PMEG4020EPA,115
PMEG4020EPA,115
    NEXPERIA(安世)
    SOT1061
    2 A low VF MEGA Schottky barrier rectifier
PMEG4020EPA,115 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia PMEG4020EPA 2 A low VF MEGA Schottky barrier rectifier Rev. 01 — 16 December 2009 Product data sheet 1. Product profile 1.1 General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with an integrated guard ring for stress protection. PMEG4020EPA is encapsulated in an ultra thin SOT1061 leadless small Surface-Mounted Device (SMD) plastic package with medium power capability. 1.2 Features „ „ „ „ „ „ Average forward current: IF(AV) ≤ 2 A Reverse voltage: VR ≤ 40 V Low forward voltage Exposed heat sink (cathode pad) for excellent thermal and electrical conductivity Leadless small SMD plastic package with medium power capability AEC-Q101 qualified 1.3 Applications „ „ „ „ „ „ Low voltage rectification High efficiency DC-to-DC conversion Switch Mode Power Supply (SMPS) Reverse polarity protection Low power consumption applications Battery chargers for mobile equipment 1.4 Quick reference data Table 1. Quick reference data Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions IF(AV) average forward current square wave; δ = 0.5; f = 20 kHz Tamb ≤ 65 °C Tsp ≤ 140 °C Min [1] Typ Max Unit - - 2 A - - 2 A - - 40 V VR reverse voltage VF forward voltage IF = 2 A - 470 535 mV IR reverse current VR = 40 V - 20 100 μA [1] Device mounted on a ceramic Printed-Circuit Board (PCB), Al2O3, standard footprint. PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 2. Pinning information Table 2. Pinning Pin Description 1 anode 2 anode 3 cathode Simplified outline Graphic symbol 3 3 1, 2 006aab624 1 2 Transparent top view 3. Ordering information Table 3. Ordering information Type number Package Name Description Version PMEG4020EPA HUSON3 plastic thermal enhanced ultra thin small outline package; SOT1061 no leads; three terminals; body 2 × 2 × 0.65 mm 4. Marking Table 4. Marking codes Type number Marking code PMEG4020EPA A3 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage Tj = 25 °C - 40 V IF(AV) average forward current square wave; δ = 0.5; f = 20 kHz - 2 A Tamb ≤ 65 °C [1] Tsp ≤ 140 °C - 2 A [2] - 7 A square wave; tp = 8 ms [2][3] - 18 A Tamb ≤ 25 °C [4][5] - 520 mW [4][6] - 1050 mW [4][1] - 1900 mW IFRM repetitive peak forward current tp ≤ 1 ms; δ ≤ 0.25 IFSM non-repetitive peak forward current Ptot total power dissipation PMEG4020EPA_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 2 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Tj Conditions Min Max Unit junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Device mounted on a ceramic PCB, Al2O3, standard footprint. [2] Both anode pins connected. [3] Tj = 25 °C prior to surge. [4] Reflow soldering is the only recommended soldering method. [5] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [6] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. 6. Thermal characteristics Table 6. Symbol Rth(j-a) Rth(j-sp) Thermal characteristics Parameter thermal resistance from junction to ambient Conditions in free air thermal resistance from junction to solder point Typ Max Unit [3] - - 240 K/W [4] - - 120 K/W [5] - - 65 K/W [6] - - 10 K/W [1] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. [2] Reflow soldering is the only recommended soldering method. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [4] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [5] Device mounted on a ceramic PCB, Al2O3, standard footprint. [6] Soldering point of cathode tab. PMEG4020EPA_1 Product data sheet Min [1][2] © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 3 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 006aab814 103 Zth(j-a) (K/W) duty cycle = 1 0.75 0.5 102 0.33 0.25 0.2 0.1 0.05 10 0.02 0.01 0 1 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 1. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aab815 103 Zth(j-a) (K/W) duty cycle = 102 1 0.75 0.5 0.25 0.1 10 0.33 0.2 0.05 0.02 0.01 0 1 10−3 10−2 10−1 1 10 102 103 tp (s) FR4 PCB, mounting pad for cathode 1 cm2 Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMEG4020EPA_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 4 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 006aab816 102 duty cycle = 1 0.75 Zth(j-a) (K/W) 0.5 0.33 0.25 10 0.1 0 1 10−3 0.2 0.05 0.02 0.01 10−2 10−1 1 102 10 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 7. Characteristics Table 7. Characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VF forward voltage IF = 0.5 A - 360 - mV IF = 1 A - 400 - mV IR Cd trr [1] reverse current diode capacitance IF = 2 A - 470 535 mV VR = 10 V - 5 - μA VR = 40 V - 20 100 μA f = 1 MHz VR = 1 V - 270 - pF VR = 10 V - 100 - pF - 85 - ns reverse recovery time When switched from IF = 10 mA to IR = 10 mA; RL = 100 Ω; measured at IR = 1 mA. PMEG4020EPA_1 Product data sheet [1] © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 5 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 006aab817 10 IF (A) (1) 1 006aab818 10−2 IR (A) 10−3 (1) (2) (2) 10−4 10−1 10−5 (3) (4) (3) (5) 10−6 10−2 10−7 10−3 10−8 (4) 10−4 0.0 10−9 0.1 0.2 0.3 0.4 0.5 0.6 0.7 VF (V) 0 10 20 30 40 VR (V) (1) Tj = 150 °C (1) Tj = 125 °C (2) Tj = 125 °C (2) Tj = 85 °C (3) Tj = 85 °C (3) Tj = 25 °C (4) Tj = 25 °C (4) Tj = −40 °C (5) Tj = −40 °C Fig 4. Forward current as a function of forward voltage; typical values Fig 5. Reverse current as a function of reverse voltage; typical values 006aab819 600 Cd (pF) 400 200 0 0 10 20 30 40 VR (V) f = 1 MHz; Tamb = 25 °C Fig 6. Diode capacitance as a function of reverse voltage; typical values PMEG4020EPA_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 6 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 006aab820 1.5 (4) PF(AV) (W) 006aab821 0.7 PR(AV) (W) 0.6 (3) 0.5 1.0 (2) 0.4 (1) (1) (2) 0.3 (3) 0.5 0.2 (4) 0.1 0.0 0.0 0.0 1.0 2.0 3.0 0 10 20 30 IF(AV) (A) Tj = 150 °C Tj = 125 °C (1) δ = 0.1 (1) δ = 1 (2) δ = 0.2 (2) δ = 0.9 (3) δ = 0.5 (3) δ = 0.8 (4) δ = 1 Fig 7. (4) δ = 0.5 Average forward power dissipation as a function of average forward current; typical values 006aab822 3.0 IF(AV) (A) Fig 8. Average reverse power dissipation as a function of reverse voltage; typical values 006aab823 3.0 (1) IF(AV) (A) 2.0 40 VR (V) 2.0 (1) (2) (2) (3) (3) 1.0 1.0 (4) (4) 0 0 0 25 50 75 100 125 150 175 Tamb (°C) 0 25 50 Tj = 150 °C 125 150 175 Tamb (°C) Tj = 150 °C (1) δ = 1; DC (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz (4) δ = 0.1; f = 20 kHz Average forward current as a function of ambient temperature; typical values Fig 10. Average forward current as a function of ambient temperature; typical values PMEG4020EPA_1 Product data sheet 100 FR4 PCB, mounting pad for cathode 1 cm2 FR4 PCB, standard footprint Fig 9. 75 © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 7 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 006aab824 3.0 006aab825 3.0 (1) (1) IF(AV) (A) IF(AV) (A) 2.0 2.0 (2) (2) (3) (3) 1.0 1.0 (4) (4) 0 0 0 25 50 75 100 125 150 175 Tamb (°C) 0 25 50 75 100 125 150 175 Tsp (°C) Tj = 150 °C Ceramic PCB, Al2O3, standard footprint Tj = 150 °C (1) δ = 1; DC (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig 11. Average forward current as a function of ambient temperature; typical values Fig 12. Average forward current as a function of solder point temperature; typical values PMEG4020EPA_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 8 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 8. Test information P duty cycle δ = t2 t1 t2 t1 t 006aaa812 Fig 13. Duty cycle definition The current ratings for the typical waveforms as shown in Figure 9, 10, 11 and 12 are calculated according to the equations: I F ( AV ) = I M × δ with IM defined as peak current, I RMS = I F ( AV ) at DC, and I RMS = I M × δ with IRMS defined as RMS current. 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 1.3 0.65 max 0.35 0.25 1 1.05 0.95 2 0.45 0.35 1.1 0.9 0.3 0.2 2.1 1.9 3 1.6 1.4 Dimensions in mm 2.1 1.9 09-11-12 Fig 14. Package outline SOT1061 PMEG4020EPA_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 9 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 4 mm pitch, 8 mm tape and reel -115 3000 PMEG4020EPA SOT1061 [1] For further information and the availability of packing methods, see Section 14. 11. Soldering 2.1 1.3 0.5 (2×) 0.4 (2×) 0.5 (2×) 0.6 (2×) 1.05 2.3 0.6 0.55 0.25 1.1 0.25 1.2 0.25 0.4 0.5 1.6 1.7 Dimensions in mm solder paste = solder lands solder resist occupied area sot1061_fr Reflow soldering is the only recommended soldering method. Fig 15. Reflow soldering footprint SOT1061 PMEG4020EPA_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 10 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PMEG4020EPA_1 20091216 Product data sheet - - PMEG4020EPA_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 11 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. Definition [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. NXP Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local NXP Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com PMEG4020EPA_1 Product data sheet © NXP B.V. 2009. All rights reserved. Rev. 01 — 16 December 2009 12 of 13 PMEG4020EPA NXP Semiconductors 2 A low VF MEGA Schottky barrier rectifier 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Quality information . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9 Packing information . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Contact information. . . . . . . . . . . . . . . . . . . . . 12 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © NXP B.V. 2009. All rights reserved. For more information, please visit: http://www.nxp.com For sales office addresses, please send an email to: salesaddresses@nxp.com Date of release: 16 December 2009 Document identifier: PMEG4020EPA_1
PMEG4020EPA,115 价格&库存
很抱歉,暂时无法提供与“PMEG4020EPA,115”相匹配的价格&库存,您可以联系我们找货
PMEG4020EPA,115
  • 1+5.827351+0.74782
  • 10+3.6191510+0.46444
  • 100+2.31066100+0.29653
  • 500+1.74667500+0.22415
  • 1000+1.564681000+0.20080
PMEG4020EPA,115
  • 3000+1.333233000+0.17109
  • 6000+1.216566000+0.15612
  • 9000+1.157119000+0.14849
  • 15000+1.0902815000+0.13992
  • 21000+1.0507221000+0.13484
  • 30000+1.0122530000+0.12990
