1PS88SB82,165
1PS88SB82,165
    NEXPERIA(安世)
    SOT363
    肖特基二极管 15V 2.20 x 1.35 SMT SOT363 30mA
1PS88SB82,165 数据手册
1PS66SB82; 1PS88SB82 15 V, 30 mA low Cd Schottky barrier diodes Rev. 04 — 13 January 2010 Product data sheet 1. Product profile 1.1 General description Epitaxial low capacitance Schottky barrier diodes encapsulated in very small SMD plastic packages. Table 1. Product overview Type number Package Configuration Nexperia JEITA 1PS66SB82 SOT666 - triple isolated diode 1PS88SB82 SOT363 SC-88 triple isolated diode 1.2 Features „ Low diode capacitance „ Low forward voltage „ Very small SMD plastic packages 1.3 Applications „ Digital applications: ‹ Ultra high-speed switching ‹ Clamping circuits „ RF applications: ‹ Diode ring mixer ‹ RF detector ‹ RF voltage doubler 1.4 Quick reference data Table 2. Quick reference data Symbol Parameter IF continuous forward current VR continuous reverse voltage Cd diode capacitance Conditions VR = 0 V; f = 1 MHz; see Figure 4 Min Typ Max Unit - - 30 mA - - 15 V - 1 - pF 1PS66SB82; 1PS88SB82 Nexperia 15 V, 30 mA low Cd Schottky barrier diodes 2. Pinning information Table 3. Pinning Pin Description 1 anode (diode 1) 2 anode (diode 2) 3 anode (diode 3) 4 cathode (diode 3) 5 cathode (diode 2) 6 cathode (diode 1) Simplified outline 6 1 5 Symbol 4 2 6 5 1 2 4 3 sym046 3 001aab555 3. Ordering information Table 4. Ordering information Type number Package Name Description Version 1PS66SB82 - plastic surface mounted package; 6 leads SOT666 1PS88SB82 SC-88 plastic surface mounted package; 6 leads SOT363 4. Marking Table 5. Marking codes Type number Marking code 1PS66SB82 N5 1PS88SB82 E1* [1] * = -: made in Hong Kong * = p: made in Hong Kong * = t: made in Malaysia * = W: made in China 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Max Unit VR continuous reverse voltage - 15 V IF continuous forward current - 30 mA Tj junction temperature - 125 °C Tamb ambient temperature −65 +125 °C Tstg storage temperature −65 +150 °C © 1PS66SB82_1PS88SB82_4 Product data sheet Min Rev. 04 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 2 of 10 1PS66SB82; 1PS88SB82 Nexperia 15 V, 30 mA low Cd Schottky barrier diodes 6. Thermal characteristics Table 7. Symbol Rth(j-a) Thermal characteristics Parameter Conditions thermal resistance from junction to ambient in free air Min Typ Max Unit [1] SOT666 [2][3] - - 700 K/W SOT363 [3][4] - - 416 K/W [1] For Schottky barrier diodes thermal run-away has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. Nomograms for determining the reverse power losses PR and IF(AV) rating will be available on request. [2] Refer to SOT666 standard mounting conditions. [3] Reflow soldering is the only recommended soldering method. [4] Refer to SOT363 (SC-88) standard mounting conditions. 7. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol VF Parameter Conditions forward voltage see Figure 1 Typ Max Unit IF = 1 mA - - 340 mV IF = 30 mA - - 700 mV IR reverse current VR = 1 V; see Figure 2 - - 0.2 μA rdif differential resistance IF = 5 mA; f = 1 kHz; see Figure 3 - 12 - Ω Cd diode capacitance VR = 0 V; f = 1 MHz; see Figure 4 - 1 - pF [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. © 1PS66SB82_1PS88SB82_4 Product data sheet Min [1] Rev. 04 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 3 of 10 1PS66SB82; 1PS88SB82 Nexperia 15 V, 30 mA low Cd Schottky barrier diodes mld549 103 mld550 103 IR (μA) IF (mA) 102 (1) (2) (3) (1) 102 10 (2) 1 10 (3) 10−1 (2) (1) 1 0 (3) 10−2 0.4 0.8 1.2 VF (V) 1.6 0 5 (1) Tamb = 125 °C (1) Tamb = 125 °C (2) Tamb = 85 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (3) Tamb = 25 °C Fig 1. Forward current as a function of forward voltage; typical values mgt838 103 r dif (Ω) Fig 2. 10 VR (V) 15 Reverse current as a function of reverse voltage; typical values mld551 1.2 Cd (pF) 1 102 0.8 0.6 10 0.4 1 10−1 1 10 IF (mA) 0 102 0 6 8 10 f = 1 MHz; Tamb = 25 °C Differential diode forward resistance as a function of forward current; typical values Fig 4. Diode capacitance as a function of reverse voltage; typical values © 1PS66SB82_1PS88SB82_4 Product data sheet 4 VR (V) f = 1 kHz; Tamb = 25 °C Fig 3. 2 Rev. 04 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 4 of 10 1PS66SB82; 1PS88SB82 Nexperia 15 V, 30 mA low Cd Schottky barrier diodes 8. Package outline Plastic surface-mounted package; 6 leads SOT666 D E A X Y S S HE 6 5 4 pin 1 index A 1 2 e1 c 3 bp w M A Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A bp c D E e e1 HE Lp w y mm 0.6 0.5 0.27 0.17 0.18 0.08 1.7 1.5 1.3 1.1 1.0 0.5 1.7 1.5 0.3 0.1 0.1 0.1 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SOT666 Fig 5. Package outline SOT666 © 1PS66SB82_1PS88SB82_4 Product data sheet Rev. 04 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 5 of 10 1PS66SB82; 1PS88SB82 Nexperia 15 V, 30 mA low Cd Schottky barrier diodes Plastic surface-mounted package; 6 leads SOT363 D E B y X A HE 6 5 v M A 4 Q pin 1 index A A1 1 2 e1 3 c bp Lp w M B e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max bp c D E e e1 HE Lp Q v w y mm 1.1 0.8 0.1 0.30 0.20 0.25 0.10 2.2 1.8 1.35 1.15 1.3 0.65 2.2 2.0 0.45 0.15 0.25 0.15 0.2 0.2 0.1 OUTLINE VERSION REFERENCES IEC JEDEC SOT363 Fig 6. JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-08 06-03-16 SC-88 Package outline SOT363 (SC-88) © 1PS66SB82_1PS88SB82_4 Product data sheet Rev. 04 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 6 of 10 1PS66SB82; 1PS88SB82 Nexperia 15 V, 30 mA low Cd Schottky barrier diodes 9. Packing information Table 9. Packing methods The -xxx numbers are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 3 000 4000 10 000 1PS66SB82 SOT666 4 mm pitch, 8 mm tape and reel - -115 - 1PS88SB82 SOT363 4 mm pitch, 8 mm tape and reel -115 - -135 [1] For further information and the availability of packing methods see Section 12. © 1PS66SB82_1PS88SB82_4 Product data sheet Rev. 04 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 7 of 10 1PS66SB82; 1PS88SB82 Nexperia 15 V, 30 mA low Cd Schottky barrier diodes 10. Revision history Table 10. Revision history Document ID Release date 1PS66SB82_1PS88SB82_4 20100113 Modifications: Data sheet status Change notice Supersedes Product data sheet - 1PS66SB82_1PS88SB82_3 • This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content. • • • Table 3 “Pinning”: updated Figure 5 “Package outline SOT666”: updated Figure 6 “Package outline SOT363 (SC-88)”: updated 1PS66SB82_1PS88SB82_3 20050124 Product data sheet - 1PS88SB82_2 1PS88SB82_2 20030411 Product specification - 1PS88SB82_1 1PS88SB82_1 20010216 Product specification - - © 1PS66SB82_1PS88SB82_4 Product data sheet Rev. 04 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 8 of 10 1PS66SB82; 1PS88SB82 Nexperia 15 V, 30 mA low Cd Schottky barrier diodes 11. Legal information 11.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 11.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 11.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 11.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 12. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © 1PS66SB82_1PS88SB82_4 Product data sheet Rev. 04 — 13 January 2010 Nexperia B.V. 2017. All rights reserved 9 of 10 Nexperia 1PS66SB82; 1PS88SB82 15 V, 30 mA low Cd Schottky barrier diodes 13. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 10 11 11.1 11.2 11.3 11.4 12 13 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Thermal characteristics . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 5 Packing information . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Contact information. . . . . . . . . . . . . . . . . . . . . . 9 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 13 January 2010
1PS88SB82,165 价格&库存
很抱歉,暂时无法提供与“1PS88SB82,165”相匹配的价格&库存,您可以联系我们找货
