulsed
VR = 40 V; tp ≤ 300 µs; δ ≤ 0.02 ;
Tj = 25 °C; pulsed
Tj = -40 °C; pulsed
Tj = 125 °C; pulsed
Cd
diode capacitance
trr
Tj = 25 °C
VFRM
peak forward recovery
voltage
IF = 1 A; dIF/dt = 40 A/µs; Tj = 25 °C
006aad108
10
IR
(A)
(1)
IF
(A)
(2)
1
006aad109
10-1
(1)
10-2
(2)
10-3
(3)
(3)
10-4
10-1
(4)
10-5
(4)
(5)
(6)
10-6
10-2
(5)
10-7
10-8
10-3
10-9
10-4
Fig. 4.
0.4
0.6
0.8
VF (V)
1.0
10-10
(6)
(1) Tj = 175 °C
(1) Tj = 175 °C
(2) Tj = 150 °C
(2) Tj = 150 °C
(3) Tj = 125 °C
(3) Tj = 125 °C
(4) Tj = 85 °C
(4) Tj = 85 °C
(5) Tj = 25 °C
(5) Tj = 25 °C
(6) Tj = −40 °C
(6) Tj = −40 °C
Forward current as a function of forward
voltage; typical values
PMEG4010ETR
Product data sheet
Fig. 5.
30
VR (V)
40
Reverse current as a function of reverse
28 November 2012
5 / 13
PMEG4010ETR
NXP Semiconductors
006aab367
250
006aad111
0.5
PF(AV)
(W)
Cd
(pF)
200
0.4
150
0.3
100
0.2
50
0.1
Fig. 6.
VR (V)
(2)
(1)
f = 1 MHz; Tamb = 25 °C
Tj = 175 °C
Diode capacitance as a function of reverse
(1) δ = 0.1
(2) δ = 0.2
(3) δ = 0.5
(4) δ = 1
Fig. 7.
006aad112
1.2
(4)
(3)
1.0
Average forward power dissipation as a
function of average forward current; typical
values
006aad149
0.3
PR(AV)
(W)
PR(AV)
(W)
0.8
0.2
(1)
0.4
(1)
0.1
(2)
(2)
(3)
(3)
(4)
Fig. 8.
1.5
IF(AV) (A)
VR (V)
(4)
Tj = 150 °C
Tj = 125 °C
(1) δ = 1
(2) δ = 0.5
(3) δ = 0.2
(4) δ = 0.1
(1) δ = 1
(2) δ = 0.5
(3) δ = 0.2
(4) δ = 0.1
Average reverse power dissipation as a
function of reverse voltage; typical values
PMEG4010ETR
Product data sheet
Fig. 9.
30
VR (V)
40
28 November 2012
6 / 13
PMEG4010ETR
NXP Semiconductors
006aad150
30
006aad113
1.5
PR(AV)
(mW)
(1)
IF(AV)
(A)
10
(2)
1.0
(2)
(3)
0.5
(4)
(3)
(4)
VR (V)
Tj = 85 °C
Fig. 10. Average reverse power dissipation as a
006aad114
1.5
Fig. 11. Average forward current as a function of
ambient temperature; typical values
006aad115
(1)
1.0
(3)
(2)
(3)
0.5
(4)
50
100
200
Tamb (°C)
Tj = 175 °C
Fig. 12. Average forward current as a function of
Product data sheet
100
150
200
Tamb (°C)
2
Tj = 175 °C
(1) δ = 1 (DC)
(2) δ = 0.5; f = 20 kHz
(3) δ = 0.2; f = 20 kHz
(4) δ = 0.1; f = 20 kHz
(1) δ = 1 (DC)
PMEG4010ETR
150
200
Tamb (°C)
(1) δ = 1 (DC)
IF(AV)
(A)
(2)
0.5
100
1.5
(1)
1.0
50
Tj = 175 °C
(1) δ = 1
(2) δ = 0.5
(3) δ = 0.2
(4) δ = 0.1
IF(AV)
(A)
Fig. 13. Average forward current as a function of
28 November 2012
7 / 13
PMEG4010ETR
NXP Semiconductors
006aad116
1.5
(1)
IF(AV)
(A)
1.0
(2)
(3)
0.5
(4)
100
150
Tsp (°C)
200
Tj = 175 °C
(1) δ = 1 (DC)
Fig. 14. Average forward current as a function of solder point temperature; typical values
8. Test information
IF
IR(meas)
time
IR
trr
006aad022
Fig. 15. Reverse recovery definition
PMEG4010ETR
Product data sheet
28 November 2012
8 / 13
PMEG4010ETR
NXP Semiconductors
IF
time
VF
VFRM
VF
time
001aab912
Fig. 16. Forward recovery definition
P
tcy
duty cycle δ =
tp
tcy
tp
t
006aac658
Fig. 17. Duty cycle definition
The current ratings for the typical waveforms are calculated according to the equations:
IF(AV) = IM × δ with IM defined as peak current, IRMS = IF(AV) at DC, and IRMS = IM × √δ with
IRMS defined as RMS current.
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
PMEG4010ETR
Product data sheet
28 November 2012
9 / 13
PMEG4010ETR
NXP Semiconductors
9. Package outline
1.9
1.5
1.1
0.9
1
0.6
0.3
3.7
3.3
2.8
2.4
2
1.05
0.75
0.22
0.10
Dimensions in mm
08-11-06
Fig. 18. Package outline SOD123W
10. Soldering
4.4
2.9
2.8
solder lands
1.1 1.2
(2×) (2×)
2.1 1.6
solder resist
solder paste
occupied area
1.1
(2×)
1.2
(2×)
Dimensions in mm
sod123w_fr
Fig. 19. Reflow soldering footprint for SOD123W
11. Revision history
Table 8.
Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PMEG4010ETR v.2
20121128
Product data sheet
PMEG4010ETR v.1
Modifications:
PMEG4010ETR v.1
20120926
PMEG4010ETR
Product data sheet
Table 7. Characteristics: IR value corrected
Product data sheet
28 November 2012
10 / 13
PMEG4010ETR
NXP Semiconductors
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
12. Legal information
12.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nxp.com.
12.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
NXP Semiconductors does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local NXP
Semiconductors sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
12.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, NXP Semiconductors does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. NXP Semiconductors takes no
responsibility for the content in this document if provided by an information
source outside of NXP Semiconductors.
PMEG4010ETR
Product data sheet
Right to make changes — NXP Semiconductors reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This NXP
Semiconductors product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of an NXP Semiconductors product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. NXP Semiconductors and its suppliers accept no liability for
inclusion and/or use of NXP Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using NXP Semiconductors products, and NXP
Semiconductors accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the NXP Semiconductors product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
28 November 2012
11 / 13
PMEG4010ETR
NXP Semiconductors
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
12.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV,
FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE,
ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse,
QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET,
TOPTriac, TrenchMOS, TriMedia and UCODE — are trademarks of NXP
B.V.
HD Radio and HD Radio logo — are trademarks of iBiquity Digital
Corporation.
PMEG4010ETR
Product data sheet
28 November 2012
12 / 13
PMEG4010ETR
NXP Semiconductors
13. Contents
1
1.1
1.2
1.3
1.4
Product profile ....................................................... 1
General description .............................................. 1
Features and benefits ...........................................1
Applications .......................................................... 1
Quick reference data ............................................ 1
2
Pinning information ............................................... 2
3
Ordering information ............................................. 2
4
Marking ................................................................... 2
5
Limiting values .......................................................2
6
Thermal characteristics .........................................3
7
Characteristics ....................................................... 4
8
8.1
Test information ..................................................... 8
Quality information .........................................
9
Package outline ................................................... 10
10
Soldering .............................................................. 10
11
Revision history ................................................... 10
12
12.1
12.2
12.3
12.4
Legal information .................................................11
Data sheet status ............................................... 11
Definitions ...........................................................11
Disclaimers .........................................................11
Trademarks ........................................................ 12
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
Date of release: 28 November 2012
PMEG4010ETR
Product data sheet
28 November 2012
13 / 13
