BAV102,115
BAV102,115
    NEXPERIA(安世)
    SOD80C
    开关二极管(小信号) 150V Φ1.60 x 3.70mm SMT SOD80C 250mA
BAV102,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia BAV102; BAV103 Single general-purpose switching diodes Rev. 4 — 6 August 2010 Product data sheet 1. Product profile 1.1 General description Single general-purpose switching diodes, fabricated in planar technology, and encapsulated in small hermetically sealed glass SOD80C Surface-Mounted Device (SMD) packages. Table 1. Product overview Type number BAV102 Package Configuration NXP JEITA SOD80C - single BAV103 1.2 Features and benefits „ High switching speed: trr ≤ 50 ns „ Low leakage current „ Low capacitance: Cd ≤ 5 pF „ Small hermetically sealed glass SMD package 1.3 Applications „ High-speed switching „ General-purpose switching „ Voltage clamping „ Reverse polarity protection 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter IF forward current VR reverse voltage Conditions [1][2] BAV102 BAV103 [3] Min Typ Max Unit - - 250 mA - - 150 V - - 200 V - - 50 ns trr reverse recovery time [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [3] When switched from IF = 30 mA to IR = 30 mA; RL = 100 Ω; measured at IR = 3 mA. BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes 2. Pinning information Table 3. Pinning Pin Description 1 cathode 2 anode Simplified outline Graphic symbol [1] k a 2 1 006aab040 [1] The marking band indicates the cathode. 3. Ordering information Table 4. Ordering information Type number BAV102 Package Name Description Version - hermetically sealed glass surface-mounted package; 2 connectors SOD80C BAV103 4. Marking Table 5. Marking codes Type number Marking code BAV102 marking band BAV103 marking band 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VRRM repetitive peak reverse voltage VR BAV102_BAV103 Product data sheet Conditions Min Max Unit BAV102 - 200 V BAV103 - 250 V BAV102 - 150 V BAV103 - 200 V - 250 mA - 625 mA tp = 1 μs - 9 A tp = 100 μs - 3 A tp = 1 s - 1 A reverse voltage IF forward current IFRM repetitive peak forward current IFSM non-repetitive peak forward current [1][2] square wave All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 [3] © NXP B.V. 2010. All rights reserved. 2 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes Table 6. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Ptot total power dissipation Tamb ≤ 25 °C - 400 mW Tj junction temperature - 175 °C Tamb ambient temperature −65 +175 °C Tstg storage temperature −65 +175 °C [2] [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [3] Tj = 25 °C prior to surge. 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient Rth(j-t) thermal resistance from junction to tie-point [1] in free air [1] Min Typ Max Unit - - 375 K/W - - 300 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter VF forward voltage IR Conditions BAV103 Product data sheet Typ Max Unit IF = 100 mA - - 1.0 V IF = 200 mA - - 1.25 V VR = 150 V - - 100 nA VR = 150 V; Tj = 150 °C - - 100 μA VR = 200 V - - 100 nA VR = 200 V; Tj = 150 °C - - 100 μA f = 1 MHz; VR = 0 V - - 5 pF - - 50 ns reverse current BAV102 BAV102_BAV103 Min [1] Cd diode capacitance trr reverse recovery time [2] [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [2] When switched from IF = 30 mA to IR = 30 mA; RL = 100 Ω; measured at IR = 3 mA. All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 © NXP B.V. 2010. All rights reserved. 3 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes mbg459 600 IF (mA) mbg703 102 IFSM (A) 10 400 (1) (2) (3) 1 200 10−1 0 0 1 VF (V) 1 2 10 102 103 104 tp (μs) (1) Tamb = 150 °C; typical values Based on square wave currents. (2) Tamb = 25 °C; typical values Tj = 25 °C; prior to surge (3) Tamb = 25 °C; maximum values Fig 1. Forward current as a function of forward voltage Fig 2. mgd005 mgd009 103 IR (μA) Non-repetitive peak forward current as a function of pulse duration; maximum values 1.6 Cd (pF) 102 1.4 10 1.2 1 1.0 10−1 10−2 0.8 0 100 Tj (°C) 0 200 10 VR (V) 20 f = 1 MHz; Tamb = 25 °C VR = VRmax Solid line: maximum values Dotted line: typical values Fig 3. Reverse current as a function of junction temperature BAV102_BAV103 Product data sheet Fig 4. Diode capacitance as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 © NXP B.V. 2010. All rights reserved. 4 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes mbh278 300 mgl588 300 VR (V) IF (mA) (1) 200 200 (2) 100 100 0 0 0 100 Tamb (°C) 200 0 FR4 PCB, standard footprint 100 200 Tamb (°C) FR4 PCB, standard footprint (1) BAV103 (2) BAV102 Fig 5. Forward current as a function of ambient temperature; derating curve Fig 6. Reverse voltage as a function of ambient temperature; derating curve 8. Test information tr t D.U.T. RS = 50 Ω V = VR + IF × RS tp 10 % + IF IF SAMPLING OSCILLOSCOPE trr t Ri = 50 Ω VR (1) 90 % mga881 input signal output signal (1) IR = 1 mA Fig 7. Reverse recovery time test circuit and waveforms BAV102_BAV103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 © NXP B.V. 2010. All rights reserved. 5 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes 9. Package outline 0.3 0.3 1.60 1.45 3.7 3.3 Dimensions in mm Fig 8. 06-03-16 Package outline SOD80C 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number BAV102 Package SOD80C Description 4 mm pitch, 8 mm tape and reel Packing quantity 2500 10000 -115 -135 BAV103 [1] BAV102_BAV103 Product data sheet For further information and the availability of packing methods, see Section 14. All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 © NXP B.V. 2010. All rights reserved. 6 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes 11. Soldering 4.55 4.30 2.30 solder lands solder paste 2.25 1.70 1.60 solder resist occupied area Dimensions in mm 0.90 (2x) Fig 9. sod080c Reflow soldering footprint SOD80C 6.30 4.90 2.70 1.90 solder lands solder resist occupied area 2.90 1.70 tracks Dimensions in mm sod080c Fig 10. Wave soldering footprint SOD80C BAV102_BAV103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 © NXP B.V. 2010. All rights reserved. 7 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BAV102_BAV103 v.4 20100806 Product data sheet - BAV102_BAV103_3 Modifications: • • Section 4 “Marking”: updated Section 13 “Legal information”: updated BAV102_BAV103_3 20070816 Product data sheet - BAV100_2 BAV100_2 19960917 Product specification - BAV100_1 BAV100_1 19960423 Product specification - - BAV102_BAV103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 © NXP B.V. 2010. All rights reserved. 8 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between NXP Semiconductors and its customer, unless NXP Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the NXP Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NXP Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of NXP Semiconductors. malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NXP Semiconductors products, and NXP Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NXP Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NXP Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using NXP Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). NXP does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NXP Semiconductors hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NXP Semiconductors products by customer. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. BAV102_BAV103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 © NXP B.V. 2010. All rights reserved. 9 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Non-automotive qualified products — Unless this data sheet expressly states that this specific NXP Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NXP Semiconductors accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NXP Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NXP Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NXP Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NXP Semiconductors’ standard warranty and NXP Semiconductors’ product specifications. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com BAV102_BAV103 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 6 August 2010 © NXP B.V. 2010. All rights reserved. 10 of 11 BAV102; BAV103 NXP Semiconductors Single general-purpose switching diodes 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information . . . . . . . . . . . . . . . . . . . . . 6 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2010. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 6 August 2010 Document identifier: BAV102_BAV103
BAV102,115 价格&库存
很抱歉,暂时无法提供与“BAV102,115”相匹配的价格&库存,您可以联系我们找货
BAV102,115
    BAV102,115
    • 1+0.28761
    • 100+0.27323
    • 300+0.25885
    • 500+0.24447
    • 2000+0.23728
    • 5000+0.23296
    库存:70
    BAV102,115
    • 20+0.57370
    • 100+0.34220
    • 500+0.23950
    • 2500+0.17110
    • 5000+0.16260
    • 25000+0.15050
    库存:1
