PMLL4153,115
PMLL4153,115
    NEXPERIA(安世)
    SOD80C
    二极管配置:独立式 功率:500mW 直流反向耐压(Vr):75V 平均整流电流(Io):200mA 正向压降(Vf):850mV@50mA
PMLL4153,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PMLL4153 High-speed diode Rev. 3 — 19 August 2010 Product data sheet 1. Product profile 1.1 General description High-speed switching diode fabricated in planar technology, and encapsulated in a small hermetically sealed glass SOD80C Surface-Mounted Device (SMD) package. 1.2 Features and benefits „ „ „ „ „ „ High switching speed: max. 4 ns General application Reverse voltage: max. 50 V Repetitive peak reverse voltage: max. 75 V Repetitive peak forward current: max. 450 mA Small hermetically sealed glass SMD package 1.3 Applications „ High-speed switching „ Military and industrial applications 1.4 Quick reference data Table 1. Symbol Quick reference data Parameter IF forward current VR reverse voltage VF forward voltage [1] Conditions [1] IF = 50 mA Min Typ Max Unit - - 200 mA - - 50 V 740 - 880 mV Device mounted on an FR4 Printed-Circuit Board (PCB). 2. Pinning information Table 2. Pin Pinning Description 1 cathode 2 anode Simplified outline Graphic symbol [1] k a 1 2 006aab040 [1] The marking band indicates the cathode. PMLL4153 NXP Semiconductors High-speed diode 3. Ordering information Table 3. Ordering information Type number PMLL4153 Package Name Description Version - hermetically sealed glass surface-mounted package; 2 connectors SOD80C 4. Marking Table 4. Marking codes Type number Marking code PMLL4153 marking band 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VRRM repetitive peak reverse voltage Conditions VR reverse voltage IF forward current IFRM repetitive peak forward current IFSM non-repetitive peak forward current [1] square wave Min Max Unit - 75 V - 50 V - 200 mA - 450 mA [2] tp = 1 μs - 4 A tp = 1 ms - 1 A - 0.5 A - 500 mW tp = 1 s Tamb ≤ 25 °C [1] Ptot total power dissipation Tj junction temperature - 200 °C Tstg storage temperature −65 +200 °C [1] Device mounted on an FR4 PCB. [2] Tj = 25 °C prior to surge. 6. Thermal characteristics Table 6. Parameter Rth(j-t) thermal resistance from junction to tie-point Rth(j-a) thermal resistance from junction to ambient [1] PMLL4153 Product data sheet Thermal characteristics Symbol Conditions in free air [1] Min Typ Max Unit - - 300 K/W - - 350 K/W Device mounted on an FR4 PCB. All information provided in this document is subject to legal disclaimers. Rev. 3 — 19 August 2010 © NXP B.V. 2010. All rights reserved. 2 of 10 PMLL4153 NXP Semiconductors High-speed diode 7. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VF forward voltage IF = 0.1 mA 490 - 550 mV IF = 0.25 mA 530 - 590 mV IF = 1 mA 590 - 670 mV IF = 2 mA 620 - 700 mV IF = 10 mA 700 - 810 mV reverse current IR diode capacitance Cd IF = 50 mA 740 - 880 mV VR = 50 V - - 0.05 μA VR = 50 V; Tj = 150 °C - - 50 μA VR = 0 V; f = 1 MHz reverse recovery time trr forward recovery time tfr - - 2 pF [1] - - 4 ns [2] - - 2 ns [3] - - 10 ns [1] When switched from IF = 10 mA to IR = 10 mA; RL = 100 Ω; measured at IR = 1 mA. [2] When switched from IF = 10 mA to IR = 60 mA; RL = 100 Ω; measured at IR = 1 mA. [3] When switched to IF = 200 mA; tr = 0.4 ns; measured at VF = 1 V. mbg451 300 mbg464 600 IF (mA) IF (mA) 200 400 (1) (2) (3) 200 100 0 0 0 100 Tamb (°C) 0 200 Device mounted on an FR4 Printed-Circuit Board (PCB). 1 VF (V) 2 (1) Tj = 175 °C; typical values (2) Tj = 25 °C; typical values (3) Tj = 25 °C; maximum values Fig 1. Forward current as a function of ambient temperature; derating curve PMLL4153 Product data sheet Fig 2. Forward current as a function of forward voltage All information provided in this document is subject to legal disclaimers. Rev. 3 — 19 August 2010 © NXP B.V. 2010. All rights reserved. 3 of 10 PMLL4153 NXP Semiconductors High-speed diode mbg704 102 IFSM (A) 10 1 10−1 1 10 102 103 104 tp (μs) Based on square wave currents. Tj = 25 °C prior to surge Fig 3. Non-repetitive peak forward current as a function of pulse duration; maximum values mgd006 103 IR (μA) mgd004 1.2 Cd (pF) 102 1.0 (1) (2) (3) 10 0.8 1 0.6 10−1 10−2 0.4 0 100 Tj (°C) 0 200 10 VR (V) 20 f = 1 MHz; Tj = 25 °C (1) VR = 75 V; maximum values (2) VR = 75 V; typical values (3) VR = 20 V; typical values Fig 4. Reverse current as a function of junction temperature PMLL4153 Product data sheet Fig 5. Diode capacitance as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 19 August 2010 © NXP B.V. 2010. All rights reserved. 4 of 10 PMLL4153 NXP Semiconductors High-speed diode 8. Test information tr tp t D.U.T. 10 % + IF IF RS = 50 Ω SAMPLING OSCILLOSCOPE trr t Ri = 50 Ω V = VR + IF × RS (1) 90 % VR mga881 input signal Fig 6. output signal Reverse recovery voltage test circuit and waveforms I 1 kΩ 450 Ω RS = 50 Ω I 1.0 90% VF (V) OSCILLOSCOPE D.U.T. Vfr Ri = 50 Ω 10% t tr tfr tp output signal input signal t mbh181 Input signal: forward pulse rise time tr = 0.4 ns; forward pulse duration tp = 100 ns; duty factor δ = 0.01 Fig 7. Forward recovery time test circuit and waveforms 9. Package outline 0.3 0.3 1.60 1.45 3.7 3.3 Dimensions in mm Fig 8. PMLL4153 Product data sheet 06-03-16 Package outline SOD80C All information provided in this document is subject to legal disclaimers. Rev. 3 — 19 August 2010 © NXP B.V. 2010. All rights reserved. 5 of 10 PMLL4153 NXP Semiconductors High-speed diode 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PMLL4153 [1] Package Description SOD80C Packing quantity 4 mm pitch, 8 mm tape and reel 2500 10000 -115 -135 For further information and the availability of packing methods, see Section 14. 11. Soldering 4.55 4.30 2.30 solder lands solder paste 2.25 1.70 1.60 solder resist occupied area Dimensions in mm 0.90 (2x) Fig 9. sod080c Reflow soldering footprint SOD80C 6.30 4.90 2.70 1.90 solder lands solder resist occupied area 2.90 1.70 tracks Dimensions in mm sod080c Fig 10. Wave soldering footprint SOD80C PMLL4153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 19 August 2010 © NXP B.V. 2010. All rights reserved. 6 of 10 PMLL4153 NXP Semiconductors High-speed diode 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PMLL4153 v.3 20100819 Product data sheet - PMLL4150_2 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • • • • • • • • Type numbers PMLL4150 and PMLL4151 removed. Legal texts have been adapted to the new company name where appropriate. Table 1 “Quick reference data”: added Section 4 “Marking”: added Figure 1: updated Figure 8: superseded by minimized package outline drawing Section 10 “Packing information”: added Section 11 “Soldering”: added Section 13 “Legal information”: updated PMLL4150_2 19960918 Product specification - PMLL4150_1 PMLL4150_1 19960423 Product specification - - PMLL4153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 19 August 2010 © NXP B.V. 2010. All rights reserved. 7 of 10 PMLL4153 NXP Semiconductors High-speed diode 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. PMLL4153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 19 August 2010 © NXP B.V. 2010. All rights reserved. 8 of 10 PMLL4153 NXP Semiconductors High-speed diode Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PMLL4153 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 19 August 2010 © NXP B.V. 2010. All rights reserved. 9 of 10 PMLL4153 NXP Semiconductors High-speed diode 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 5 Packing information . . . . . . . . . . . . . . . . . . . . . 6 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 7 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 8 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 8 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Contact information. . . . . . . . . . . . . . . . . . . . . . 9 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 19 August 2010 Document identifier: PMLL4153
PMLL4153,115 价格&库存
很抱歉,暂时无法提供与“PMLL4153,115”相匹配的价格&库存,您可以联系我们找货
