BAS70L,315
BAS70L,315
    NEXPERIA(安世)
    SOD-882
    肖特基二极管 70V 1.02 x 0.62mm SMT SOD882 70mA
BAS70L,315 数据手册
BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes Rev. 10 — 7 April 2021 Product data sheet 1. Product profile 1.1. General description General-purpose Schottky diodes in small Surface-Mounted Device (SMD) plastic packages. Table 1. Product overview Type number Package Configuration Nexperia JEITA 1PS76SB70 SOD323 SC-76 single diode 1PS79SB70 SOD523 SC-79 single diode BAS70 SOT23 - single diode BAS70H SOD123F - single diode BAS70L SOD882 - single diode BAS70W SOT323 SC-70 single diode BAS70-04 SOT23 - dual series BAS70-04W SOT323 SC-70 dual series BAS70-05 SOT23 - dual common cathode BAS70-05W SOT323 SC-70 dual common cathode BAS70-06 SOT23 - dual common anode BAS70-06W SOT323 SC-70 dual common anode BAS70-07 SOT143B - dual isolated BAS70-07S SOT363 SC-88 dual isolated BAS70-07V SOT666 - dual isolated BAS70VV SOT666 BAS70XY SOT363 triple isolated SC-88 quadruple; 2 series Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 1.2. Features and benefits • • • • • High switching speed Low leakage current High breakdown voltage Low capacitance AEC-Q101 qualified 1.3. Applications • • Ultra high-speed switching Voltage clamping 1.4. Quick reference data Table 2. Quick reference data Symbol Parameter Conditions Min Typ Max Unit - - 70 mA Per diode IF forward current VF forward voltage IF = 1 mA [1] - - 410 mV VR reverse voltage Tj = 25 °C - - 70 V [1] BAS70_1PS7XSB70_SER Product data sheet Pulse test: tp ≤ 300 μs; δ ≤ 0.02. All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 2 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 2. Pinning information Table 3. Pinning Pin Symbol Description Simplified outline Symbol BAS70H; 1PS76SB70; 1PS79SB70 1 K cathode 2 A anode K cathode [1] 1 2 K A sym001 BAS70L 1 2 A [1] K 1 anode 2 A sym001 Transparent top view BAS70; BAS70W 1 A anode 2 n.c. not connected 3 K cathode 3 K n.c. A 006aaa436 1 2 BAS70-04; BAS70-04W 1 A1 anode (diode 1) 2 K2 cathode (diode 2) 3 K1; A2 cathode (diode1), anode (diode 2) 3 K1; A2 A1 K2 006aaa437 1 2 BAS70-05; BAS70-05W 1 A1 anode (diode 1) 2 A2 anode (diode 2) 3 K1; K2 cathode (diode 1), cathode (diode 2) 3 K1; K2 1 A1 2 A2 006aaa438 BAS70-06; BAS70-06W 1 K1 cathode (diode 1) 2 K2 cathode (diode 2) 3 A1; A2 anode (diode 1), anode (diode 2) 3 A1; A2 K1 K2 006aaa439 1 2 BAS70-07 BAS70_1PS7XSB70_SER Product data sheet 1 K1 cathode (diode 1) 2 K2 cathode (diode 2) 3 A2 anode (diode 2) 4 A1 anode (diode 1) All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 4 1 3 2 A1 A2 K1 K2 006aaa434 © Nexperia B.V. 2021. All rights reserved 3 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes Pin Symbol Description Simplified outline Symbol BAS70-07S; BAS70-07V 1 A1 anode (diode 1) 2 n.c. not connected 3 K2 cathode (diode 2) 4 A2 anode (diode 2) 5 n.c. not connected 6 K1 cathode (diode 1) 1 A1 anode (diode 1) 2 A2 anode (diode 2) 3 A3 anode (diode 3) 4 K3 cathode (diode 3) 5 K2 cathode (diode 2) 6 K1 cathode (diode 1) 1 A1 anode (diode 1) 2 K2 cathode (diode 2) 3 A3; K4 anode (diode 3), cathode (diode 4) 4 A4 anode (diode 4) 5 K3 cathode (diode 3) 6 5 K 4 n.c. D1 1 2 A 3 A D2 n.c. K K1 K2 K3 A1 A2 006aaa440 BAS70VV 6 5 1 4 2 A3 sym046 3 BAS70XY 6 [1] BAS70_1PS7XSB70_SER Product data sheet K1; A2 6 5 4 1 2 3 K1; A2 A1 cathode (diode 1), anode (diode 2) K3 K2 A4 A3; K4 006aaa256 The marking bar indicates the cathode. All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 4 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 3. Ordering information Table 4. Ordering information Type number Package BAS70_1PS7XSB70_SER Product data sheet Name Description Version 1PS76SB70 SC-76 plastic surface-mounted package; 2 leads SOD323 1PS79SB70 SC-79 plastic surface-mounted package; 2 leads SOD523 BAS70 - plastic surface-mounted package; 3 leads SOT23 BAS70H - plastic surface-mounted package; 2 leads SOD123F BAS70L - leadless ultra small plastic package; 2 leads SOD882 BAS70W SC-70 plastic surface-mounted package; 3 leads SOT323 BAS70-04 - plastic surface-mounted package; 3 leads SOT23 BAS70-04W SC-70 plastic surface-mounted package; 3 leads SOT323 BAS70-05 - plastic surface-mounted package; 3 leads SOT23 BAS70-05W SC-70 plastic surface-mounted package; 3 leads SOT323 BAS70-06 - plastic surface-mounted package; 3 leads SOT23 BAS70-06W SC-70 plastic surface-mounted package; 3 leads SOT323 BAS70-07 - plastic surface-mounted package; 4 leads SOT143B BAS70-07S SC-88 plastic surface-mounted package; 6 leads SOT363 BAS70-07V - plastic surface-mounted package; 6 leads SOT666 BAS70VV - plastic surface-mounted package; 6 leads SOT666 BAS70XY SC-88 plastic surface-mounted package; 6 leads SOT363 All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 5 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 4. Marking Table 5. Marking codes Type number Marking code [1] Type number Marking code [1] 1PS76SB70 S2 BAS70-05W 75% 1PS79SB70 G BAS70-06 76% BAS70 73% BAS70-06W 76% BAS70H AH BAS70-07 77% BAS70L S8 BAS70-07S 77% BAS70W 73% BAS70-07V 77 BAS70-04 74% BAS70VV N1 BAS70-04W 74% BAS70XY 70% BAS70-05 75% - - [1] % indicates the assembly center 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage Tj = 25 °C - 70 V IF forward current - 70 mA IFRM repetitive peak forward current tp ≤ 1 s; δ ≤ 0.5 - 70 mA IFSM non-repetitive peak forward current tp ≤ 10 ms [1] - 100 mA Tj junction temperature - 150 °C Tamb ambient temperature -65 +150 °C Tstg storage temperature -65 +150 °C Per diode [1] BAS70_1PS7XSB70_SER Product data sheet Tj = 25 °C prior to surge. All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 6 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 6. Thermal characteristics Table 7. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit Per device Rth(j-a) Rth(j-sp) thermal resistance from junction to ambient [2] [3] [1] • SOT23 - - 500 K/W • SOT143B - - 500 K/W • SOT363 (BAS70-07S) - - 416 K/W • SOT666 (BAS70VV) [2] - - 700 K/W • SOT666 (BAS70-07V) [2] - - 416 K/W • SOD123F [2] - - 330 K/W • SOD323 - - 450 K/W • SOD523 [2] - - 450 K/W • SOD882 [2] - - 500 K/W • SOT323 - - 625 K/W [3] - - 260 K/W thermal resistance from junction to solder point • [1] in free air SOT363 (BAS70XY) Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. Reflow soldering is the only recommended soldering method. Soldering point at pins 2, 3, 5 and 6. 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit IF = 1 mA - - 410 mV IF = 10 mA - - 750 mV IF = 15 mA - - 1 V VR = 50 V - - 100 nA VR = 70 V - - 10 μA VR = 0 V; f = 1 MHz - - 2 pF Per diode VF IR Cd [1] BAS70_1PS7XSB70_SER Product data sheet [1] forward voltage reverse current diode capacitance Pulse test: tp ≤ 300 μs; δ ≤ 0.02. All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 7 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes mra803 102 mra805 102 IR (µA) IF (mA) (1) 10 10 (2) 1 1 10- 1 10- 1 10- 2 (1) 10- 2 0 (2) (3) (4) 0.2 0.4 0.6 0.8 VF (V) 1 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (4) Tamb = -40 °C Fig. 1. (3) 10- 3 0 20 40 60 VR (V) 80 (1) Tamb = 125 °C (2) Tamb = 85 °C (3) Tamb = 25 °C Forward current as a function of forward voltage; typical values Fig. 2. mra802 103 Reverse current as a funciton of reverse voltage; typical values mra804 2 Cd (pF) rdif (Ω) 1.5 102 1 10 0.5 1 10- 1 1 10 IF (mA) 0 102 20 40 60 VR (V) 80 Tamb = 25 °C; f = 1 MHz f = 10 kHz Fig. 3. 0 Differential resistance as a function of forward current; typical values Fig. 4. Diode capacitance as a function of reverse voltage; typical values 8. Test information 8.1. Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 8 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 9. Package outline 1.35 1.15 0.45 0.15 1 2.7 2.3 0.85 0.75 1.1 0.8 1 1.65 1.25 1.55 1.15 1.8 1.6 2 2 0.40 0.25 0.25 0.10 Dimensions in mm Fig. 5. 0.65 0.58 0.34 0.26 03-12-17 Package outline SOD323 (SC-76) 3.0 2.8 0.17 0.11 Dimensions in mm Fig. 6. 02-12-13 Package outline SOD523 (SC-79) 1.7 1.5 1.1 0.9 1.2 1.0 1 3 2.5 1.4 2.1 1.2 3.6 3.4 1 0.48 0.38 Dimensions in mm Package outline SOT23 (TO-236AB) 0.30 0.22 Fig. 8. 04-11-29 Package outline SOD123F 2.2 1.8 1.1 0.8 0.45 0.15 3 1.02 0.95 2.2 1.35 2.0 1.15 1 0.55 0.47 0.25 0.10 Dimensions in mm 0.50 0.46 0.65 1 cathode marking on top side (if applicable) Dimensions in mm 03-04-17 Package outline SOD882 (DFN1006-2) Product data sheet 0.70 0.55 2 0.30 0.22 BAS70_1PS7XSB70_SER 2 0.15 0.09 18-03-12 0.62 0.55 Fig. 9. 2.7 2.5 2 1.9 Fig. 7. 0.55 0.35 0.45 0.15 2 1.3 0.4 0.3 0.25 0.10 Dimensions in mm 04-11-04 Fig. 10. Package outline SOT323 (SC-70) All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 9 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 3.0 2.8 1.9 4 2.5 2.1 2.2 1.8 1.1 0.9 6 3 0.45 0.15 1.4 1.2 1 2.2 1.35 2.0 1.15 0.48 0.38 5 4 2 3 1 0.15 0.09 0.65 1.7 1.3 Dimensions in mm 04-11-16 0.45 0.15 pin 1 index 2 0.88 0.78 1.1 0.8 0.25 0.10 0.3 0.2 Dimensions in mm 14-10-03 Fig. 12. Package outline SOT363 (SC-88) Fig. 11. Package outline SOT143B 1.7 1.5 6 0.6 0.5 5 4 0.3 0.1 1.7 1.5 1.3 1.1 pin 1 index 1 2 0.5 1 3 0.27 0.17 Dimensions in mm 0.18 0.08 04-11-08 Fig. 13. Package outline SOT666 BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 10 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 10. Soldering Table 9. Soldering 3.05 2.1 solder lands solder resist 1.65 0.95 0.5 (2×) 0.6 (2×) solder paste occupied area 2.2 Dimensions in mm 0.5 (2×) 0.6 (2×) sod323_fr Fig. 14. Reflow soldering footprint SOD323 (SC-76) 5 2.9 1.5 (2×) solder lands solder resist occupied area 2.75 1.2 (2×) Dimensions in mm preferred transport direction during soldering sod323_fw Fig. 15. Wave soldering footprint SOD323 (SC-76) 2.15 1.4 solder lands solder resist 0.5 0.6 (2×) (2×) 1.2 solder paste occupied area Dimensions in mm 0.4 (2×) 0.5 (2×) sod523_fr Fig. 16. Reflow soldering footprint SOD523 (SC-79) BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 11 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 3.3 2.9 1.9 solder lands 3 solder resist 2 1.7 solder paste occupied area 0.6 (3×) 0.7 (3×) Dimensions in mm 0.5 (3×) 0.6 (3×) 1 sot023_fr Fig. 17. Reflow soldering footprint SOT23 (TO-236AB) 2.2 1.2 (2×) 1.4 (2×) solder lands 4.6 solder resist 2.6 occupied area Dimensions in mm 1.4 preferred transport direction during soldering 2.8 4.5 sot023_fw Fig. 18. Wave soldering footprint SOT23 (TO-236AB) BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 12 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes Footprint information for reflow soldering of plastic surface-mounted, 2 leads package SOD123F 4.4 2.9 2.8 1.1 1.2 (2×) (2×) 2.1 1.6 1.1 (2×) 1.2 (2×) solder land solder land plus solder paste solder paste deposit solder resist occupied area Dimensions in mm sod123f_fr Fig. 19. Reflow soldering footprint SOD123F 1.3 0.7 R0.05 (8×) solder lands 0.6 0.7 0.8 (2×) (2×) (2×) 0.9 solder resist solder paste occupied area 0.3 (2×) Dimensions in mm 0.4 (2×) 0.5 (2×) sod882_fr Fig. 20. Reflow soldering footprint SOD882 BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 13 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 2.65 1.85 1.325 solder lands solder resist 2 2.35 0.6 (3×) 3 solder paste 1.3 occupied area 0.5 (3×) 1 Dimensions in mm 0.55 (3×) sot323_fr Fig. 21. Reflow soldering footprint SOT323 (SC-70) 4.6 2.575 1.425 (3×) solder lands solder resist occupied area 1.8 3.65 2.1 09 (2×) Dimensions in mm preferred transport direction during soldering sot323_fw Fig. 22. Wave soldering footprint SOT323 (SC-70) 3.25 0.6 (3×) 0.5 (3×) 1.9 solder lands 0.7 0.6 (3×) (3×) solder resist 2 3 solder paste occupied area 0.7 0.6 Dimensions in mm 0.75 0.95 0.9 1 sot143b_fr Fig. 23. Reflow soldering footprint SOT143B BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 14 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 4.45 2.2 1.2 (3×) 1.425 (3×) solder lands 4.6 solder resist 2.575 occupied area 1.425 Dimensions in mm preferred transport direction during soldering 1 1.2 sot143b_fw Fig. 24. Wave soldering footprint SOT143B 2.65 solder lands 2.35 1.5 0.4 (2×) 0.6 0.5 (4×) (4×) solder resist solder paste 0.5 (4×) 0.6 (2×) occupied area 0.6 (4×) Dimensions in mm 1.8 sot363_fr Fig. 25. Reflow soldering footprint SOT363 (SC-88) 1.5 solder lands 0.3 2.5 4.5 1.5 solder resist occupied area Dimensions in mm 1.3 preferred transport direction during soldering 1.3 2.45 5.3 sot363_fw Fig. 26. Wave soldering footprint SOT363 (SC-88) BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 15 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 2.75 2.45 2.1 1.6 0.538 2 1.7 1.075 0.4 (6×) 0.25 (2×) 0.55 (2×) solder lands 0.3 (2×) placement area solder paste occupied area 0.325 0.375 (4×) (4×) 1.7 0.45 (4×) 0.6 (2×) 0.5 (4×) 0.65 (2×) Dimensions in mm sot666_fr Fig. 27. Reflow soldering footprint SOT666 BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 16 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes 11. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BAS70_1PS7XSB70_SER v.10 20210407 Product data sheet - BAS70_1PS7XSB70_SER_9 Modifications: • • • Soldering: Reflow soldering footprint SOD523 (SC-76) was updated. The format of this data sheet has been redesigned to comply with the new identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. BAS70_1PS7XSB70_SER_9 20060504 Product data sheet - BAS70_1PS7XSB70_SER_8 BAS70_1PS7XSB70_SER_8 20060504 Product data sheet - BAS70_1PS7XSB70_SER_7 BAS70_1PS7XSB70_SER_7 20050718 Product data sheet - 1PS76SB70_2 1PS79SB70_1 BAS70H_1 BAS70L_1 BAS70-07V_1 BAS70VV BAS70W_3 BAS70-07S_4 BAS70_SERIES_6 1PS76SB70_2 20040126 Product specification - 1PS76SB70_SER_1 1PS76SB70_1 19980716 Product specification - - BAS70H_1 20050425 Product data sheet - - BAS70L_1 20030520 Product specification - - BAS70-07V_1 20020117 Product specification - - BAS70VV_1 20040910 Product data sheet - - BAS70W_3 19990326 Product data sheet - BAS70W_2 BAS70-07S_4 20030411 Product specification - BAS70_07S_3 BAS70_SERIES_6 20011011 Product specification - BAS70_5 BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 17 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 12. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 18 / 19 Nexperia BAS70 series; 1PS7XSB70 series General-purpose Schottky diodes Contents 1. Product profile.............................................................. 1 1.1. General description......................................................1 1.2. Features and benefits..................................................2 1.3. Applications................................................................. 2 1.4. Quick reference data................................................... 2 2. Pinning information......................................................3 3. Ordering information....................................................5 4. Marking.......................................................................... 6 5. Limiting values............................................................. 6 6. Thermal characteristics............................................... 7 7. Characteristics.............................................................. 7 8. Test information............................................................8 8.1. Quality information.......................................................8 9. Package outline............................................................ 9 10. Soldering................................................................... 11 11. Revision history........................................................ 17 12. Legal information......................................................18 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 7 April 2021 BAS70_1PS7XSB70_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 10 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 19 / 19
BAS70L,315 价格&库存
很抱歉,暂时无法提供与“BAS70L,315”相匹配的价格&库存,您可以联系我们找货
BAS70L,315
    • 10000+0.20900
    库存:290000
    BAS70L,315
    • 1+1.674841+0.21709
    • 10+1.0497110+0.13607
    • 100+0.64754100+0.08394
    • 500+0.47126500+0.06109
    • 1000+0.413921000+0.05366
    • 2000+0.365492000+0.04738
    • 5000+0.312865000+0.04056
