PMEG4010ESBYL
PMEG4010ESBYL
    NEXPERIA(安世)
    SOD993
    肖特基二极管 40V 525mW SMT SOD993 1A 75pF
PMEG4010ESBYL 数据手册
PMEG4010ESB 40 V, 1 A low VF MEGA Schottky barrier rectifier 27 November 2015 Product data sheet 1. General description Planar Maximum Efficiency General Application (MEGA) Schottky barrier rectifier with an integrated guard ring for stress protection in a leadless ultra small DSN1006-2 (SOD993) Surface-Mounted Device (SMD) package. 2. Features and benefits • • • • • Average forward current: IF(AV) ≤ 1 A Reverse voltage: VR ≤ 40 V Low forward voltage, typical: VF = 510 mV Low reverse current, typical: IR = 13 µA Package height typ. 270 µm 3. Applications • • • • • • Low voltage rectification High efficiency DC-to-DC conversion Switch mode power supply Low power consumption applications Ultra high-speed switching LED backlight for mobile application 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF(AV) average forward current δ = 0.5 ; f = 20 kHz; Tsp ≤ 140 °C; - - 1 A VR reverse voltage Tj = 25 °C - - 40 V VF forward voltage IF = 1 A; tp ≤ 300 µs; δ ≤ 0.02 ; - 510 610 mV - 2.1 6 µA - 13 40 µA square wave Tj = 25 °C IR reverse current VR = 20 V; tp ≤ 3 ms; δ ≤ 0.3 ; Tj = 25 °C VR = 40 V; tp ≤ 3 ms; δ ≤ 0.3 ; Tj = 25 °C PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K cathode[1] 2 A anode Simplified outline Graphic symbol 1 1 2 2 sym001 Transparent top view DSN1006-2 (SOD993) [1] The marking bar indicates the cathode. 6. Ordering information Table 3. Ordering information Type number PMEG4010ESB Package Name Description Version DSN1006-2 DSN1006-2, leadless ultra small package; 2 terminals; body 1.0 x 0.6 x 0.27 mm SOD993 7. Marking Table 4. Marking codes Type number Marking code PMEG4010ESB 4E PMEG4010ESB Product data sheet All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 2 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage Tj = 25 °C - 40 V IF forward current Tsp ≤ 135 °C; δ = 1 - 1.4 A IF(AV) average forward current δ = 0.5 ; f = 20 kHz; Tamb ≤ 105 °C; - 1 A - 1 A [1] square wave δ = 0.5 ; f = 20 kHz; Tsp ≤ 140 °C; square wave IFRM repetitive peak forward current tp ≤ 1 ms; δ ≤ 0.25 - 4 A IFSM non-repetitive peak forward current tp = 8 ms; Tj(init) = 25 °C; square wave - 10 A Ptot total power dissipation Tamb ≤ 25 °C [2] - 0.525 W [3] - 1 W [1] - 1.78 W Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] [2] [3] Device mounted on a ceramic Printed-Circuit Board (PCB), Al2O3, standard footprint. Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for anode and cathode 2 1 cm each. 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point [1] PMEG4010ESB Product data sheet Min Typ Max Unit [1][2] - - 240 K/W [1][3] - - 125 K/W [1][4] - - 70 K/W [5] - - 15 K/W [2] [3] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for anode and cathode [4] [5] 1 cm each. Device mounted on a ceramic PCB, Al2O3, standard footprint. Soldering point of anode tab. 2 All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 3 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier aaa-016800 103 Zth(j-a) (K/W) duty cycle = 1 0.5 102 0.25 0.1 10 0 0.75 0.33 0.2 0.05 0.02 0.01 1 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 1. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-016801 103 Zth(j-a) (K/W) duty cycle = 1 102 0.5 0.25 10 0.75 0.33 0.2 0.1 0.05 0 1 10-3 0.02 0.01 10-2 10-1 1 10 102 tp (s) 103 2 FR4 PCB, mounting pad for anode and cathode 1 cm each Fig. 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PMEG4010ESB Product data sheet All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 4 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier aaa-016802 102 duty cycle = 1 Zth(j-a) (K/W) 0.75 0.5 0.33 0.25 0.2 0.1 0.05 10 0.02 0.01 0 1 10-3 10-2 10-1 1 102 10 103 tp (s) Ceramic PCB, Al2O3, standard footprint Fig. 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit V(BR)R reverse breakdown voltage IR = 1 mA; tp = 300 µs; δ = 0.02 ; 40 - - V forward voltage IF = 1 mA; tp ≤ 300 µs; δ ≤ 0.02 ; - 205 - mV - 270 - mV - 340 385 mV - 370 - mV - 430 495 mV - 465 - mV - 510 610 mV VR = 5 V; tp ≤ 3 ms; δ ≤ 0.3 ; Tj = 25 °C - 0.8 - µA VR = 10 V; tp ≤ 3 ms; δ ≤ 0.3 ; - 1 4 µA - 2.1 6 µA VF Tj = 25 °C Tj = 25 °C IF = 10 mA; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C IF = 100 mA; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C IF = 200 mA; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C IF = 500 mA; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C IF = 700 mA; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C IF = 1 A; tp ≤ 300 µs; δ ≤ 0.02 ; Tj = 25 °C IR reverse current Tj = 25 °C VR = 20 V; tp ≤ 3 ms; δ ≤ 0.3 ; Tj = 25 °C PMEG4010ESB Product data sheet All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 5 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier Symbol Parameter Conditions Min Typ Max Unit VR = 40 V; tp ≤ 3 ms; δ ≤ 0.3 ; - 13 40 µA VR = 1 V; f = 1 MHz; Tj = 25 °C - 75 - pF VR = 10 V; f = 1 MHz; Tj = 25 °C - 22 - pF IF = 0.5 A; IR = 0.5 A; IR(meas) = 0.1 A; - 2.9 - ns Tj = 25 °C Cd diode capacitance trr reverse recovery time Tj = 25 °C aaa-017973 10 IR (A) IF (A) 1 10-1 aaa-017974 10-1 10-2 (1) 10-3 (2) 10-4 (1) (2) (3) (4) (3) 10-5 (5) 10-6 10-2 (4) 10-7 10-8 10-3 (5) 10-9 10-4 0.0 Fig. 4. 0.2 0.4 0.6 0.8 VF (V) 1.0 10-10 0 10 pulsed condition (1) Tj = 150 °C pulsed condition (1) Tj = 150 °C (2) Tj = 125 °C (2) Tj = 125 °C (3) Tj = 85 °C (3) Tj = 85 °C (4) Tj = 25 °C (4) Tj = 25 °C (5) Tj = −40 °C (5) Tj = −40 °C Forward current as a function of forward voltage; typical values PMEG4010ESB Product data sheet Fig. 5. 30 VR (V) 40 Reverse current as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. 27 November 2015 20 © Nexperia B.V. 2017. All rights reserved 6 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier aaa-017975 140 Cd (pF) 120 aaa-017976 0.8 (4) PF(AV) (W) (3) 0.6 100 (2) 80 (1) 0.4 60 40 0.2 20 0 Fig. 6. 0 10 20 30 VR (V) 0.0 0.0 40 0.5 f = 1 MHz; Tamb = 25 °C Tj = 150 °C Diode capacitance as a function of reverse voltage; typical values (1) δ = 0.1 (2) δ = 0.2 (3) δ = 0.5 (4) δ = 1 Fig. 7. aaa-017977 0.25 IF(AV) (A) 1.5 Average forward power dissipation as a function of average forward current; typical values aaa-017978 1.5 PR(AV) (W) 1.0 (1) IF(AV) (A) 0.20 (2) 1.0 0.15 (1) (2) (3) (3) 0.10 0.5 (4) 0.05 0.00 (4) 0 10 20 30 VR (V) 0.0 40 Tj = 125 °C Average reverse power dissipation as a function of reverse voltage; typical values PMEG4010ESB Product data sheet 25 50 75 100 125 150 175 Tamb (°C) FR4 PCB, standard footprint Tj = 150 °C (1) δ = 1 (2) δ = 0.9 (3) δ = 0.8 (4) δ = 0.5 Fig. 8. 0 (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig. 9. Average forward current as a function of ambient temperature; typical values All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 7 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier aaa-017979 1.5 (1) IF(AV) (A) (1) IF(AV) (A) (2) 1.0 aaa-017980 1.5 (2) 1.0 (3) (3) 0.5 0.5 (4) 0.0 0 (4) 25 50 75 100 125 0.0 150 175 Tamb (°C) FR4 PCB, mounting pad for anode and cathode 1 0 25 50 75 100 125 150 175 Tamb (°C) Ceramic PCB, Al2O3, standard footprint 2 Tj = 150 °C cm each Tj = 150 °C (1) δ = 1 (DC) (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz (1) δ = 1; DC (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig. 11. Average forward current as a function of ambient temperature; typical values Fig. 10. Average forward current as a function of ambient temperature; typical values aaa-017981 1.5 (1) IF(AV) (A) (2) 1.0 (3) 0.5 (4) 0.0 0 25 50 75 100 125 150 175 Tsp (°C) Tj = 150 °C (1) δ = 1 (DC) (2) δ = 0.5; f = 20 kHz (3) δ = 0.2; f = 20 kHz (4) δ = 0.1; f = 20 kHz Fig. 12. Average forward current as a function of solder point temperature; typical values PMEG4010ESB Product data sheet All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 8 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier 11. Test information IF IR(meas) time IR trr 006aad022 Fig. 13. Reverse recovery definition; step recovery P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 14. Duty cycle definition The current ratings for the typical waveforms are calculated according to the equations: IF(AV) = IM × δ with IM defined as peak current, IRMS = IF(AV) at DC, and IRMS = IM × √δ with IRMS defined as RMS current. 12. Package outline 0.30 0.24 0.65 0.55 1 0.03 max 0.26 0.24 0.65 1.05 0.95 0.26 0.24 Dimensions in mm 2 0.51 0.49 14-10-24 Fig. 15. Package outline DSN1006-2 (SOD993) PMEG4010ESB Product data sheet All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 9 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier 13. Soldering SOD993 1.2 0.65 0.3 0.7 0.6 0.5 (2x) (2x) (2x) 0.8 0.2 0.25 (2x) occupied area solder resist 0.35 (2x) solder lands solder paste 0.45 (2x) Dimensions in mm 15-02-20 15-03-05 sod993_fr Fig. 16. Reflow soldering footprint for DSN1006-2 (SOD993) 14. Mounting SOD993 is an ultra small Discretes Silicon No-leads (DSN) package allowing maximized utilization of the package area for active silicon. Due to the special product design, Nexperia investigated the board assembly process parameters. In order to have an optimum soldering quality, Nexperia advises following the assembly recommendations explained in AN11689. PMEG4010ESB Product data sheet All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 10 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier 15. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PMEG4010ESB v.3 20151127 Product data sheet - PMEG4010ESB v.2 Modifications: • PMEG4010ESB v.2 20150624 Product data sheet - PMEG4010ESB v.1 PMEG4010ESB v.1 20150512 Preliminary data sheet - - PMEG4010ESB Product data sheet Added section "Mounting" All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 11 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 16. Legal information 16.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PMEG4010ESB Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 12 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PMEG4010ESB Product data sheet All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 13 / 14 PMEG4010ESB Nexperia 40 V, 1 A low VF MEGA Schottky barrier rectifier 17. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................3 9 Thermal characteristics .........................................3 10 Characteristics ....................................................... 5 11 Test information ..................................................... 9 12 Package outline ..................................................... 9 13 Soldering .............................................................. 10 14 Mounting ...............................................................10 15 Revision history ................................................... 11 16 16.1 16.2 16.3 16.4 Legal information .................................................12 Data sheet status ............................................... 12 Definitions ...........................................................12 Disclaimers .........................................................12 Trademarks ........................................................ 13 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 November 2015 PMEG4010ESB Product data sheet All information provided in this document is subject to legal disclaimers. 27 November 2015 © Nexperia B.V. 2017. All rights reserved 14 / 14
PMEG4010ESBYL 价格&库存
很抱歉,暂时无法提供与“PMEG4010ESBYL”相匹配的价格&库存,您可以联系我们找货
PMEG4010ESBYL
  • 1+0.38610
  • 500+0.25740
  • 5000+0.22330
  • 10000+0.20350
库存:18669
