PMEG3005ET,215
PMEG3005ET,215
    NEXPERIA(安世)
    SOT-23
    直流反向耐压(Vr):30V 平均整流电流(Io):500mA 正向压降(Vf):430mV@500mA
PMEG3005ET,215 数据手册
PMEGxx05ET series 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package Rev. 02 — 13 January 2010 Product data sheet 1. Product profile 1.1 General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with an integrated guard ring for stress protection, encapsulated in a SOT23 small Surface Mounted Device (SMD) plastic package. Table 1. Product overview Type number Package Nexperia JEITA PMEG2005ET SOT23 - single diode PMEG3005ET SOT23 - single diode PMEG4005ET SOT23 - single diode 1.2 Features „ Forward current: 0.5 A „ Very low forward voltage „ Small SMD plastic package 1.3 Applications „ „ „ „ „ Low voltage rectification High efficiency DC-to-DC conversion Switch mode power supply Inverse polarity protection Low power consumption applications Configuration PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter IF forward current VR reverse voltage Conditions Min Typ Max Unit - - 0.5 A PMEG2005ET - - 20 V PMEG3005ET - - 30 V - - 40 V PMEG2005ET - 355 390 mV PMEG3005ET - 380 430 mV PMEG4005ET - 420 470 mV PMEG4005ET forward voltage VF [1] [1] IF = 500 mA Pulse test: tp ≤ 300 μs; δ ≤ 0.02. 2. Pinning information Table 3. Pinning Pin Description 1 anode 2 not connected 3 cathode Simplified outline Symbol 3 2 n.c. 1 1 3 2 mlc357 3. Ordering information Table 4. Ordering information Type number Package Name Description Version PMEG2005ET - plastic surface mounted package; 3 leads SOT23 PMEG3005ET - plastic surface mounted package; 3 leads SOT23 PMEG4005ET - plastic surface mounted package; 3 leads SOT23 © PMEGXX05ET_SER_2 Product data sheet Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 2 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 4. Marking Table 5. Marking codes Type number Marking code[1] PMEG2005ET P3* PMEG3005ET P4* PMEG4005ET P5* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit PMEG2005ET - 20 V PMEG3005ET - 30 V PMEG4005ET - 40 V reverse voltage VR IF forward current - 0.5 A IFRM repetitive peak forward current tp ≤ 1 ms; δ ≤ 0.5 - 3.9 A - 10 A IFSM non-repetitive peak forward current tp = 8 ms square wave [1] Ptot total power dissipation Tamb ≤ 25 °C [1] - 280 mW [2] - 420 mW Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Rth(j-a) Conditions thermal resistance from junction to ambient in free air Typ Max Unit - - 440 K/W [1][3] - - 300 K/W [1] For Schottky barrier diodes thermal run-away has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. Nomograms for determining the reverse power losses PR and IF(AV) rating will be available on request. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. © PMEGXX05ET_SER_2 Product data sheet Min [1][2] Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 3 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol VF Parameter Conditions PMEG3005ET PMEG4005ET Unit IF = 0.1 mA - 90 130 mV IF = 1 mA - 150 190 mV IF = 10 mA - 210 240 mV IF = 100 mA - 280 330 mV IF = 500 mA - 355 390 mV IF = 0.1 mA - 90 130 mV IF = 1 mA - 150 200 mV IF = 10 mA - 215 250 mV IF = 100 mA - 285 340 mV IF = 500 mA - 380 430 mV IF = 0.1 mA - 95 130 mV IF = 1 mA - 155 210 mV IF = 10 mA - 220 270 mV - 295 350 mV IF = 500 mA - 420 470 mV VR = 10 V - 15 40 μA VR = 20 V - 40 200 μA VR = 10 V - 12 30 μA VR = 30 V - 40 150 μA VR = 10 V - 7 20 μA VR = 40 V - 30 100 μA PMEG2005ET - 66 80 pF PMEG3005ET - 55 70 pF PMEG4005ET - 43 50 pF reverse current PMEG3005ET PMEG4005ET [1] Max IF = 100 mA PMEG2005ET Cd Typ forward voltage PMEG2005ET IR Min [1] diode capacitance VR = 1 V; f = 1 MHz Pulse test: tp ≤ 300 μs; δ ≤ 0.02. © PMEGXX05ET_SER_2 Product data sheet Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 4 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 006aaa517 104 IR (μA) IF (mA) 103 006aaa518 105 (1) 104 (2) 103 (3) 102 (4) 102 10 1 (1) (2) (3) (4) (5) 10−1 10 (5) 10−2 10−3 1 0 0.2 0.4 0 0.6 5 10 15 (1) Tamb = 150 °C (1) Tamb = 150 °C (2) Tamb = 125 °C (2) Tamb = 125 °C (3) Tamb = 85 °C (3) Tamb = 85 °C (4) Tamb = 25 °C (4) Tamb = 25 °C (5) Tamb = −40 °C (5) Tamb = −40 °C Fig 1. 20 VR (V) VF (V) PMEG2005ET: Forward current as a function of forward voltage; typical values Fig 2. PMEG2005ET: Reverse current as a function of reverse voltage; typical values 006aaa249 120 Cd (pF) 80 40 0 0 4 8 12 16 20 VR (V) Tamb = 25 °C; f = 1 MHz Fig 3. PMEG2005ET: Diode capacitance as a function of reverse voltage; typical values © PMEGXX05ET_SER_2 Product data sheet Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 5 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 006aaa519 104 IR (μA) IF (mA) 006aaa520 105 (1) (2) 104 (3) 103 103 102 (4) 102 10 1 (1) (2) (3) (4) (5) 10−1 10 (5) 10−2 10−3 1 0 0.2 0.4 0.6 0 0.8 5 10 15 20 25 30 VR (V) VF (V) (1) Tamb = 150 °C (1) Tamb = 150 °C (2) Tamb = 125 °C (2) Tamb = 125 °C (3) Tamb = 85 °C (3) Tamb = 85 °C (4) Tamb = 25 °C (4) Tamb = 25 °C (5) Tamb = −40 °C (5) Tamb = −40 °C Fig 4. PMEG3005ET: Forward current as a function of forward voltage; typical values Fig 5. PMEG3005ET: Reverse current as a function of reverse voltage; typical values 006aaa252 120 Cd (pF) 80 40 0 0 10 20 30 VR (V) Tamb = 25 °C; f = 1 MHz Fig 6. PMEG3005ET: Diode capacitance as a function of reverse voltage; typical values © PMEGXX05ET_SER_2 Product data sheet Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 6 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 006aaa521 104 IR (μA) IF (mA) 103 006aaa522 105 (1) 104 (2) 103 (3) 102 (4) 102 10 1 (1) (2) (3) (4) (5) 10−1 10 (5) 10−2 10−3 1 0 0.2 0.4 0.6 0.8 0 1.0 10 20 30 (1) Tamb = 150 °C (1) Tamb = 150 °C (2) Tamb = 125 °C (2) Tamb = 125 °C (3) Tamb = 85 °C (3) Tamb = 85 °C (4) Tamb = 25 °C (4) Tamb = 25 °C (5) Tamb = −40 °C (5) Tamb = −40 °C Fig 7. 40 VR (V) VF (V) PMEG4005ET: Forward current as a function of forward voltage; typical values Fig 8. PMEG4005ET: Reverse current as a function of reverse voltage; typical values 006aaa255 100 Cd (pF) 80 60 40 20 0 0 10 20 30 40 VR (V) Tamb = 25 °C; f = 1 MHz Fig 9. PMEG4005ET: Diode capacitance as a function of reverse voltage; typical values © PMEGXX05ET_SER_2 Product data sheet Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 7 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 8. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 0.48 0.38 0.15 0.09 Dimensions in mm 04-11-04 Fig 10. Package outline SOT23 (TO-236AB) 9. Packing information Table 9. Packing methods The -xxx numbers are the last three digits of the 12NC ordering code.[1] Type number PMEG2005ET Package SOT23 Description 4 mm pitch, 8 mm tape and reel Packing quantity 3000 10000 -215 -235 PMEG3005ET PMEG4005ET [1] For further information and the availability of packing methods, see Section 13. © PMEGXX05ET_SER_2 Product data sheet Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 8 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 10. Soldering 2.90 2.50 solder lands solder resist 2 0.85 1 2.70 1.30 3.00 0.85 3 occupied area solder paste 0.60 (3x) 0.50 (3x) 0.60 (3x) 1.00 3.30 MSA439 Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 11. Reflow soldering footprint SOT23 (TO-236AB) © PMEGXX05ET_SER_2 Product data sheet Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 9 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 11. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PMEGXX05ET_SER_2 20100113 Product data sheet - PMEGXX05ET_SER_1 Modifications: PMEGXX05ET_SER_1 • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. • Figure 11 “Reflow soldering footprint SOT23 (TO-236AB)”: updated 20050715 Product data sheet - © PMEGXX05ET_SER_2 Product data sheet - Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 10 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 12. Legal information 12.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 12.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 12.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 12.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 13. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © PMEGXX05ET_SER_2 Product data sheet Rev. 02 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 11 of 12 PMEGxx05ET series Nexperia 0.5 A very low VF MEGA Schottky barrier rectifiers in SOT23 package 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 12.1 12.2 12.3 12.4 13 14 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Packing information . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 January 2010
PMEG3005ET,215 价格&库存
很抱歉,暂时无法提供与“PMEG3005ET,215”相匹配的价格&库存,您可以联系我们找货
PMEG3005ET,215
    PMEG3005ET,215
    • 1+0.36880
    • 200+0.34820
    库存:2131
    PMEG3005ET,215
    • 30+3.5873730+0.46625
    • 100+2.28421100+0.29688
    • 500+1.65712500+0.21538
    • 1000+1.518721000+0.19739
    • 3000+0.748343000+0.09727
    库存:10
    PMEG3005ET,215
    • 3000+0.698213000+0.09075
    • 9000+0.595099000+0.07735
    库存:3355
