1PS76SB21; BAT721 series
Schottky barrier diodes in small packages
Rev. 06 — 21 December 2006
Product data sheet
1. Product profile
1.1 General description
Planar Schottky barrier diodes with an integrated guard ring for stress protection.
Encapsulated in small Surface-Mounted Device (SMD) plastic packages.
Table 1.
Product overview
Type number
Package
Nexperia
Configuration
JEITA
1PS76SB21
SOD323
SC-76
single
BAT721
SOT23
single
BAT721A
SOT23
dual common anode
BAT721C
SOT23
dual common cathode
BAT721S
SOT23
dual series
1.2 Features
n Low forward voltage
n Small SMD plastic packages
n Low capacitance
1.3 Applications
n
n
n
n
Ultra high-speed switching
Voltage clamping
Line termination
Reverse polarity protection
1.4 Quick reference data
Table 2.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
200
mA
40
V
550
mV
Per diode
IF
forward current
VR
reverse voltage
VF
[1]
forward voltage
Pulse test: tp ≤ 300 µs; δ ≤ 0.02.
IF = 200 mA
[1]
Nexperia
2. Pinning information
Table 3.
Pinning
Pin
Description
Simplified outline
Symbol
1PS76SB21
1
cathode
2
anode
[1]
1
1
2
2
sym001
BAT721
1
anode
2
not connected
3
cathode
3
3
2
n.c.
1
006aaa436
1
2
006aaa144
BAT721A
1
cathode (diode 1)
2
cathode (diode 2)
3
anode (diode 1),
anode (diode 2)
3
3
1
2
006aaa439
1
2
006aaa144
BAT721C
1
anode (diode 1)
2
anode (diode 2)
3
cathode (diode 1),
cathode (diode 2)
3
3
1
2
006aaa438
1
2
006aaa144
BAT721S
1
anode (diode 1)
2
cathode (diode 2)
3
cathode (diode 1),
anode (diode 2)
3
3
1
2
006aaa437
1
2
006aaa144
[1]
The marking bar indicates the cathode.
1PS76SB21_BAT721_SER_6
Product data sheet
Nexperia B.V. 2017. All rights reserved
2 of 11
Nexperia
3. Ordering information
Table 4.
Type number
Package
Name
Description
Version
1PS76SB21
SC-76
plastic surface-mounted package; 2 leads
SOD323
BAT721
plastic surface-mounted package; 3 leads
SOT23
BAT721A
BAT721C
BAT721S
4. Marking
Table 5.
Marking codes
Type number
Marking code[1]
1PS76SB21
S1
BAT721
L7*
BAT721A
L8*
BAT721C
L9*
BAT721S
L0*
[1]
* = -: made in Hong Kong
* = p: made in Hong Kong
* = t: made in Malaysia
* = W: made in China
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Per diode
VR
reverse voltage
40
V
IF
forward current
200
mA
IFSM
non-repetitive peak forward
current
1
A
Tj
junction temperature
125
°C
Tamb
ambient temperature
−65
+150
°C
Tstg
storage temperature
−65
+150
°C
half sine wave;
JEDEC method;
tp = 8.3 ms
Product data sheet
3 of 11
Nexperia
6. Thermal characteristics
Table 7.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
thermal resistance from
junction to ambient
in free air
1PS76SB21
450
K/W
BAT721
500
K/W
BAT721A
500
K/W
BAT721C
500
K/W
BAT721S
500
K/W
Per diode
Rth(j-a)
[1]
[1]
Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard
footprint.
7. Characteristics
Table 8.
Characteristics
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
forward voltage
IF = 10 mA
[1]
300
mV
IF = 100 mA
[1]
420
mV
IF = 200 mA
[1]
550
mV
15
µA
Per diode
VF
IR
reverse current
Cd
diode capacitance
[1]
VR = 30 V
VR = 30 V; Tj = 100 °C
3
mA
VR = 0 V; f = 1 MHz
40
50
pF
Product data sheet
4 of 11
Nexperia
006aaa689
103
IR
(mA)
IF
(mA)
006aaa690
10
(1)
1
(2)
102
10−1
(1)
(2)
(3)
10−2
(4)
(3)
10
10−3
10−4
1
10−5
10−1
(4)
10−6
400
600
VF (mV)
40
VR (V)
(1) Tamb = 125 °C
(1) Tamb = 125 °C
(2) Tamb = 85 °C
(2) Tamb = 85 °C
(3) Tamb = 25 °C
(3) Tamb = 25 °C
(4) Tamb = −40 °C
(4) Tamb = −40 °C
Fig 1. Forward current as a function of forward
voltage; typical values
Fig 2. Reverse current as a function of reverse
mbk574
102
Cd
(pF)
10
1
VR (V)
40
Tamb = 25 °C; f = 1 MHz
Fig 3. Diode capacitance as a function of reverse voltage; typical values
Product data sheet
5 of 11
Nexperia
8. Package outline
1.35
1.15
1.1
0.8
3.0
2.8
0.45
0.15
1
1.1
0.9
3
0.45
0.15
2.7
2.3
2.5 1.4
2.1 1.2
1.8
1.6
1
2
0.40
0.25
0.25
0.10
Dimensions in mm
2
1.9
03-12-17
Fig 4. Package outline SOD323 (SC-76)
0.48
0.38
Dimensions in mm
0.15
0.09
04-11-04
Fig 5. Package outline SOT23
9. Packing information
Table 9.
Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
Package
Description
Packing quantity
3000
10000
1PS76SB21
SOD323
4 mm pitch, 8 mm tape and reel
-115
-135
BAT721
SOT23
-215
-235
BAT721A
BAT721C
BAT721S
[1]
For further information and the availability of packing methods, see Section 13.
Product data sheet
6 of 11
Nexperia
10. Soldering
3.05
2.80
2.10
1.60
solder lands
solder resist
1.65
0.95
0.50
0.60
occupied area
solder paste
0.50
(2×)
msa433
Dimensions in mm
Fig 6. Reflow soldering footprint SOD323 (SC-76)
5.00
4.40
1.40
solder lands
solder resist
occupied area
2.75 1.20
msa415
preferred transport direction during soldering
Dimensions in mm
Fig 7. Wave soldering footprint SOD323 (SC-76)
Product data sheet
7 of 11
Nexperia
2.90
2.50
solder lands
solder resist
2
0.85
1
2.70
1.30
3.00
0.85
3
occupied area
solder paste
0.60
(3x)
0.50 (3x)
0.60 (3x)
1.00
3.30
MSA439
Dimensions in mm
Fig 8. Reflow soldering footprint SOT23
3.40
1.20 (2x)
solder lands
solder resist
occupied area
2
1
4.60 4.00 1.20
3
2.80
4.50
MSA427
Dimensions in mm
Fig 9. Wave soldering footprint SOT23
Product data sheet
8 of 11
Nexperia
11. Revision history
Table 10.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
20061221
Product data sheet
1PS76SB21_BAT721
_SER_5
BAT721_SERIES_4
1PS76SB21_3
Modifications:
1PS76SB21_BAT721_SER_5
Modifications:
Amended Table 10 “Revision history”
20061205
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Table 1 “Product overview”: added
This data sheet is a combination of data sheets BAT721_SERIES_4 and
1PS76SB21_3.
Section 1.2 “Features”: amended
Section 1.3 “Applications”: amended
Table 2 “Quick reference data”: added
Table 5 “Marking codes”: for 1PS76SB21 amended
Table 5 “Marking codes”: enhanced table note section
Table 6 “Limiting values”: indication per diode added
Table 6 “Limiting values”: for 1PS76SB21 IFSM condition amended
Table 6 “Limiting values”: Tamb ambient temperature added
Table 7 “Thermal characteristics”: indication per diode added
Table 7: Rth(j-a) thermal resistance from junction to ambient condition amended
Table 8 “Characteristics”: indication per diode added
Table 8 “Characteristics”: reference to Table note 1 amended
Table 8: for 1PS76SB21 Cd minimum value changed to typical value
Figure 1 and 2: amended
Figure 4 and 5: superseded by minimized package outlines
Section 9 “Packing information”: added
Section 10 “Soldering”: added
Section 12 “Legal information”: updated
BAT721_SERIES_4
20040315
Product specification
BAT721_SERIES_3
1PS76SB21_3
20040126
1PS76SB21_2
Product data sheet
9 of 11
Nexperia
12. Legal information
12.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
12.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
12.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected to
result in personal injury, death or severe property or environmental damage.
Nexperia accepts no liability for inclusion and/or use of Nexperia
products in such equipment or applications and therefore
such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
12.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
13. Contact information
For additional information, please visit: http://www.nexperia.com
For sales office addresses, send an email to: salesaddresses@nexperia.com
Product data sheet
10 of 11
Nexperia
14. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
10
11
12
12.1
12.2
12.3
12.4
13
14
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 3
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Thermal characteristics. . . . . . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6
Packing information. . . . . . . . . . . . . . . . . . . . . . 6
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9
Legal information. . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 10
Contact information. . . . . . . . . . . . . . . . . . . . . 10
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 21 December 2006
很抱歉,暂时无法提供与“1PS76SB21,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.246001+0.42000
- 10+1.8686010+0.24180
- 100+1.22180100+0.15810
- 500+0.91150500+0.11800
- 1000+0.797701000+0.10320
- 3000+0.604903000+0.07830
- 国内价格
- 1+0.64240
- 200+0.41470
- 1500+0.36080
- 3000+0.31900
- 国内价格
- 1+0.56670
- 10+0.48910
- 30+0.37220
- 100+0.34580
- 300+0.33760
- 3000+0.32760
