PMEG3010CEH; PMEG3010CEJ
1 A very low VF MEGA Schottky barrier rectifiers
Rev. 02 — 22 March 2007
Product data sheet
1. Product profile
1.1 General description
Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifiers with an
integrated guard ring for stress protection, encapsulated in small and flat lead
Surface-Mounted Device (SMD) plastic packages.
Table 1.
Product overview
Type number
Package
Configuration
Nexperia
JEITA
PMEG3010CEH
SOD123F
single
PMEG3010CEJ
SOD323F
SC-90
single
1.2 Features
n
n
n
n
Forward current: IF ≤ 1 A
Reverse voltage: VR ≤ 30 V
Very low forward voltage
Small and flat lead SMD plastic packages
1.3 Applications
n
n
n
n
n
Low voltage rectification
High efficiency DC-to-DC conversion
Switch mode power supply
Reverse polarity protection
Low power consumption applications
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
IF
forward current
Tsp ≤ 55 °C
1
A
VR
reverse voltage
30
V
450
520
mV
VF
[1]
forward voltage
Pulse test: tp ≤ 300 µs; δ ≤ 0.02.
IF = 1 A
[1]
Nexperia
2. Pinning information
Table 3.
Pinning
Pin
Description
1
cathode
2
anode
Simplified outline
Symbol
[1]
1
1
2
2
sym001
001aab540
[1]
The marking bar indicates the cathode.
3. Ordering information
Table 4.
Type number
Package
Name
Description
Version
PMEG3010CEH
plastic surface-mounted package; 2 leads
SOD123F
PMEG3010CEJ
SC-90
SOD323F
4. Marking
Table 5.
Marking codes
Type number
Marking code
PMEG3010CEH
C8
PMEG3010CEJ
EN
PMEG3010CEH_PMEG3010CEJ_2
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 10
Nexperia
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VR
reverse voltage
30
V
IF
forward current
IFRM
repetitive peak forward current
Tsp ≤ 55 °C
1
A
tp ≤ 1 ms;
δ ≤ 0.25
7
A
IFSM
non-repetitive peak forward
current
square wave;
tp = 8 ms
PMEG3010CEH
9
A
PMEG3010CEJ
10
A
[1]
375
mW
[2]
830
mW
[1]
350
mW
[2]
830
mW
total power dissipation
Ptot
Tamb ≤ 25 °C
PMEG3010CEH
PMEG3010CEJ
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2.
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from
junction to ambient
in free air
Min
Typ
Max
Unit
[2]
330
K/W
[3]
150
K/W
[2]
350
K/W
[3]
150
K/W
PMEG3010CEH
60
K/W
PMEG3010CEJ
55
K/W
PMEG3010CEH
PMEG3010CEJ
Rth(j-sp)
junction to solder point
[4]
[1]
For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse
power losses PR are a significant part of the total power losses.
[2]
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
[3]
[4]
Soldering point of cathode tab.
Product data sheet
[1]
3 of 10
Nexperia
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
VF
IR
Cd
[1]
Parameter
Conditions
Min
Typ
Max
Unit
IF = 1 mA
200
240
mV
IF = 10 mA
260
310
mV
IF = 100 mA
330
390
mV
IF = 500 mA
400
440
mV
[1]
forward voltage
reverse current
diode capacitance
IF = 700 mA
420
450
mV
IF = 1 A
450
520
mV
VR = 5 V
1.2
µA
VR = 10 V
1.8
µA
VR = 30 V
10
50
µA
VR = 1 V; f = 1 MHz
90
100
pF
Product data sheet
4 of 10
Nexperia
006aaa752
104
IF
(mA)
103
102
006aaa753
105
(1)
(2)
(3)
(4)
(5)
4
IR 10
(µA)
103
(1)
102
(3)
(2)
10
(4)
1
10
10−1
10−2
1
(5)
10−3
10−1
0.0
10−4
0.2
0.4
0.6
VF (V)
VR (V)
(1) Tamb = 150 °C
(1) Tamb = 150 °C
(2) Tamb = 125 °C
(2) Tamb = 125 °C
(3) Tamb = 85 °C
(3) Tamb = 85 °C
(4) Tamb = 25 °C
(4) Tamb = 25 °C
(5) Tamb = −40 °C
(5) Tamb = −40 °C
Fig 1. Forward current as a function of forward
voltage; typical values
Fig 2. Reverse current as a function of reverse
006aaa754
200
Cd
(pF)
160
120
80
40
VR (V)
f = 1 MHz; Tamb = 25 °C
Fig 3. Diode capacitance as a function of reverse voltage; typical values
Product data sheet
5 of 10
Nexperia
8. Test information
P
t2
duty cycle δ =
t1
t2
t1
t
006aaa812
Fig 4. Duty cycle definition
9. Package outline
1.7
1.5
1.2
1.0
1.35
1.15
1
0.80
0.65
0.5
0.3
1
0.55
0.35
3.6
3.4
2.7
2.3
2.7
2.5
1.8
1.6
2
2
0.70
0.55
Dimensions in mm
0.25
0.10
0.40
0.25
0.25
0.10
04-11-29
Fig 5. Package outline SOD123F
Dimensions in mm
04-09-13
Fig 6. Package outline SOD323F (SC-90)
10. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
Package
Description
PMEG3010CEH
SOD123F
4 mm pitch, 8 mm tape and reel
PMEG3010CEJ
SOD323F
[1]
3000
10000
-115
-135
For further information and the availability of packing methods, see Section 14.
Product data sheet
Packing quantity
6 of 10
Nexperia
11. Soldering
4.4
4
2.9
1.6
solder lands
solder resist
2.1 1.6
1.1 1.2
solder paste
occupied area
1.1
(2×)
Reflow soldering is the only recommended soldering method.
Dimensions in mm
Fig 7. Reflow soldering footprint SOD123F
3.05
2.80
2.10
1.60
solder lands
solder resist
1.65
0.95
0.50
0.60
occupied area
solder paste
0.50
(2×)
001aab169
Dimensions in mm
Fig 8. Reflow soldering footprint SOD323F (SC-90)
Product data sheet
7 of 10
Nexperia
12. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
20070322
Product data sheet
PMEG3010CEJ_1
Modifications:
PMEG3010CEJ_1
The format of this data sheet has been redesigned to comply with the new
identity guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Type number PMEG3010CEH added
Section 1.1 “General description”: amended
Table 1 “Product overview”: added
Table 7 “Thermal characteristics”: Table note 1 amended
Table 8 “Characteristics”: VF forward voltage maximum values amended
Section 8 “Test information”: added
20060411
Product data sheet
Product data sheet
8 of 10
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected to
result in personal injury, death or severe property or environmental damage.
Nexperia accepts no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore
such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
Product data sheet
9 of 10
Nexperia
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics. . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6
Packing information. . . . . . . . . . . . . . . . . . . . . . 6
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Contact information. . . . . . . . . . . . . . . . . . . . . . 9
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 22 March 2007
很抱歉,暂时无法提供与“PMEG3010CEJ,115”相匹配的价格&库存,您可以联系我们找货
