MMBD4148
High-speed switching diode
Rev. 01 — 4 June 2009
Product data sheet
1. Product profile
1.1 General description
High-speed switching diode, encapsulated in a small SOT23 (TO-236AB)
Surface-Mounted Device (SMD) plastic package.
1.2 Features
n High switching speed: trr ≤ 4 ns
n Low leakage current
n Repetitive peak reverse voltage:
VRRM ≤ 75 V
n Low capacitance
n Reverse voltage: VR ≤ 75 V
n Small SMD plastic package
1.3 Applications
n High-speed switching
n General-purpose switching
1.4 Quick reference data
Table 1.
Symbol
Parameter
VR
reverse voltage
IR
reverse current
VR = 75 V
[1]
reverse recovery time
trr
[1]
Conditions
Min
Typ
Max
Unit
75
V
0.5
µA
4
ns
When switched from IF = 10 mA to IR = 10 mA; RL = 100 Ω; measured at IR = 1 mA.
2. Pinning information
Table 2.
Pinning
Pin
Description
1
anode
2
not connected
3
cathode
Simplified outline
Graphic symbol
3
3
1
1
2
2
006aaa764
MMBD4148
Nexperia
3. Ordering information
Table 3.
Type number
MMBD4148
Package
Name
Description
Version
plastic surface-mounted package; 3 leads
SOT23
4. Marking
Table 4.
Marking codes
Type number
Marking code[1]
MMBD4148
A6*
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VRRM
repetitive peak reverse
voltage
Conditions
VR
reverse voltage
[1]
IF
forward current
IFRM
repetitive peak forward
current
tp ≤ 0.5 µs;
δ ≤ 0.25
IFSM
non-repetitive peak forward
current
square wave
Max
Unit
75
V
75
V
215
mA
500
mA
[2]
tp = 1 µs
4
A
tp = 1 ms
1
A
0.5
A
250
mW
tp = 1 s
Tamb ≤ 25 °C
[1]
Ptot
total power dissipation
Tj
junction temperature
150
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
[2]
Tj = 25 °C prior to surge.
MMBD4148
Product data sheet
Min
© Nexperia B.V. 2009. All rights reserved.
2 of 10
MMBD4148
Nexperia
6. Thermal characteristics
Table 6.
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from
junction to ambient
Rth(j-t)
junction to tie-point
[1]
in free air
[1]
Min
Typ
Max
Unit
500
K/W
330
K/W
Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint.
7. Characteristics
Table 7.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
VF
forward voltage
IR
Cd
trr
VFR
[1]
Conditions
reverse current
diode capacitance
Min
Typ
Max
Unit
IF = 1 mA
715
mV
IF = 10 mA
855
mV
IF = 50 mA
1
V
IF = 150 mA
1.25
V
VR = 25 V
30
nA
VR = 75 V
0.5
µA
VR = 25 V; Tj = 150 °C
30
µA
VR = 75 V; Tj = 150 °C
50
µA
[1]
f = 1 MHz; VR = 0 V
1.5
pF
[2]
4
ns
forward recovery voltage
[3]
1.75
V
Pulse test: tp ≤ 300 µs; δ ≤ 0.02.
[2]
[3]
When switched from IF = 10 mA; tr = 20 ns.
MMBD4148
Product data sheet
3 of 10
MMBD4148
Nexperia
006aab132
103
mbg704
102
IF
(mA)
IFSM
(A)
102
10
10
1
(1)
(2)
(3)
(4)
1
10−1
10−1
0.4
0.6
0.8
1.0
1
1.2
1.4
VF (V)
10
102
103
104
tp (µs)
(1) Tamb = 150 °C
Based on square wave currents.
(2) Tamb = 85 °C
Tj = 25 °C; prior to surge
(3) Tamb = 25 °C
(4) Tamb = −40 °C
Fig 1.
Forward current as a function of forward
voltage; typical values
Fig 2.
006aab133
102
IR
(µA)
10
(1)
1
(2)
Non-repetitive peak forward current as a
function of pulse duration; maximum values
mbg446
0.8
Cd
(pF)
0.6
10−1
0.4
(3)
10−2
10−3
0.2
10−4
(4)
10−5
60
80
4
8
VR (V)
(1) Tamb = 150 °C
12
VR (V)
16
f = 1 MHz; Tamb = 25 °C
(2) Tamb = 85 °C
(3) Tamb = 25 °C
(4) Tamb = −40 °C
Fig 3.
Reverse current as a function of reverse
Fig 4.
Diode capacitance as a function of reverse
MMBD4148
Product data sheet
4 of 10
MMBD4148
Nexperia
8. Test information
tr
tp
t
D.U.T.
10 %
+ IF
IF
RS = 50 Ω
SAMPLING
OSCILLOSCOPE
V = VR + IF × RS
trr
t
Ri = 50 Ω
(1)
90 %
VR
mga881
input signal
output signal
(1) IR = 1 mA
Input signal: reverse pulse rise time tr = 0.6 ns; reverse voltage pulse duration tp = 100 ns; duty cycle δ = 0.05
Oscilloscope: rise time tr = 0.35 ns
Fig 5.
Reverse recovery time test circuit and waveforms
I
1 kΩ
RS = 50 Ω
D.U.T.
450 Ω
I
V
90 %
OSCILLOSCOPE
VFR
Ri = 50 Ω
10 %
t
tr
t
tp
input signal
output signal
mga882
Input signal: forward pulse rise time tr = 20 ns; forward current pulse duration tp ≥ 100 ns; duty cycle δ ≤ 0.005
Fig 6.
Forward recovery voltage test circuit and waveforms
MMBD4148
Product data sheet
5 of 10
MMBD4148
Nexperia
9. Package outline
3.0
2.8
1.1
0.9
3
0.45
0.15
2.5 1.4
2.1 1.2
1
2
1.9
0.48
0.38
Dimensions in mm
Fig 7.
0.15
0.09
04-11-04
Package outline MMBD4148 (SOT23/TO-236AB)
10. Packing information
Please refer to packing information on www.nexperia.com.
MMBD4148
Product data sheet
6 of 10
MMBD4148
Nexperia
11. Soldering
3.3
2.9
1.9
solder lands
solder resist
3
2
1.7
solder paste
occupied area
0.6
(3×)
0.7
(3×)
Dimensions in mm
0.5
(3×)
0.6
(3×)
1
Fig 8.
sot023_fr
Reflow soldering footprint MMBD4148 (SOT23/TO-236AB)
2.2
1.2
(2×)
1.4
(2×)
solder lands
4.6
solder resist
2.6
occupied area
Dimensions in mm
1.4
preferred transport direction during soldering
2.8
4.5
Fig 9.
Wave soldering footprint MMBD4148 (SOT23/TO-236AB)
MMBD4148
Product data sheet
sot023_fw
7 of 10
MMBD4148
Nexperia
12. Revision history
Table 9.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
MMBD4148_1
20090604
Product data sheet
MMBD4148
Product data sheet
8 of 10
MMBD4148
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness of such information
Right to make changes — Nexperia reserves the right to make changes to
information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in medical, military, aircraft, space or life
support equipment, nor in applications where failure or malfunction of an
Nexperia product can reasonably be expected to result in personal injury,
death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore such inclusion and/
or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold subject to the
general terms and conditions of commercial sale, as published at http://
www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of any
inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from national authorities.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
MMBD4148
Product data sheet
9 of 10
MMBD4148
Nexperia
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
13
13.1
13.2
13.3
13.4
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . .
General description. . . . . . . . . . . . . . . . . . . . . .
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . .
Quick reference data. . . . . . . . . . . . . . . . . . . . .
Pinning information . . . . . . . . . . . . . . . . . . . . . .
Ordering information . . . . . . . . . . . . . . . . . . . . .
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . .
Thermal characteristics. . . . . . . . . . . . . . . . . . .
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . .
Test information . . . . . . . . . . . . . . . . . . . . . . . . .
Package outline . . . . . . . . . . . . . . . . . . . . . . . . .
Packing information. . . . . . . . . . . . . . . . . . . . . .
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .
Legal information. . . . . . . . . . . . . . . . . . . . . . . .
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . .
1
1
1
1
1
1
2
2
2
3
3
5
6
6
7
8
9
9
9
9
9
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to:
salesaddresses@nexperia.com
Date of release: 4 June 2009
Document identifier: MMBD4148
很抱歉,暂时无法提供与“MMBD4148,215”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 9000+0.171149000+0.02211
- 国内价格 香港价格
- 国内价格 香港价格
- 1+1.317601+0.17030
- 10+0.7977010+0.10310
- 100+0.49110100+0.06350
- 500+0.35930500+0.04650
- 1000+0.316201000+0.04090
- 3000+0.280303000+0.03630
- 6000+0.253906000+0.03280
- 9000+0.210809000+0.02730
- 24000+0.1665024000+0.02150
- 国内价格
- 3000+0.33104
- 9000+0.32511
