BAS17,215
BAS17,215
    NEXPERIA(安世)
    SOT-23
    安世 SOT-23 0.96V 0.25W
BAS17,215 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET dbook, halfpage M3D088 BAS17 Low-voltage stabistor Product data sheet Supersedes data of 1999 May 31 2003 Mar 25 NXP Semiconductors Product data sheet Low-voltage stabistor BAS17 FEATURES PINNING • Low-voltage stabilization PIN DESCRIPTION • Forward voltage range: 580 to 960 mV 1 anode • Total power dissipation: max. 250 mW. 2 not connected 3 cathode APPLICATIONS • Low-voltage stabilization e.g. – Bias stabilizer in class-B output stages – Clipping handbook, halfpage 2 1 – Clamping – Meter protection. 2 n.c. 1 DESCRIPTION 3 Low-voltage stabilization diode in a small SOT23 plastic package. 3 MAM185 MARKING Fig.1 MARKING CODE(1) TYPE NUMBER ∗A9 BAS17 Simplified outline (SOT23), pin configuration and symbol. Note 1. ∗ = p : Made in Hong Kong. ∗ = t : Made in Malaysia. ∗ = W : Made in China. LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. MAX. UNIT VR continuous reverse voltage − 5 V IF continuous forward current − 200 mA Ptot total power dissipation − 250 mW Tstg storage temperature −65 +150 °C Tj junction temperature − 150 °C 2003 Mar 25 Tamb = 25 °C 2 NXP Semiconductors Product data sheet Low-voltage stabistor BAS17 ELECTRICAL CHARACTERISTICS Tj = 25 °C unless otherwise specified. SYMBOL VF PARAMETER forward voltage CONDITIONS MIN. TYP. MAX. UNIT see Fig.2 IF = 0.1 mA 580 − 660 mV IF = 1 mA 665 − 745 mV IF = 5 mA 725 − 805 mV IF = 10 mA 750 − 830 mV IF = 100 mA 870 − 960 mV IR reverse current VR = 4 V − − 5 µA rdif differential resistance IF = 0.5 mA − 120 − Ω IF = 2 mA − 80 − Ω SF temperature coefficient IF = 1 mA − −1.8 − mV/K Cd diode capacitance VR = 0 V; f = 1 MHz − − 140 pF THERMAL CHARACTERISTICS SYMBOL PARAMETER Rth j-tp thermal resistance from junction to tie-point Rth j-a thermal resistance from junction to ambient CONDITIONS note 1 Note 1. Device mounted on a FR4 printed-circuit board. 2003 Mar 25 3 VALUE UNIT 330 K/W 500 K/W NXP Semiconductors Product data sheet Low-voltage stabistor BAS17 GRAPHICAL DATA MBG517 2 10halfpage handbook, IF (mA) (1) (2) 10 1 10−1 0.5 0.75 VF (V) 1.0 Tj = 25 °C. (1) Minimum values. (2) Maximum values. Fig.2 Forward current as a function of forward voltage. 2003 Mar 25 4 NXP Semiconductors Product data sheet Low-voltage stabistor BAS17 PACKAGE OUTLINE Plastic surface mounted package; 3 leads SOT23 D E B A X HE v M A 3 Q A A1 1 2 e1 bp c w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 OUTLINE VERSION SOT23 2003 Mar 25 REFERENCES IEC JEDEC EIAJ EUROPEAN PROJECTION ISSUE DATE 97-02-28 99-09-13 TO-236AB 5 NXP Semiconductors Product data sheet Low-voltage stabistor BAS17 DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. DISCLAIMERS General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. 2003 Mar 25 Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 6 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors. No changes were made to the content, except for the legal definitions and disclaimers. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands 613514/03/pp7 Date of release: 2003 Mar 25 Document order number: 9397 750 10969
BAS17,215
物料型号:BAS17
器件简介:BAS17是一款低电压稳定二极管,由Nexperia公司生产,该公司是2017年由NXP标准产品业务分离出来的新公司。
引脚分配:1号引脚为阳极,2号引脚未连接,3号引脚为阴极。
参数特性: - 连续反向电压(VR):最高5V - 连续正向电流(IF):最高200mA - 总功耗(Ptot):最高250mW - 存储温度(Tstg):-65℃至+150℃ - 结温(T):最高150℃
功能详解: - 用于低电压稳定,例如在B类输出阶段作为偏置稳定器、剪切、钳位、仪表保护等。
应用信息:BAS17二极管在小尺寸SOT23塑料封装中提供低电压稳定功能。
封装信息:SOT23塑料表面贴装封装,共有3个引脚。
BAS17,215 价格&库存
很抱歉,暂时无法提供与“BAS17,215”相匹配的价格&库存,您可以联系我们找货
BAS17,215
  • 1+1.00760
  • 200+0.77550
  • 1500+0.67540
  • 3000+0.62810
库存:58
BAS17,215
    BAS17,215
      • 5+1.05830
      • 50+0.84014
      • 150+0.74672
      • 500+0.63008
      • 3000+0.57813
      • 6000+0.54692
      库存:27
      BAS17,215
