PMEG1020EA,115
PMEG1020EA,115
    NEXPERIA(安世)
    SOD-323
    直流反向耐压(Vr):10V 平均整流电流(Io):2A 正向压降(Vf):460mV@2A
PMEG1020EA,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PMEG1020EA 2 A ultra low VF MEGA Schottky barrier rectifier Rev. 04 — 30 December 2008 Product data sheet 1. Product profile 1.1 General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with an integrated guard ring for stress protection, encapsulated in SOD323 (SC-76) very small Surface-Mounted Device (SMD) plastic package. 1.2 Features n n n n Forward current: IF ≤ 2 A Reverse voltage: VR ≤ 10 V Ultra low forward voltage Very small SMD plastic package 1.3 Applications n n n n n Low voltage rectification High efficiency DC-to-DC conversion Switch Mode Power Supply (SMPS) Reverse polarity protection Low power consumption applications 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF forward current Tsp ≤ 55 °C - - 2 A VR reverse voltage - - 10 V VF forward voltage - 280 350 mV [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. IF = 1 A [1] PMEG1020EA NXP Semiconductors 2 A ultra low VF MEGA Schottky barrier rectifier 2. Pinning information Table 2. Pinning Pin Description 1 cathode 2 anode Simplified outline Graphic symbol [1] 1 1 2 2 sym001 [1] The marking bar indicates the cathode. 3. Ordering information Table 3. Ordering information Type number PMEG1020EA Package Name Description Version SC-76 plastic surface-mounted package; 2 leads SOD323 4. Marking Table 4. Marking codes Type number Marking code PMEG1020EA E2 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage - 10 V IF forward current IFRM repetitive peak forward current Tsp ≤ 55 °C - 2 A tp ≤ 1 ms; δ ≤ 0.5 - 3.2 A IFSM non-repetitive peak forward current square wave; tp = 8 ms - 9 A Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C PMEG1020EA_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 30 December 2008 2 of 9 PMEG1020EA NXP Semiconductors 2 A ultra low VF MEGA Schottky barrier rectifier 6. Thermal characteristics Table 6. Symbol Rth(j-a) Rth(j-sp) Thermal characteristics Parameter Conditions thermal resistance from junction to ambient in free air thermal resistance from junction to solder point Min Typ Max Unit [1] - - 450 K/W [2] - - 210 K/W [3] - - 90 K/W [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB with copper clad 10 × 10 mm. [3] Soldering point of cathode tab. 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol VF Parameter Conditions Min forward voltage Cd - 100 130 mV - 170 200 mV IF = 1 A - 280 350 mV - 350 460 mV VR = 5 V - 0.7 2 mA VR = 8 V - 1 2.5 mA VR = 10 V - 1.2 3 mA VR = 5 V; f = 1 MHz - 37 45 pF [2] [1] Pulse test: tp ≤ 300 µs; δ ≤ 0.02. [2] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. PMEG1020EA_4 Product data sheet Unit IF = 0.1 A reverse current diode capacitance Max IF = 0.01 A IF = 2 A IR Typ [1] © NXP B.V. 2009. All rights reserved. Rev. 04 — 30 December 2008 3 of 9 PMEG1020EA NXP Semiconductors 2 A ultra low VF MEGA Schottky barrier rectifier mdb194 104 mdb195 105 IR (µA) IF (mA) (1) 104 103 103 (1) 102 (2) (2) (3) 102 10 10 (3) 1 0 100 200 300 1 400 500 VF (mV) 0 2 6 8 10 VR (V) (1) Tamb = 85 °C (1) Tamb = 85 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = −40 °C (3) Tamb = −40 °C Fig 1. 4 Forward current as a function of forward voltage; typical values Fig 2. Reverse current as a function of reverse voltage; typical values mdb196 120 Cd (pF) 100 80 60 40 20 0 2 4 6 10 8 VR (V) f = 1 MHz; Tamb = 25 °C Fig 3. Diode capacitance as a function of reverse voltage; typical values PMEG1020EA_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 30 December 2008 4 of 9 PMEG1020EA NXP Semiconductors 2 A ultra low VF MEGA Schottky barrier rectifier 8. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig 4. Duty cycle definition 9. Package outline 1.35 1.15 1.1 0.8 0.45 0.15 1 2.7 2.3 1.8 1.6 2 0.40 0.25 Dimensions in mm Fig 5. 0.25 0.10 03-12-17 Package outline SOD323 (SC-76) 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description PMEG1020EA SOD323 [1] 4 mm pitch, 8 mm tape and reel 3000 10000 -115 -135 For further information and the availability of packing methods, see Section 14. PMEG1020EA_4 Product data sheet Packing quantity © NXP B.V. 2009. All rights reserved. Rev. 04 — 30 December 2008 5 of 9 PMEG1020EA NXP Semiconductors 2 A ultra low VF MEGA Schottky barrier rectifier 11. Soldering 3.05 2.1 solder lands solder resist 0.5 (2×) 1.65 0.95 0.6 (2×) solder paste occupied area 2.2 Dimensions in mm 0.5 (2×) 0.6 (2×) Fig 6. sod323_fr Reflow soldering footprint SOD323 (SC-76) 5 2.9 1.5 (2×) solder lands solder resist occupied area 2.75 1.2 (2×) Dimensions in mm preferred transport direction during soldering sod323_fw Fig 7. Wave soldering footprint SOD323 (SC-76) PMEG1020EA_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 30 December 2008 6 of 9 PMEG1020EA NXP Semiconductors 2 A ultra low VF MEGA Schottky barrier rectifier 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PMEG1020EA_4 20081230 Product data sheet - PMEG1020EA_3 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Section 13 “Legal information”: updated PMEG1020EA_3 20040206 Product specification - PMEG1020EA_2 PMEG1020EA_2 20030715 Product specification - PMEG1020EA_1 PMEG1020EA_1 20030307 Preliminary specification - - PMEG1020EA_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 30 December 2008 7 of 9 PMEG1020EA NXP Semiconductors 2 A ultra low VF MEGA Schottky barrier rectifier 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PMEG1020EA_4 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 04 — 30 December 2008 8 of 9 PMEG1020EA NXP Semiconductors 2 A ultra low VF MEGA Schottky barrier rectifier 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description. . . . . . . . . . . . . . . . . . . . . . Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data. . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics. . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Test information . . . . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information. . . . . . . . . . . . . . . . . . . . . . Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . . Contact information. . . . . . . . . . . . . . . . . . . . . . Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 2 2 2 2 3 3 5 5 5 6 7 8 8 8 8 8 8 9 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 30 December 2008 Document identifier: PMEG1020EA_4
PMEG1020EA,115 价格&库存
很抱歉,暂时无法提供与“PMEG1020EA,115”相匹配的价格&库存,您可以联系我们找货
PMEG1020EA,115
  • 1+0.36060
库存:3
PMEG1020EA,115
  • 5+0.74393
  • 20+0.67829
  • 100+0.61265
  • 500+0.54700
  • 1000+0.51637
  • 2000+0.49449
PMEG1020EA,115
  • 1+3.964341+0.51216
  • 10+2.4148410+0.31198
  • 100+1.52457100+0.19697
  • 500+1.13632500+0.14681
  • 1000+1.010741000+0.13058
PMEG1020EA,115
    • 3000+0.71150
    • 15000+0.70440
