PMEG4002ELD,315
PMEG4002ELD,315
    NEXPERIA(安世)
    SOD-882D
    肖特基二极管 40V 340mW SMT SOD882D 200mA 14pF
PMEG4002ELD,315 数据手册
PMEG4002ELD 40 V, 0.2 A low VF MEGA Schottky barrier rectifier Rev. 1 — 20 April 2011 Product data sheet 1. Product profile 1.1 General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with an integrated guard ring for stress protection, encapsulated in a SOD882D leadless ultra small Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. 1.2 Features and benefits     Forward current: IF  0.2 A Reverse voltage: VR  40 V Low forward voltage: VF  600 mV Ultra small and leadless SMD plastic package  AEC-Q101 qualified  Solderable side pads  Package height typ. 0.37 mm 1.3 Applications       Low voltage rectification High efficiency DC-to-DC conversion Switch Mode Power Supply (SMPS) Reverse polarity protection Low power consumption applications Ultra high-speed switching 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter IF(AV) average forward current Conditions reverse current VR reverse voltage VF forward voltage Typ Max Unit - - 0.2 A - - 0.2 A - 0.3 0.5 A - - 40 V - 540 600 mV square wave;  = 0.5; f = 20 kHz Tamb  120 C [1] Tsp  140 C IR Min VR = 25 V IF = 200 mA [2] [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [2] Pulse test: tp  300 s;   0.02. PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 2. Pinning information Table 2. Pinning Pin Description 1 cathode 2 anode Simplified outline Graphic symbol [1] 1 1 2 2 sym001 Transparent top view [1] The marking bar indicates the cathode. 3. Ordering information Table 3. Ordering information Type number PMEG4002ELD Package Name Description Version - leadless ultra small plastic package; 2 terminals; body 1  0.6  0.4 mm SOD882D 4. Marking Table 4. Marking codes Type number Marking code[1] PMEG4002ELD 1011 0000 [1] For SOD882D binary marking code description, see Figure 1. 4.1 Binary marking code description CATHODE BAR READING DIRECTION VENDOR CODE READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac477 Fig 1. PMEG4002ELD Product data sheet SOD882D binary marking code description All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 2 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions VR reverse voltage IF(AV) average forward current Min Max Unit - 40 V - 0.2 A Tsp  140 C - 0.2 A - 1 A square wave;  = 0.5; f = 20 kHz Tamb  120 C PMEG4002ELD Product data sheet [1] IFRM repetitive peak forward current tp  1 ms;   0.25 IFSM non-repetitive peak forward current square wave; tp = 8 ms [2] - 3 A Ptot total power dissipation Tamb  25 C [3] - 340 mW [1] - 660 mW [4] - 1000 mW Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [2] Tj = 25 C prior to surge. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [4] Device mounted on a ceramic PCB, Al2O3, standard footprint. All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 3 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 6. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) Rth(j-sp) Conditions thermal resistance from in free air junction to ambient thermal resistance from junction to solder point Min Typ Max Unit [1][2] - - 370 K/W [1][3] - - 190 K/W [1][4] - - 125 K/W [5] - - 50 K/W [1] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. [2] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [4] Device mounted on a ceramic PCB, Al2O3, standard footprint. [5] Soldering point of cathode tab. 006aac593 103 duty cycle = Zth(j-a) (K/W) 1 0.75 0.5 0.33 102 0.25 0.2 0.1 0.05 0 0.02 0.01 10 10–3 10–2 10–1 1 10 102 103 tp (s) FR4 PCB, standard footprint Fig 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMEG4002ELD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 4 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 006aac594 103 Zth(j-a) (K/W) duty cycle = 1 0.75 102 0.5 0.25 0.33 0.2 0.1 0.05 0.02 0.01 0 10 10–3 10–2 10–1 1 10 102 103 tp (s) FR4 PCB, mounting pad for cathode 1 cm2 Fig 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 006aac595 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.1 10 10–3 0.05 0.02 0.01 0 0.25 0.2 10–2 10–1 1 10 102 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMEG4002ELD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 5 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 7. Characteristics Table 7. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Typ Max IF = 0.1 mA - 190 220 mV IF = 1 mA - 250 290 mV IF = 10 mA - 320 360 mV IF = 100 mA - 450 500 mV forward voltage VF reverse current IR diode capacitance Cd IF = 200 mA - 540 600 mV - 0.3 0.5 A VR = 40 V - 0.6 10 A - 14 20 pF - 4 - ns VR = 1 V; f = 1 MHz [2] reverse recovery time [1] Pulse test: tp  300 s;   0.02. [2] When switched from IF = 10 mA to IR = 10 mA; RL = 100 ; measured at IR = 1 mA. 006aac596 006aac597 10–2 IR (A) 10–3 IF (A) 1 Unit VR = 25 V trr 10 10–1 Min [1] (1) 10–4 (2) 10–5 (3) (1) (2) 10–2 (3) 10–3 10–6 (5) (4) (4) 10–4 0.0 10–7 10–8 0.2 0.4 0.6 0.8 1.0 1.2 1.4 VF (V) 0 10 20 30 40 VR (V) (1) Tj = 150 C (1) Tj = 150 C (2) Tj = 125 C (2) Tj = 125 C (3) Tj = 85 C (3) Tj = 85 C (4) Tj = 25 C (4) Tj = 25 C (5) Tj = 40 C Fig 5. Forward current as a function of forward voltage; typical values PMEG4002ELD Product data sheet Fig 6. Reverse current as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 6 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 006aac598 30 Cd (pF) 20 10 0 0 10 20 30 40 VR (V) f = 1 MHz; Tamb = 25 C Fig 7. Diode capacitance as a function of reverse voltage; typical values 006aac599 0.20 PF(AV) (W) 006aac600 0.020 PR(AV) (W) (4) 0.015 0.15 (3) (2) 0.10 (1) 0.010 (2) (3) (1) 0.005 0.05 0.00 0.0 (4) 0.000 0.1 0.2 0.3 0 10 20 30 IF(AV) (A) Tj = 150 C Tj = 125 C (1)  = 0.1 (1)  = 1 (2)  = 0.2 (2)  = 0.9 (3)  = 0.5 (3)  = 0.8 (4)  = 1 (4)  = 0.5 Fig 8. Average forward power dissipation as a function of average forward current; typical values PMEG4002ELD Product data sheet 40 VR (V) Fig 9. Average reverse power dissipation as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 7 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 006aac601 0.3 006aac602 0.3 (1) (1) IF(AV) (A) IF(AV) (A) (2) (2) 0.2 0.2 (3) (3) 0.1 0.1 (4) (4) 0.0 0.0 0 25 50 75 100 125 150 175 Tamb (°C) 0 25 50 75 100 125 150 175 Tamb (°C) FR4 PCB, mounting pad for cathode 1 cm2 FR4 PCB, standard footprint Tj = 150 C Tj = 150 C (1)  = 1; DC (1)  = 1; DC (2)  = 0.5; f = 20 kHz (2)  = 0.5; f = 20 kHz (3)  = 0.2; f = 20 kHz (3)  = 0.2; f = 20 kHz (4)  = 0.1; f = 20 kHz (4)  = 0.1; f = 20 kHz Fig 10. Average forward current as a function of ambient temperature; typical values 006aac603 0.3 Fig 11. Average forward current as a function of ambient temperature; typical values 006aac604 0.3 (1) (1) IF(AV) (A) IF(AV) (A) (2) (2) 0.2 0.2 (3) (3) 0.1 0.1 (4) (4) 0.0 0.0 0 25 50 75 100 125 150 175 Tamb (°C) 0 25 50 75 100 125 150 175 Tsp (°C) Tj = 150 C Ceramic PCB, Al2O3, standard footprint Tj = 150 C (1)  = 1; DC (1)  = 1; DC (2)  = 0.5; f = 20 kHz (2)  = 0.5; f = 20 kHz (3)  = 0.2; f = 20 kHz (3)  = 0.2; f = 20 kHz (4)  = 0.1; f = 20 kHz (4)  = 0.1; f = 20 kHz Fig 12. Average forward current as a function of ambient temperature; typical values PMEG4002ELD Product data sheet Fig 13. Average forward current as a function of solder point temperature; typical values All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 8 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 8. Test information tr tp t D.U.T. 10 % + IF IF RS = 50 Ω SAMPLING OSCILLOSCOPE V = VR + IF × RS trr t Ri = 50 Ω (1) 90 % VR mga881 input signal output signal (1) IR = 1 mA Fig 14. Reverse recovery time test circuit and waveforms P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig 15. Duty cycle definition The current ratings for the typical waveforms as shown in Figure 10, 11, 12 and 13 are calculated according to the equations: I F  AV  = I M   with IM defined as peak current, I RMS = I F  AV  at DC, and I RMS = I M   with IRMS defined as RMS current. 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PMEG4002ELD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 9 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 9. Package outline 0.65 0.55 0.4 max 2 0.30 0.22 0.65 1.05 0.95 1 0.30 0.22 0.55 0.45 cathode marking on top side Dimensions in mm 10-08-06 Fig 16. Package outline SOD882D 10. Packing information Table 8. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 10000 PMEG4002ELD [1] SOD882D 2 mm pitch, 8 mm tape and reel -315 For further information and the availability of packing methods, see Section 14. 11. Soldering 1.4 0.2 solder lands 0.8 (2×) 0.6 (2×) 0.7 (2×) solder resist solder paste Dimensions in mm 0.3 0.4 1 1.3 sod882d_fr Reflow soldering is the only recommended soldering method. Fig 17. Reflow soldering SOD882D PMEG4002ELD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 10 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes PMEG4002ELD v.1 20110420 Product data sheet - - PMEG4002ELD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 11 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. PMEG4002ELD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 12 of 14 PMEG4002ELD Nexperia 40 V, 0.2 A low VF MEGA Schottky barrier rectifier Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PMEG4002ELD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 20 April 2011 © Nexperia B.V. 2017. All rights reserved 13 of 14 Nexperia PMEG4002ELD 40 V, 0.2 A low VF MEGA Schottky barrier rectifier 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 4.1 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Binary marking code description. . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 9 Quality information . . . . . . . . . . . . . . . . . . . . . . 9 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Packing information . . . . . . . . . . . . . . . . . . . . 10 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 20 April 2011
PMEG4002ELD,315 价格&库存
很抱歉,暂时无法提供与“PMEG4002ELD,315”相匹配的价格&库存,您可以联系我们找货
PMEG4002ELD,315
    PMEG4002ELD,315
    • 1+3.443501+0.44635
    • 10+2.1162110+0.27430
    • 100+1.32858100+0.17221
    • 500+0.98619500+0.12783
    • 1000+0.875281000+0.11346
    • 2000+0.781872000+0.10135
    • 5000+0.680505000+0.08821
