PMEG2005BELD,315
PMEG2005BELD,315
    NEXPERIA(安世)
    SOD-882D
    直流反向耐压(Vr):20V 平均整流电流(Io):500mA 正向压降(Vf):390mV@500mA
PMEG2005BELD,315 数据手册
PMEG2005BELD 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 4 August 2015 Product data sheet 1. General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with an integrated guard ring for stress protection, encapsulated in a leadless ultra small SOD882D (DFN1006D-2) Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. 2. Features and benefits • • • • • • • Average forward current: IF(AV) ≤ 0.5 A Reverse voltage: VR ≤ 20 V Low forward voltage VF ≤ 390 mV AEC-Q101 qualified Ultra small and leadless SMD plastic package Solderable side pads Package height typ. 0.37 mm 3. Applications • • • • • • • Low voltage rectification High efficiency DC-to-DC conversion Switch mode power supply Reverse polarity protection Low power consumption applications Ultra high-speed switching LED backlight for mobile application 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF(AV) average forward current δ = 0.5 ; f = 20 kHz; Tsp ≤ 140 °C; - - 0.5 A - - 0.5 A Tj = 25 °C - - 20 V IF = 500 mA; pulsed; tp ≤ 300 µs; - 353 390 mV - 28 50 µA square wave δ = 0.5 ; f = 20 kHz; Tamb ≤ 115 °C; [1] square wave VR reverse voltage VF forward voltage δ ≤ 0.02 ; Tj = 25 °C IR reverse current VR = 10 V; Tj = 25 °C PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for 2 cathode 1 cm . 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K cathode[1] 2 A anode Simplified outline Graphic symbol 1 1 2 2 sym001 Transparent top view DFN1006D-2 (SOD882D) [1] The marking bar indicates the cathode. 6. Ordering information Table 3. Ordering information Type number PMEG2005BELD Package Name Description Version DFN1006D-2 DFN1006D-2: leadless ultra small plastic package; 2 terminals SOD882D 7. Marking Table 4. Marking codes Type number Marking code PMEG2005BELD 0010 1000 CATHODE BAR READING DIRECTION VENDOR CODE READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac477 Fig. 1. SOD882D binary marking code description PMEG2005BELD Product data sheet All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 2 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage Tj = 25 °C - 20 V IF forward current Tsp ≤ 140 °C - 0.5 A IF(AV) average forward current δ = 0.5 ; f = 20 kHz; Tsp ≤ 140 °C; - 0.5 A - 0.5 A square wave δ = 0.5 ; f = 20 kHz; Tamb ≤ 115 °C; [1] square wave IFRM repetitive peak forward current tp ≤ 1 ms; δ ≤ 0.25 - 3 A IFSM non-repetitive peak forward current tp = 8 ms; Tj(init) = 25 °C; square wave - 6 A Ptot total power dissipation Tamb ≤ 25 °C [2][3] - 370 mW [1][3] - 735 mW [4][3] - 1135 mW Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C PMEG2005BELD Product data sheet [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for [2] [3] [4] cathode 1 cm . Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Reflow soldering is the only recommended soldering method. Device mounted on a ceramic PCB, Al2O3, standard footprint. 2 All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 3 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) Min thermal resistance from junction to solder point [1] [2] [3] [4] [5] [6] Typ Max Unit [1][2][3] - - 340 K/W [1][4][3] - - 170 K/W [1][5][3] - - 110 K/W - - 25 K/W [6] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Reflow soldering is the only recommended soldering method. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm . Device mounted on a ceramic PCB, Al2O3, standard footprint. Soldering point of cathode tab. 006aac928 103 duty cycle = Zth(j-a) (K/W) 0.75 1 0.5 102 0.33 0.2 0.25 0.1 0.05 0 10 10-3 0.02 0.01 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMEG2005BELD Product data sheet All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 4 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 006aac929 103 Zth(j-a) (K/W) duty cycle = 1 0.75 0.5 102 0.33 0.2 0.1 0 0.05 0.02 0.01 0.25 10 10-3 10-2 10-1 FR4 PCB, mounting pad for cathode 1 cm Fig. 3. 1 102 10 tp (s) 103 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aac930 103 Zth(j-a) (K/W) duty cycle = 102 1 0.75 0.5 0.33 0.2 0 10 10-3 0.25 0.1 0.05 0.02 0.01 10-2 10-1 1 102 10 tp (s) 103 Ceramic PCB, Al2O3, standard footprint Fig. 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 10. Characteristics Table 7. Characteristics Symbol Parameter VF forward voltage Conditions Min Typ Max Unit IF = 0.1 mA; pulsed; tp ≤ 300 µs; - 79 105 mV - 137 170 mV - 197 235 mV δ ≤ 0.02 ; Tj = 25 °C IF = 1 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C IF = 10 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C PMEG2005BELD Product data sheet All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 5 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier Symbol Parameter Conditions Min Typ Max Unit IF = 100 mA; pulsed; tp ≤ 300 µs; - 266 310 mV - 353 390 mV VR = 10 V; Tj = 25 °C - 28 50 µA VR = 20 V; Tj = 25 °C - 87 200 µA δ ≤ 0.02 ; Tj = 25 °C IF = 500 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C IR reverse current Cd diode capacitance VR = 1 V; f = 1 MHz; Tj = 25 °C - 31 40 pF trr reverse recovery time IF = 0.5 A; IR = 0.5 A; IR(meas) = 0.1 A; - 1.6 - ns - 565 - mV Tj = 25 °C VFRM peak forward recovery voltage IF = 0.5 A; dIF/dt = 20 A/µs; Tj = 25 °C 006aac931 1 IF (A) 10-1 (1) (2) (3) (4) 006aac932 10-1 IR (A) 10-2 (1) (2) 10-3 (5) 10-4 (3) 10-2 10-5 10-6 10-3 (4) 10-7 10-4 0.0 0.1 0.2 0.3 0.4 VF (V) 0.5 0 5 (1) Tj = 150 °C (1) Tj = 125 °C (2) Tj = 125 °C (2) Tj = 85 °C (3) Tj = 85 °C (3) Tj = 25 °C (4) Tj = 25 °C (4) Tj = −40 °C (5) Tj = −40 °C Fig. 5. 10-8 Fig. 6. Forward current as a function of forward voltage; typical values PMEG2005BELD Product data sheet 15 VR (V) 20 Reverse current as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. 4 August 2015 10 © Nexperia B.V. 2017. All rights reserved 6 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 006aac933 70 Cd (pF) 60 006aac934 0.25 PF(AV) (W) (4) 0.20 (3) 50 (2) 0.15 40 30 (1) 0.10 20 0.05 10 0 Fig. 7. 0 5 10 15 VR (V) 0.00 0.00 20 0.25 f = 1 MHz; Tamb = 25 °C Tj = 150 °C Diode capacitance as a function of reverse voltage; typical values (1) δ = 0.1 (2) δ = 0.2 (3) δ = 0.5 (4) δ = 1 Fig. 8. 006aac935 1.2 PR(AV) (W) 0.75 006aac936 0.75 (1) (2) 0.50 (1) IF(AV) (A) Average forward power dissipation as a function of average forward current; typical values IF(AV) (A) 0.8 0.50 (2) (3) (3) 0.4 0.25 (4) (4) 0.0 0 5 10 15 VR (V) 20 0.00 Tj = 125 °C Average reverse power dissipation as a function of reverse voltage; typical values PMEG2005BELD Product data sheet 25 50 75 100 125 150 175 Tamb (°C) FR4 PCB, standard footprint Tj = 150 °C (1) δ = 1 (DC) (2) δ = 0.9; f = 20 kHz (3) δ = 0.8; f = 20 kHz (4) δ = 0.5; f = 20 kHz Fig. 9. 0 (1) δ = 1 (2) δ = 0.5 (3) δ = 0.2 (4) δ = 0.1 Fig. 10. Average forward current as a function of ambient temperature; typical values All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 7 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 006aac937 0.75 (1) IF(AV) (A) (1) IF(AV) (A) (2) 0.50 006aac938 0.75 (2) 0.50 (3) (3) 0.25 0.25 (4) 0.00 0 25 50 (4) 75 100 125 0.00 150 175 Tamb (°C) FR4 PCB, mounting pad for cathode 1 cm Tj = 150 °C 0 25 50 75 100 125 150 175 Tamb (°C) Ceramic PCB, Al2O3, standard footprint 2 Tj = 150 °C (1) δ = 1 (2) δ = 0.5 (3) δ = 0.2 (4) δ = 0.1 (1) δ = 1 (2) δ = 0.5 (3) δ = 0.2 (4) δ = 0.1 Fig. 12. Average forward current as a function of ambient temperature; typical values Fig. 11. Average forward current as a function of ambient temperature; typical values 006aac939 0.75 (1) IF(AV) (A) (2) 0.50 (3) 0.25 (4) 0.00 0 25 50 75 100 125 150 175 Tsp (°C) Tj = 150 °C (1) δ = 1 (2) δ = 0.5 (3) δ = 0.2 (4) δ = 0.1 Fig. 13. Average forward current as a function of solder point temperature; typical values PMEG2005BELD Product data sheet All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 8 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 11. Test information IF IR(meas) time IR trr 006aad022 Fig. 14. Reverse recovery definition IF time VF VFRM VF time 001aab912 Fig. 15. Forward recovery definition P tcy duty cycle δ = tp tcy tp t 006aac658 Fig. 16. Duty cycle definition The current ratings for the typical waveforms are calculated according to the equations: IF(AV) = IM × δ with IM defined as peak current, IRMS = IF(AV) at DC, and IRMS = IM × √δ with IRMS defined as RMS current. PMEG2005BELD Product data sheet All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 9 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 11.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 0.65 0.55 0.4 max 2 0.30 0.22 1.05 0.95 0.65 1 0.30 0.22 0.55 0.45 cathode marking on top side (if applicable) Dimensions in mm 12-05-01 Fig. 17. Package outline DFN1006D-2 (SOD882D) 13. Soldering 1.4 0.2 solder lands 0.8 (2×) 0.6 (2×) solder resist 0.7 (2×) solder paste Dimensions in mm 0.3 0.4 1 1.3 sod882d_fr Fig. 18. Reflow soldering footprint for DFN1006D-2 (SOD882D) PMEG2005BELD Product data sheet All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 10 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 14. Revision history Table 8. Revision history Document ID Release date Document status Change notice Supersedes PMEG2005BELD v.4 20150804 Product data sheet - PMEG2005BELD v.3 Modifications: • PMEG2005BELD v.3 20120704 Product data sheet - PMEG2005BELD v.2 PMEG2005BELD v.2 20120312 Product data sheet - PMEG2005BELD v.1 PMEG2005BELD v.1 20120111 Preliminary data sheet - - PMEG2005BELD Product data sheet Section "Marking": updated Figure 1. All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 11 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 15. Legal information 15.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PMEG2005BELD Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 12 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PMEG2005BELD Product data sheet All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 13 / 14 PMEG2005BELD Nexperia 20 V, 0.5 A low VF MEGA Schottky barrier rectifier 16. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................3 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 5 11 11.1 Test information ..................................................... 9 Quality information ............................................. 10 12 Package outline ................................................... 10 13 Soldering .............................................................. 10 14 Revision history ................................................... 11 15 15.1 15.2 15.3 15.4 Legal information .................................................12 Data sheet status ............................................... 12 Definitions ...........................................................12 Disclaimers .........................................................12 Trademarks ........................................................ 13 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 04 August 2015 PMEG2005BELD Product data sheet All information provided in this document is subject to legal disclaimers. 4 August 2015 © Nexperia B.V. 2017. All rights reserved 14 / 14
PMEG2005BELD,315
物料型号:PMEG2005BELD
器件简介: - 这是一个20V,0.5A的低正向电压(VF) MEGA Schottky势垒整流器。 - 它具有集成的防护环,用于应力保护,并封装在无引脚超小型SOD882D (DFN1006D-2)表面贴装设备(SMD)塑料封装中,具有可见和可焊的侧面垫。
引脚分配: - 引脚1:K,阴极 - 引脚2:A,阳极
参数特性: - 平均正向电流(IF(AV)) ≤ 0.5A - 反向电压(VR) ≤ 20V - 低正向电压(VF) ≤ 390mV - 通过AEC-Q101认证 - 封装高度典型值0.37mm
功能详解: - 适用于低电压整流、高效率DC-DC转换、开关电源模式、反极性保护、低功耗应用、超高速开关、移动应用的LED背光。
应用信息: - 该整流器适用于需要低电压整流、高效率DC-DC转换、开关模式电源、反极性保护、低功耗应用和超高速开关的场景。
封装信息: - 封装类型:DFN1006D-2,无引脚超小型塑料封装,2个端子。 - 封装高度典型值:0.37mm。
PMEG2005BELD,315 价格&库存
很抱歉,暂时无法提供与“PMEG2005BELD,315”相匹配的价格&库存,您可以联系我们找货
PMEG2005BELD,315
    • 10000+1.92150
    库存:20000
    PMEG2005BELD,315
