BAS101S,215
BAS101S,215
    NEXPERIA(安世)
    SOT-23
    开关二极管(小信号) 300V 3.00 x 1.40mm SMT SOT23 200mA
BAS101S,215 数据手册
BAS101; BAS101S High-voltage switching diodes Rev. 02 — 14 December 2009 Product data sheet 1. Product profile 1.1 General description High-voltage switching diodes, encapsulated in a SOT23 small Surface-Mounted Device (SMD) plastic package. Table 1. Product overview Type number Package Configuration Nexperia JEITA BAS101 SOT23 - single BAS101S SOT23 - dual series 1.2 Features „ High switching speed: trr ≤ 50 ns „ Low leakage current „ Repetitive peak reverse voltage: VRRM ≤ 300 V „ Low capacitance: Cd ≤ 2 pF „ Reverse voltage: VR ≤ 300 V „ Small SMD plastic package 1.3 Applications „ High-speed switching „ High-voltage switching „ Voltage clamping „ Reverse polarity protection 1.4 Quick reference data Table 2. Symbol Quick reference data Parameter Conditions Min Typ Max Unit - - 200 mA - - 150 nA - - 300 V - - 50 ns Per diode IF forward current IR reverse current VR reverse voltage trr reverse recovery time [1] VR = 250 V [1] When switched from IF = 30 mA to IR =30 mA; RL = 100 Ω; measured at IR = 3 mA. BAS101; BAS101S Nexperia High-voltage switching diodes 2. Pinning information Table 3. Pinning Pin Description Simplified outline Symbol BAS101 1 anode 2 not connected 3 cathode 3 3 1 1 2 006aaa764 2 BAS101S 1 anode (diode 1) 2 cathode (diode 2) 3 cathode (diode 1), anode (diode 2) 3 1 3 2 1 2 006aaa763 3. Ordering information Table 4. Ordering information Type number Package Name Description Version BAS101 - plastic surface-mounted package; 3 leads SOT23 BAS101S 4. Marking Table 5. Marking codes Marking code[1] Type number BAS101 *HQ BAS101S *HR [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China BAS101_BAS101S Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 2 of 11 BAS101; BAS101S Nexperia High-voltage switching diodes 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit - 300 V - 600 V - 300 V Per diode VRRM repetitive peak reverse voltage VR reverse voltage IF forward current series connection series connection - 600 V - 200 mA series connection - 100 mA - 1 A - 9 A IFRM repetitive peak forward current tp ≤ 1 ms; δ ≤ 0.25 IFSM non-repetitive peak forward current square wave; tp ≤ 1 μs [1] Ptot total power dissipation Tamb ≤ 25 °C [2] - 250 mW Tj junction temperature - 150 °C Tamb ambient temperature −65 +150 °C Tstg storage temperature −65 +150 °C Per device [1] Tj = 25 °C prior to surge [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. 6. Thermal characteristics Table 7. Symbol Thermal characteristics Parameter Conditions thermal resistance from junction to ambient in free air Min Typ Max Unit - - 500 K/W Per device Rth(j-a) [1] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. BAS101_BAS101S Product data sheet [1] © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 3 of 11 BAS101; BAS101S Nexperia High-voltage switching diodes 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit - - 1.1 V Per diode forward voltage IF = 100 mA IR reverse current VR = 250 V - - 150 nA VR =250 V; Tj = 150 °C - - 100 μA Cd diode capacitance trr reverse recovery time VR =0 V; f =1 MHz [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [2] When switched from IF = 30 mA to IR =30 mA; RL = 100 Ω; measured at IR = 3 mA. BAS101_BAS101S Product data sheet [1] VF [2] - - 2 pF - - 50 ns © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 4 of 11 BAS101; BAS101S Nexperia High-voltage switching diodes mhc618 500 IF (mA) mbg703 102 IFSM (A) 400 10 300 200 1 (1) (2) 100 (3) 10−1 0 0 0.5 1 VF (V) 1 1.5 10 102 103 104 tp (μs) (1) Tamb = 150 °C Based on square wave currents (2) Tamb = 75 °C Tj = 25 °C; prior to surge (3) Tamb = 25 °C Fig 1. Forward current as a function of forward voltage; typical values mhc619 102 IR (μA) Fig 2. Non-repetitive peak forward current as a function of pulse duration; maximum values mhc621 0.42 Cd (pF) 10 0.38 1 0.34 10−1 10−2 0 40 80 120 160 0.3 200 Tj (°C) 0 30 40 f = 1 MHz; Tamb = 25 °C Reverse current as a function of junction temperature; typical values Fig 4. Diode capacitance as a function of reverse voltage; typical values BAS101_BAS101S Product data sheet 20 VR (V) VR = 300 V Fig 3. 10 © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 5 of 11 BAS101; BAS101S Nexperia High-voltage switching diodes 8. Test information tr t D.U.T. RS = 50 Ω tp 10 % + IF IF SAMPLING OSCILLOSCOPE trr t Ri = 50 Ω V = VR + IF × RS VR (1) 90 % mga881 input signal output signal (1) IR = 3 mA Fig 5. Reverse recovery time test circuit and waveforms 9. Package outline 3.0 2.8 1.1 0.9 3 0.45 0.15 2.5 1.4 2.1 1.2 1 2 1.9 Dimensions in mm Fig 6. 0.48 0.38 0.15 0.09 04-11-04 Package outline SOT23 (TO-236AB) 10. Packing information Please refer to packing information on www.nexperia.com. BAS101_BAS101S Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 6 of 11 BAS101; BAS101S Nexperia High-voltage switching diodes 11. Soldering 2.90 2.50 solder lands solder resist 2 0.85 1 2.70 1.30 3.00 0.85 3 occupied area solder paste 0.60 (3x) 0.50 (3x) 0.60 (3x) 1.00 3.30 MSA439 Dimensions in mm Fig 7. Reflow soldering footprint SOT23 (TO-236AB) 3.40 1.20 (2x) solder lands solder resist occupied area 2 1 4.60 4.00 1.20 3 preferred transport direction during soldering 2.80 4.50 MSA427 Dimensions in mm Fig 8. Wave soldering footprint SOT23 (TO-236AB) BAS101_BAS101S Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 7 of 11 BAS101; BAS101S Nexperia High-voltage switching diodes 12. Mounting 43.4 0.6 0.7 40 0.6 0.7 0.5 Dimensions in mm 006aaa527 PCB thickness = 1.6 mm Fig 9. FR4 PCB, standard footprint SOT23 (TO-236AB) BAS101_BAS101S Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 8 of 11 BAS101; BAS101S Nexperia High-voltage switching diodes 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes BAS101_BAS101S_2 20091214 Product data sheet - BAS101_BAS101S_1 Modifications: BAS101_BAS101S_1 • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. • Table 3 “Pinning”: updated 20060908 Product data sheet - BAS101_BAS101S Product data sheet - © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 9 of 11 BAS101; BAS101S Nexperia High-voltage switching diodes 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Definition Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 14.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http:// www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BAS101_BAS101S Product data sheet © Nexperia B.V. 2009. All rights reserved. Rev. 02 — 14 December 2009 10 of 11 Nexperia BAS101; BAS101S High-voltage switching diodes 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 12 13 14 14.1 14.2 14.3 14.4 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 6 Packing information . . . . . . . . . . . . . . . . . . . . . 6 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Mounting. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 9 Legal information. . . . . . . . . . . . . . . . . . . . . . . 10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10 15 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Nexperia B.V. 2009. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 14 December 2009 Document identifier: BAS101_BAS101S
BAS101S,215
物料型号为BAS101和BAS101S,它们是Nexperia生产的高压开关二极管。
以下是对PDF文档中关键信息的中文分析:
器件简介: - BAS101和BAS101S是封装在SOT23小尺寸表面贴装塑料封装中的高压开关二极管。
- BAS101为单二极管配置,BAS101S为双二极管系列。
引脚分配: - BAS101的引脚:1为阳极,2为空,3为阴极。
- BAS101S的引脚:1为二极管1的阳极,2为二极管2的阴极,3为二极管1的阴极和二极管2的阳极。
参数特性: - 高开关速度:trr ≤ 50 ns - 低电容:Cd ≤ 2 pF - 低漏电流 - 反向电压:VR ≤ 300 V - 重复峰值反向电压:VRRM ≤ 300 V - 封装:小型SMD塑料封装
功能详解: - 高速开关 - 电压钳位 - 高压开关 - 反极性保护
应用信息: - 这些二极管适用于高速开关、电压钳位、高压开关和反极性保护等应用。
封装信息: - 封装类型:SOT23 - 标记代码:BAS101为"HQ",BAS101S为"HR",其中""代表产地信息。
订购信息: - BAS101:塑料表面贴装封装,3引脚 - BAS101S:同上
限制值: - 按照IEC 60134的绝对最大额定值系统规定,包括重复峰值反向电压、反向电压、正向电流等参数的限制值。
热特性: - 热阻从结到环境:Rth(-a) 在自由空气中为1至500 K/W。
特性: - 正向电压:VF 在IF =100mA时的典型值为1.1V - 反向电流:IR 在VR=250V时的典型值为150nA - 二极管电容:Cd 在VR=0V;f=1MHz时的典型值为2pF - 反向恢复时间:trr 的典型值为50ns
测试信息: - 包括反向恢复时间测试电路和波形图。
包装信息: - 请参考www.nexperia.com上的包装信息。
焊接信息: - 提供了回流焊接和波峰焊接的焊盘布局。
安装: - 提供了SOT23 (TO-236AB)在FR4 PCB上的标准焊盘布局。
修订历史: - 最近的修订日期为2009年12月14日,文档状态为产品数据表。
法律信息: - 包括数据表状态、定义、免责声明、销售条款、出口控制和商标信息。
请注意,文档中包含的重要通知已包含在“法律信息”部分。
BAS101S,215 价格&库存
很抱歉,暂时无法提供与“BAS101S,215”相匹配的价格&库存,您可以联系我们找货
BAS101S,215
  • 3000+0.943763000+0.12210
库存:3000
BAS101S,215
  • 5+1.40282
  • 50+1.10344
  • 150+0.97514
  • 500+0.81508
  • 3000+0.74380
  • 6000+0.70092
库存:157
BAS101S,215
  • 1+4.467801+0.57810
  • 10+3.0783010+0.39830
  • 100+1.97640100+0.25570
  • 500+1.41340500+0.18290
  • 1000+1.233701000+0.15970
  • 3000+0.947503000+0.12260
BAS101S,215
  • 3000+0.735703000+0.09519
  • 6000+0.664326000+0.08595
  • 9000+0.627919000+0.08124
  • 15000+0.5869615000+0.07594
  • 21000+0.5627121000+0.07281
  • 30000+0.5391430000+0.06976
BAS101S,215
  • 5+3.06117
  • 10+2.05265
  • 100+1.66110
  • 500+1.22210
  • 1000+1.06904
  • 5000+0.74038
