BAV99QAZ
BAV99QAZ
    NEXPERIA(安世)
    SOT1215
    开关二极管(小信号) VR=90V SOT1215 IF=290mA IR=500nA
BAV99QAZ 数据手册
BAV99QA Dual series high-speed switching diodes 4 May 2016 Product data sheet 1. General description Dual series high-speed switching diodes, encapsulated in a leadless ultra small DFN1010D-3 (SOT1215) Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. 2. Features and benefits • • • • • • • • High switching speed: trr ≤ 4 ns Low leakage current Reverse voltage VR ≤ 90 V Low capacitance Cd ≤ 2 pF Ultra small SMD plastic package Low package height of 0.37 mm AEC-Q101 qualified Suitable for Automatic Optical Inspection (AOI) of solder joint 3. Applications • • • High-speed switching General-purpose switching Reverse poarity protection 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit IF forward current Tamb = 25 °C; single diode loaded - - 290 mA VR reverse voltage Tj = 25 °C - - 90 V IR reverse current VR = 80 V; Tj = 25 °C - - 0.5 µA trr reverse recovery time IF = 10 mA; IR = 10 mA; IR(meas) = 1 mA; RL = 100 Ω; Tamb = 25 °C - - 4 ns Per diode [1] [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. BAV99QA Nexperia Dual series high-speed switching diodes 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 A1 anode (diode 1) 2 K2 cathode (diode 2) 3 K1, A2 cathode (diode1) and anode (diode2) 4 K1, A2 cathode (diode1) and anode (diode2) Graphic symbol 1 A1 4 K1, A2 3 K2 2 aaa-022858 Transparent top view DFN1010D-3 (SOT1215) 6. Ordering information Table 3. Ordering information Type number Package BAV99QA Name Description Version DFN1010D-3 DFN1010D-3: plastic thermal enhanced ultra thin small outline package; no leads; 3 terminals; body 1.1 x 1.0 x 0.37 mm SOT1215 7. Marking Table 4. Marking codes Type number Marking code BAV99QA Z 100 MARKING CODE (EXAMPLE) READING DIRECTION YEAR DATE CODE PIN 1 INDICATION MARK VENDOR CODE READING EXAMPLE: MARK-FREE AREA A 110 aaa-020723 Fig. 1. DFN1010D-3 (SOT1215) binary marking code description BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 2 / 12 BAV99QA Nexperia Dual series high-speed switching diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VR reverse voltage Tj = 25 °C - 90 V IF forward current Tamb = 25 °C; single diode loaded [1] - 290 mA Tamb = 25 °C; double diode loaded [1] - 170 mA Per diode IFRM repetitive peak forward current tp ≤ 0.5 ms; δ ≤ 0.25 ; Tj = 25 °C - 700 mA IFSM non-repetitive peak forward current tp = 100 µs; Tj(init) = 25 °C; square wave - 4 A tp = 1 ms; Tj(init) = 25 °C; square wave - 1.5 A tp = 1 s; Tj(init) = 25 °C; square wave - 0.5 A [1] - 305 mW [2] - 470 mW Per device; one diode loaded Ptot total power dissipation Tamb ≤ 25 °C Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] [2] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm². aaa-022851 0.4 IF (A) (1) 0.3 0.2 (2) 0.1 0.0 0 25 50 75 100 125 150 175 Tamb (°C) (1) single diode loaded (2) double diode loaded Fig. 2. Forward current as a function of ambient temperature; derating curve BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 3 / 12 BAV99QA Nexperia Dual series high-speed switching diodes 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from junction to ambient thermal resistance from junction to solder point Rth(j-sp) [1] [2] [3] Conditions Min Typ Max Unit [1] - - 410 K/W [2] - - 265 K/W [3] - - 55 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm². Soldering point of cathode tab. aaa-021943 103 duty cycle = Zth(j-a) (K/W) 1 0.5 102 0.25 0.1 0.75 0.33 0.2 0.05 0.02 0.01 10 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-021944 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.5 0.33 0.25 0.2 0.1 10 0.05 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, mounting pad for cathode 1 cm² Fig. 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 4 / 12 BAV99QA Nexperia Dual series high-speed switching diodes 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit forward voltage IF = 1 mA; Tj = 25 °C - - 715 mV IF = 10 mA; Tj = 25 °C - - 855 mV IF = 50 mA; Tj = 25 °C - - 1 V IF = 150 mA; Tj = 25 °C - - 1.25 V VR = 25 V; Tj = 25 °C - - 30 nA VR = 80 V; Tj = 25 °C - - 0.5 µA VR = 25 V; Tj = 150 °C - - 30 µA VR = 80 V; Tj = 150 °C - - 150 µA Per diode VF IR reverse current Cd diode capacitance VR = 0 V; f = 1 MHz; Tamb = 25 °C - - 2 pF trr reverse recovery time IF = 10 mA; IR = 10 mA; IR(meas) = 1 mA; RL = 100 Ω; Tamb = 25 °C - - 4 ns VFR forward recovery voltage IF = 10 mA; tr = 20 ns; Tamb = 25 °C - - 1.75 V aaa-021945 1 IR (A) IF (A) 10-1 aaa-020907 10-3 10-4 (1) 10-5 10-6 (1) (2) 10-2 (2) (3) 10-7 (3) (4) 10-8 (4) 10-3 10-9 (5) 10-10 10-4 0.0 0.5 1.0 1.5 VF (V) 10-11 2.0 (1) Tj = 150 °C (2) Tj = 85 °C (3) Tj = 25 °C (4) Tj = −40 °C 0 20 40 60 80 VR (V) 100 (1) Tj = 150 °C (2) Tj = 125 °C (3) Tj = 85 °C (4) Tj = 25 °C (5) Tj = −40 °C Fig. 5. Forward current as a function of forward voltage; typical values Fig. 6. Reverse current as a function of reverse voltage; typical values BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 5 / 12 BAV99QA Nexperia Dual series high-speed switching diodes aaa-020908 2.0 aaa-020909 10 Cd (pF) IFSM (A) 1.5 1.0 1 0.5 0.0 0 5 10 15 20 VR (V) 10-1 10-1 25 f = 1MHz; Tamb = 25 °C Fig. 7. Diode capacitance as a function of reverse voltage; typical values BAV99QA Product data sheet 1 10 102 tp (ms) 103 Based on square wave currents. Tamb = 25 °C Fig. 8. Non-repetitive forward current as a function of pulse duration; maximum values All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 6 / 12 BAV99QA Nexperia Dual series high-speed switching diodes 11. Test information tr D.U.T. t 10 % IF RS = 50 Ω tp + IF SAMPLING OSCILLOSCOPE trr t Ri = 50 Ω V = VR + IF × RS mga881 (1) 90 % VR input signal output signal (1) IR = 1 mA Fig. 9. Reverse recovery time test circuit and waveforms I RS = 50 Ω 1 kΩ 450 Ω I V 90 % OSCILLOSCOPE D.U.T. VFR Ri = 50 Ω 10 % tr t tp input signal t output signal mga882 Fig. 10. Forward recovery voltage test circuit and waveforms Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 12. Package outline 0.87 0.95 0.75 1 0.95 1.05 0.22 0.30 2 0.16 0.24 0.1 3 0.04 max 0.34 0.40 Dimensions in mm 0.17 0.25 0.245 0.325 1.05 1.15 0.195 0.275 13-03-05 Fig. 11. Package outline DFN1010D-3 (SOT1215) BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 7 / 12 BAV99QA Nexperia Dual series high-speed switching diodes 13. Soldering Footprint information for reflow soldering of DFN1010D-3 package SOT1215 1.2 0.45 (2x) 0.3 1.1 0.35 (2x) 0.4 0.25 (2x) 0.75 0.3 0.5 1.5 1.4 0.4 0.5 0.4 0.3 0.5 1.3 0.4 0.3 0.4 0.5 1.3 solder land solder land plus solder paste occupied area solder resist Dimensions in mm Issue date 12-11-23 13-03-06 sot1215_fr Fig. 12. Reflow soldering footprint for DFN1010D-3 (SOT1215) BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 8 / 12 BAV99QA Nexperia Dual series high-speed switching diodes 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BAV99QA v.1 20160504 Product data sheet - - BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 9 / 12 BAV99QA Nexperia Dual series high-speed switching diodes Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 15. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. BAV99QA Product data sheet Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 10 / 12 BAV99QA Nexperia Dual series high-speed switching diodes Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 11 / 12 BAV99QA Nexperia Dual series high-speed switching diodes 16. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 5 11. Test information......................................................... 7 12. Package outline.......................................................... 7 13. Soldering..................................................................... 8 14. Revision history..........................................................9 15. Legal information..................................................... 10 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 04 May 2016 BAV99QA Product data sheet All information provided in this document is subject to legal disclaimers. 4 May 2016 © Nexperia B.V. 2017. All rights reserved 12 / 12
BAV99QAZ 价格&库存
很抱歉,暂时无法提供与“BAV99QAZ”相匹配的价格&库存,您可以联系我们找货
BAV99QAZ
  • 5000+0.409005000+0.05308
  • 15000+0.3471015000+0.04505
BAV99QAZ
