PMEG4010EJ,115
PMEG4010EJ,115
    NEXPERIA(安世)
    SOD323F
    直流反向耐压(Vr):40V 平均整流电流(Io):1A 正向压降(Vf):640mV@1A
PMEG4010EJ,115 数据手册
PMEG4010EH; PMEG4010EJ; PMEG4010ET 1 A very low VF MEGA Schottky barrier rectifiers Rev. 04 — 21 March 2007 Product data sheet 1. Product profile 1.1 General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifiers with an integrated guard ring for stress protection, encapsulated in small Surface-Mounted Device (SMD) plastic packages. Table 1. Product overview Type number Package Configuration Nexperia JEITA JEDEC PMEG4010EH SOD123F - - PMEG4010EJ SOD323F SC-90 - single PMEG4010ET SOT23 - TO-236AB single single 1.2 Features n n n n Forward current: IF ≤ 1 A Reverse voltage: VR ≤ 40 V Very low forward voltage Small SMD plastic packages 1.3 Applications n n n n n Low voltage rectification High efficiency DC-to-DC conversion Switch mode power supply Reverse polarity protection Low power consumption applications 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF forward current Tsp ≤ 55 °C - - 1 A VR reverse voltage - - 40 V - 540 640 mV VF [1] forward voltage Pulse test: tp ≤ 300 µs; δ ≤ 0.02. IF = 1000 mA [1] PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 2. Pinning information Table 3. Pinning Pin Description Simplified outline Symbol SOD123F; SOD323F 1 cathode 2 anode [1] 1 1 2 2 sym001 001aab540 SOT23 1 anode 2 n.c. 3 cathode 3 2 n.c. 1 1 [1] 3 2 006aaa436 The marking bar indicates the cathode. 3. Ordering information Table 4. Ordering information Type number Package Name Description Version PMEG4010EH - plastic surface-mounted package; 2 leads SOD123F PMEG4010EJ SC-90 plastic surface-mounted package; 2 leads SOD323F PMEG4010ET - plastic surface-mounted package; 3 leads SOT23 4. Marking Table 5. Marking codes Type number Marking code[1] PMEG4010EH AB PMEG4010EJ AL PMEG4010ET *AW [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 2 of 11 PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage - 40 V IF forward current Tsp ≤ 55 °C IFRM repetitive peak forward current tp ≤ 1 ms; δ ≤ 0.25 - 1 A PMEG4010EH - 7 A PMEG4010EJ - 7 A PMEG4010ET - 5 A - 9 A [1][3] - 375 mW [2][3] - 830 mW [1][3] - 350 mW [2][3] - 830 mW [1] - 280 mW [2] - 420 mW IFSM non-repetitive peak forward current square wave; tp = 8 ms Ptot total power dissipation Tamb ≤ 25 °C PMEG4010EH PMEG4010EJ PMEG4010ET Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [3] Reflow soldering is the only recommended soldering method. © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 3 of 11 PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 6. Thermal characteristics Table 7. Symbol Rth(j-a) Thermal characteristics Parameter Min Typ Max Unit [2][4] - - 330 K/W [3][4] - - 150 K/W [2][4] - - 350 K/W [3][4] - - 150 K/W [2] - - 440 K/W [3] - - 300 K/W PMEG4010EH - - 60 K/W PMEG4010EJ - - 55 K/W PMEG4010ET - - 120 K/W thermal resistance from junction to ambient Conditions in free air PMEG4010EH PMEG4010EJ PMEG4010ET Rth(j-sp) [1] [5] thermal resistance from junction to solder point [1] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [4] Reflow soldering is the only recommended soldering method. [5] Soldering point of cathode tab. 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol VF Parameter Min Typ Max Unit IF = 0.1 mA - 95 130 mV IF = 1 mA - 155 210 mV IF = 10 mA - 220 270 mV IF = 100 mA - 295 350 mV IF = 500 mA - 420 470 mV IF = 1000 mA - 540 640 mV VR = 10 V - 7 20 µA VR = 40 V - 30 100 µA VR = 1 V; f = 1 MHz - 43 50 pF [1] forward voltage IR reverse current Cd diode capacitance [1] Conditions Pulse test: tp ≤ 300 µs; δ ≤ 0.02. © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 4 of 11 PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 006aaa253 103 IF (mA) IR (µA) 006aaa254 105 (1) 104 (2) 103 (3) 102 (1) 10 (2) (3) (4) 102 (5) (4) 10 1 1 10−1 10−1 (5) 10−2 10−2 10−3 0 0.1 0.2 0.3 0.4 0.5 0.6 VF (V) 0 10 20 30 40 VR (V) (1) Tamb = 150 °C (1) Tamb = 150 °C (2) Tamb = 125 °C (2) Tamb = 125 °C (3) Tamb = 85 °C (3) Tamb = 85 °C (4) Tamb = 25 °C (4) Tamb = 25 °C (5) Tamb = −40 °C (5) Tamb = −40 °C Fig 1. Forward current as a function of forward voltage; typical values Fig 2. Reverse current as a function of reverse voltage; typical values 006aaa255 100 Cd (pF) 80 60 40 20 0 0 10 20 30 40 VR (V) f = 1 MHz; Tamb = 25 °C Fig 3. Diode capacitance as a function of reverse voltage; typical values © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 5 of 11 PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 8. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig 4. Duty cycle definition 9. Package outline 1.7 1.5 1.2 1.0 1.35 1.15 1 0.80 0.65 0.5 0.3 1 0.55 0.35 3.6 3.4 2.7 2.3 2.7 2.5 1.8 1.6 2 2 0.70 0.55 Dimensions in mm 0.25 0.10 0.40 0.25 0.25 0.10 04-11-29 Dimensions in mm Fig 5. Package outline SOD123F 04-09-13 Fig 6. Package outline SOD323F (SC-90) 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 0.48 0.38 Dimensions in mm 0.15 0.09 04-11-04 Fig 7. Package outline SOT23 (TO-236AB) © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 6 of 11 PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 3000 10000 PMEG4010EH SOD123F 4 mm pitch, 8 mm tape and reel -115 -135 PMEG4010EJ SOD323F 4 mm pitch, 8 mm tape and reel -115 -135 PMEG4010ET SOT23 4 mm pitch, 8 mm tape and reel -215 -235 [1] For further information and the availability of packing methods, see Section 14. 11. Soldering 4.4 4 2.9 1.6 solder lands solder resist 2.1 1.6 1.1 1.2 solder paste occupied area 1.1 (2×) Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 8. Reflow soldering footprint SOD123F 3.05 2.80 2.10 1.60 solder lands solder resist 1.65 0.95 0.50 0.60 occupied area solder paste 0.50 (2×) msa433 Reflow soldering is the only recommended soldering method. Dimensions in mm Fig 9. Reflow soldering footprint SOD323F (SC-90) © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 7 of 11 PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 2.90 2.50 0.85 2 1 solder lands 1.30 3.00 2.70 0.85 solder resist solder paste 3 occupied area 0.60 (3x) Dimensions in mm 0.50 (3x) 0.60 (3x) 1.00 3.30 sot023 Fig 10. Reflow soldering footprint SOT23 (TO-236AB) 3.40 1.20 (2x) solder lands solder resist occupied area 2 1 4.60 4.00 1.20 3 Dimensions in mm 2.80 preferred transport direction during soldering sot023 4.50 Fig 11. Wave soldering footprint SOT23 (TO-236AB) © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 8 of 11 PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PMEG4010EH_EJ_ET_4 20070321 Product data sheet - PMEGXX10EH_EJ_SER_3 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors . • • Legal texts have been adapted to the new company name where appropriate. • • • • • • • Type number PMEG4010ET added Type numbers PMEG4010EH and PMEG4010EJ separated from data sheet PMEGXX10EH_EJ_SER_3 Section 1.1 “General description”: amended Section 1.2 “Features”: amended Section 1.3 “Applications”: amended Section 8 “Test information”: added Figure 7, 10 and 11: added Section 13 “Legal information”: updated PMEGXX10EH_EJ_SER_3 20050411 Product data sheet - PMEGXX10EJ_SER_2 PMEGXX10EJ_SER_2 20050131 Product data sheet - PMEGXX10EJ_SER_1 PMEGXX10EJ_SER_1 20040907 Objective data sheet - - © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 9 of 11 PMEG4010EH/EJ/ET Nexperia 1 A very low VF MEGA Schottky barrier rectifiers 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For additional information, please visit: http://www.nexperia.com For sales office addresses, send an email to: salesaddresses@nexperia.com © PMEG4010EH_EJ_ET_4 Product data sheet Rev. 04 — 21 March 2007 Nexperia B.V. 2017. All rights reserved 10 of 11 Nexperia PMEG4010EH/EJ/ET 1 A very low VF MEGA Schottky barrier rectifiers 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics. . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information. . . . . . . . . . . . . . . . . . . . . . 7 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 21 March 2007
PMEG4010EJ,115 价格&库存
很抱歉,暂时无法提供与“PMEG4010EJ,115”相匹配的价格&库存,您可以联系我们找货
