BAT54CV,115
BAT54CV,115
    NEXPERIA(安世)
    SOT666
    肖特基二极管 30V 1.70 x 1.30mm SMT SOT666 200mA
BAT54CV,115 数据手册
BAT54CV Two Schottky barrier double diodes Rev. 3 — 15 November 2010 Product data sheet 1. Product profile 1.1 General description Two planar Schottky barrier double diodes with common cathodes and an integrated guard ring for stress protection encapsulated in a SOT666 ultra small and flat lead Surface-Mounted Device (SMD) plastic package. 1.2 Features and benefits „ „ „ „ „ Low forward voltage Low capacitance AEC-Q101 qualified Ultra small and flat lead SMD plastic package Excellent coplanarity and improved thermal behavior 1.3 Applications „ „ „ „ Ultra high-speed switching Voltage clamping Line termination Reverse polarity protection 1.4 Quick reference data Table 1. Symbol Quick reference data Parameter Conditions Min Typ Max Unit Per diode IF forward current - - 200 mA VR reverse voltage - - 30 V VF forward voltage IF = 0.1 mA - - 240 mV IF = 1 mA - - 320 mV IF = 10 mA - - 400 mV IF = 30 mA - - 500 mV IF = 100 mA - - 800 mV [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. [1] BAT54CV Nexperia Two Schottky barrier double diodes 2. Pinning information Table 2. Pinning Pin Description Simplified outline 1 anode (diode 1) 2 anode (diode 2) 3 common cathode (diode 3, 4) 4 anode (diode 3) 5 anode (diode 4) 6 common cathode (diode 1, 2) 6 5 4 1 2 3 Graphic symbol 6 5 4 1 2 3 sym057 3. Ordering information Table 3. Ordering information Type number BAT54CV Package Name Description Version - plastic surface-mounted package; 6 leads SOT666 4. Marking Table 4. Marking codes Type number Marking code BAT54CV C5 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per diode BAT54CV Product data sheet VR reverse voltage - 30 V IF forward current - 200 mA IFRM repetitive peak forward current tp ≤ 10 ms; δ ≤ 0.5 - 0.85 A IFSM non-repetitive peak forward current square wave; tp = 8.3 ms - 2 A All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2010 [1] © Nexperia B.V. 2010. All rights reserved. 2 of 10 BAT54CV Nexperia Two Schottky barrier double diodes Table 5. Limiting values …continued In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit [3] - 350 mW [4] - 420 mW Per device, one diode loaded total power dissipation Ptot [2] Tamb ≤ 25 °C Tj junction temperature - 125 °C Tamb ambient temperature −65 +125 °C Tstg storage temperature −65 +150 °C [1] Tj = 25 °C prior to surge. [2] Reflow soldering is the only recommended soldering method. [3] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and standard footprint. [4] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. 6. Thermal characteristics Table 6. Symbol Thermal characteristics Parameter Conditions Min Typ Max Unit [3] - - 360 K/W [4] - - 300 K/W [5] - - 175 K/W Per device, one diode loaded Rth(j-a) Rth(j-sp) BAT54CV Product data sheet thermal resistance from in free air junction to ambient thermal resistance from junction to solder point [1][2] [1] For Schottky barrier diodes thermal runaway has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. [2] Reflow soldering is the only recommended soldering method. [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. [4] Device mounted on an FR4 PCB, single-sided copper, tin-plated, mounting pad for cathode 1 cm2. [5] Soldering point of cathode tab. All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2010 © Nexperia B.V. 2010. All rights reserved. 3 of 10 BAT54CV Nexperia Two Schottky barrier double diodes 7. Characteristics Table 7. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit IF = 0.1 mA - - 240 mV IF = 1 mA - - 320 mV IF = 10 mA - - 400 mV Per diode VF [1] forward voltage IF = 30 mA - - 500 mV IF = 100 mA - - 800 mV IR reverse current VR = 25 V - - 2 μA Cd diode capacitance VR =1 V; f =1 MHz - - 10 pF [1] Pulse test: tp ≤ 300 μs; δ ≤ 0.02. msa892 103 IF (mA) msa893 103 IR (μA) (1) (2) (3) 102 (1) 102 (2) 10 10 1 10−1 (1) (2) (3) 0 1 0.4 0.8 VF (V) 1.2 (3) 10−1 0 (1) Tamb = 125 °C (1) Tamb = 125 °C (2) Tamb = 85 °C (2) Tamb = 85 °C (3) Tamb = 25 °C (3) Tamb = 25 °C Fig 1. Forward current as a function of forward voltage; typical values BAT54CV Product data sheet Fig 2. 10 20 VR (V) 30 Reverse current as a function of reverse voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2010 © Nexperia B.V. 2010. All rights reserved. 4 of 10 BAT54CV Nexperia Two Schottky barrier double diodes msa891 15 Cd (pF) 10 5 0 0 10 20 30 VR (V) Tamb = 25 °C; f = 1 MHz Fig 3. Diode capacitance as a function of reverse voltage; typical values 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. 9. Package outline 1.7 1.5 6 0.6 0.5 5 4 0.3 0.1 1.7 1.5 1.3 1.1 pin 1 index 1 2 3 0.27 0.17 0.5 0.18 0.08 1 Dimensions in mm Fig 4. BAT54CV Product data sheet 04-11-08 Package outline BAT54CV (SOT666) All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2010 © Nexperia B.V. 2010. All rights reserved. 5 of 10 BAT54CV Nexperia Two Schottky barrier double diodes 10. Packing information Please refer to packing information on www.nexperia.com. 11. Soldering 2.75 2.45 2.1 1.6 solder lands 0.4 (6×) 0.25 (2×) 0.538 2 1.7 1.075 0.3 (2×) 0.55 (2×) placement area solder paste occupied area 0.325 0.375 (4×) (4×) Dimensions in mm 1.7 0.45 (4×) 0.6 (2×) 0.5 (4×) 0.65 (2×) sot666_fr Reflow soldering is the only recommended soldering method. Fig 5. BAT54CV Product data sheet Reflow soldering footprint BAT54CV (SOT666) All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2010 © Nexperia B.V. 2010. All rights reserved. 6 of 10 BAT54CV Nexperia Two Schottky barrier double diodes 12. Revision history Table 9. Revision history Document ID Release date Data sheet status Change notice Supersedes BAT54CV v.3 20101115 Product data sheet - BAT54CV_2 Modifications: • • • • • • • • Section 1.2 “Features and benefits”: amended. Table 1 “Quick reference data”: updated. Table 5 “Limiting values”: Ptot amended. Table 6 “Thermal characteristics”: Rth(j-a) amended, Rth(j-sp) added. Figure 4: superseded by minimized outline drawing. Section 8 “Test information”: added. Section 11 “Soldering”: added. Section 13 “Legal information”: updated. BAT54CV_2 20100115 Objective data sheet - BAT54CV_1 BAT54CV_1 20040922 Objective data sheet - - BAT54CV Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2010 © Nexperia B.V. 2010. All rights reserved. 7 of 10 BAT54CV Nexperia Two Schottky barrier double diodes 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or BAT54CV Product data sheet malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2010 © Nexperia B.V. 2010. All rights reserved. 8 of 10 BAT54CV Nexperia Two Schottky barrier double diodes Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. BAT54CV Product data sheet 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 15 November 2010 © Nexperia B.V. 2010. All rights reserved. 9 of 10 BAT54CV Nexperia Two Schottky barrier double diodes 14. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . General description . . . . . . . . . . . . . . . . . . . . . Features and benefits . . . . . . . . . . . . . . . . . . . . Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . Quick reference data . . . . . . . . . . . . . . . . . . . . Pinning information . . . . . . . . . . . . . . . . . . . . . . Ordering information . . . . . . . . . . . . . . . . . . . . . Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . Thermal characteristics . . . . . . . . . . . . . . . . . . Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . Test information . . . . . . . . . . . . . . . . . . . . . . . . . Quality information . . . . . . . . . . . . . . . . . . . . . . Package outline . . . . . . . . . . . . . . . . . . . . . . . . . Packing information . . . . . . . . . . . . . . . . . . . . . Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Revision history . . . . . . . . . . . . . . . . . . . . . . . . . Legal information. . . . . . . . . . . . . . . . . . . . . . . . Data sheet status . . . . . . . . . . . . . . . . . . . . . . . Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 1 1 1 1 2 2 2 2 3 4 5 5 5 6 6 7 8 8 8 8 9 14 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section ‘Legal information’. © Nexperia B.V. 2010. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 November 2010 Document identifier: BAT54CV
BAT54CV,115 价格&库存
很抱歉,暂时无法提供与“BAT54CV,115”相匹配的价格&库存,您可以联系我们找货
