BAS32L,135
BAS32L,135
    NEXPERIA(安世)
    SOD80C
    开关二极管(小信号) 75V Φ1.60 x 3.70mm SMT SOD80C 200mA
BAS32L,135 数据手册
BAS32L High-speed switching diode Rev. 7 — 20 January 2011 Product data sheet 1. Product profile 1.1 General description Single high-speed switching diode, fabricated in planar technology, and encapsulated in a small hermetically sealed glass SOD80C Surface-Mounted Device (SMD) package. 1.2 Features and benefits „ „ „ „ „ High switching speed: trr ≤ 4 ns Reverse voltage: VR ≤ 75 V Repetitive peak reverse voltage: VRRM ≤ 100 V Repetitive peak forward current: IFRM ≤ 450 mA Small hermetically sealed glass SMD package 1.3 Applications „ High-speed switching „ Reverse polarity protection 1.4 Quick reference data Table 1. Symbol Quick reference data Parameter IF forward current IFRM repetitive peak forward current VR reverse voltage VF forward voltage trr reverse recovery time Conditions [1] IF = 100 mA [2] Min Typ Max Unit - - 200 mA - - 450 mA - - 75 V - - 1000 mV - - 4 ns [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] When switched from IF = 10 mA to IR = 10 mA; RL = 100 Ω; measured at IR = 1 mA. BAS32L Nexperia High-speed switching diode 2. Pinning information Table 2. Pinning Pin Description 1 cathode 2 anode Simplified outline Graphic symbol [1] k a 2 1 006aab040 [1] The marking band indicates the cathode. 3. Ordering information Table 3. Ordering information Type number Package Name Description Version BAS32L - hermetically sealed glass surface-mounted package; 2 connectors SOD80C Table 4. Marking codes 4. Marking Type number Marking code BAS32L marking band 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). BAS32L Product data sheet Symbol Parameter VRRM repetitive peak reverse voltage VR reverse voltage IF forward current IFRM repetitive peak forward current IFSM non-repetitive peak forward current Conditions Min Max Unit - 100 V - 75 V - 200 mA - 450 mA tp = 1 μs - 4 A tp = 1 ms - 1 A tp = 1 s - 0.5 A [1] square wave All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 [2] © Nexperia B.V. 2017. All rights reserved 2 of 11 BAS32L Nexperia High-speed switching diode Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Ptot total power dissipation Tamb = 25 °C - 500 mW Tj junction temperature - 200 °C Tamb ambient temperature −65 +200 °C Tstg storage temperature −65 +200 °C [1] [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [2] Tj = 25 °C prior to surge. 6. Thermal characteristics Table 6. Symbol Thermal characteristics Parameter Conditions Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) thermal resistance from junction to solder point [1] in free air [1] Min Typ Max Unit - - 350 K/W - - 300 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VF forward voltage IF = 5 mA 620 - 750 mV IF = 100 mA - - 1000 mV IF = 100 mA; Tj = 100 °C - - 930 mV VR = 20 V - - 25 nA VR = 75 V - - 5 μA VR = 20 V; Tj = 150 °C - - 50 μA VR = 75 V; Tj = 150 °C - - 100 μA IR Cd BAS32L Product data sheet reverse current diode capacitance VR = 0 V; f = 1 MHz trr reverse recovery time [1] VFR forward recovery voltage [2] - - 2 pF - - 4 ns - - 2.5 V [1] When switched from IF = 10 mA to IR = 10 mA; RL = 100 Ω; measured at IR = 1 mA. [2] When switched from IF = 50 mA; tr = 20 ns. All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 © Nexperia B.V. 2017. All rights reserved 3 of 11 BAS32L Nexperia High-speed switching diode mbg451 300 mbg464 600 IF (mA) IF (mA) 200 400 (1) (2) (3) 200 100 0 0 0 100 0 200 Tamb (°C) 1 VF (V) 2 (1) Tj = 175 °C; typical values FR4 PCB, standard footprint (2) Tj = 25 °C; typical values (3) Tj = 25 °C; maximum values Fig 1. Forward current as a function of ambient temperature; derating curve Fig 2. mbg704 102 Forward current as a function of forward voltage mgd006 103 IR (μA) IFSM (A) 102 10 (1) (2) (3) 10 1 1 10−1 10−1 1 10 102 103 104 10−2 0 100 tp (μs) Based on square wave currents. (1) VR = 75 V; maximum values Tj = 25 °C prior to surge (2) VR = 75 V; typical values Tj (°C) 200 (3) VR = 20 V; typical values Fig 3. Non-repetitive peak forward current as a function of pulse duration; maximum values BAS32L Product data sheet Fig 4. Reverse current as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 © Nexperia B.V. 2017. All rights reserved 4 of 11 BAS32L Nexperia High-speed switching diode mgd004 1.2 Cd (pF) 1.0 0.8 0.6 0.4 0 10 20 VR (V) f = 1 MHz; Tj = 25 °C Fig 5. Diode capacitance as a function of reverse voltage; typical values 8. Test information tr tp t D.U.T. 10 % + IF IF RS = 50 Ω SAMPLING OSCILLOSCOPE trr t Ri = 50 Ω V = VR + IF × RS (1) 90 % VR mga881 input signal output signal Input signal: Reverse pulse rise time tr = 0.6 ns; reverse voltage pulse duration tp = 100 ns; duty factor δ ≤ 0.05 Oscilloscope: Rise time tr = 0.35 ns (1) IR = 1 mA Fig 6. Reverse recovery time test circuit and waveforms I 1 kΩ RS = 50 Ω D.U.T. 450 Ω I V 90 % OSCILLOSCOPE VFR Ri = 50 Ω 10 % t tr t tp input signal output signal mga882 Input signal: Forward pulse rise time tr = 20 ns; forward current pulse duration tp ≥ 100 ns; duty factor δ ≤ 0.005 Fig 7. Forward recovery voltage test circuit and waveforms BAS32L Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 © Nexperia B.V. 2017. All rights reserved 5 of 11 BAS32L Nexperia High-speed switching diode 9. Package outline 0.3 0.3 1.60 1.45 3.7 3.3 Dimensions in mm Fig 8. 06-03-16 Package outline SOD80C 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number BAS32L [1] BAS32L Product data sheet Package SOD80C Description 4 mm pitch, 8 mm tape and reel Packing quantity 2500 10000 -115 -135 For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 © Nexperia B.V. 2017. All rights reserved 6 of 11 BAS32L Nexperia High-speed switching diode 11. Soldering 4.55 4.30 2.30 solder lands solder paste 2.25 1.70 1.60 solder resist occupied area Dimensions in mm 0.90 (2x) Fig 9. sod080c Reflow soldering footprint SOD80C 6.30 4.90 2.70 1.90 solder lands solder resist occupied area 2.90 1.70 tracks Dimensions in mm sod080c Fig 10. Wave soldering footprint SOD80C BAS32L Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 © Nexperia B.V. 2017. All rights reserved 7 of 11 BAS32L Nexperia High-speed switching diode 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes BAS32L v.7 20110120 Product data sheet - BAS32L v.6 Modifications: • • Table 4 “Marking codes”: amended Section 13 “Legal information”: updated BAS32L v.6 20081029 Product data sheet - BAS32L v.5 BAS32L v.5 20080103 Product data sheet - BAS32L v.4 BAS32L v.4 20050322 Product data sheet - BAS32L v.3 BAS32L v.3 20020123 Product specification - BAS32L v.2 BAS32L v.2 19960910 Product specification - BAS32L v.1 BAS32L v.1 19960423 Product specification - - BAS32L Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 © Nexperia B.V. 2017. All rights reserved 8 of 11 BAS32L Nexperia High-speed switching diode 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. BAS32L Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 © Nexperia B.V. 2017. All rights reserved 9 of 11 BAS32L Nexperia High-speed switching diode Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com BAS32L Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 20 January 2011 © Nexperia B.V. 2017. All rights reserved 10 of 11 Nexperia BAS32L High-speed switching diode 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information . . . . . . . . . . . . . . . . . . . . . 6 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 January 2011
BAS32L,135
1. 物料型号:该元件的型号是MPU6050,是一款6轴运动处理单元,集成了3轴陀螺仪和3轴加速度计。
2. 器件简介:MPU6050能够测量和报告加速度(±2g)、旋转(±250dps)以及X、Y、Z轴的倾斜。它广泛应用于智能手机、平板电脑、航模、机器人等。
3. 引脚分配:MPU6050有17个引脚,包括电源、地、I2C通信、中断输出、FSYNC、AD0/SDA、AD1/SCL等。
4. 参数特性:加速度测量范围±2g/±4g/±8g/±16g,陀螺仪测量范围±250°/s/±500°/s/±1000°/s/±2000°/s。工作电压2.0V至3.6V,I2C接口,支持多达20ms的FIFO缓存。
5. 功能详解:MPU6050能够提供加速度、陀螺仪和温度数据,支持数字运动处理器(DMP)以实现复杂算法,如行人检测、自由落体检测等。
6. 应用信息:适用于需要精确运动跟踪的各种应用,如智能手机、平板电脑、可穿戴设备、游戏控制器、稳定系统等。
BAS32L,135 价格&库存
很抱歉,暂时无法提供与“BAS32L,135”相匹配的价格&库存,您可以联系我们找货
BAS32L,135
  • 10000+0.1739010000+0.02257
  • 20000+0.1555720000+0.02019
  • 30000+0.1462230000+0.01898
  • 50000+0.1357150000+0.01761
  • 70000+0.1294770000+0.01680
  • 100000+0.12341100000+0.01602
库存:43035
BAS32L,135
    • 12048+0.1043012048+0.01360
    库存:91678
