ES1JFL
ES1JFL
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMF(SOD-123FL)
    整流二极管 600V 1A VF=1.7V@1A SOD-123FL
ES1JFL 数据手册
ES1DFL – ES1JFL Taiwan Semiconductor 1A, 200V - 600V Super Fast Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low profile package Low power loss, high efficiency Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 200 - 600 V IFSM 30 A TJ MAX 150 °C APPLICATIONS Package SOD-123FL Configuration Single die ● DC to DC converter ● Switching mode converters and inverters ● Freewheeling application MECHANICAL DATA ● ● ● ● ● ● Case: SOD-123FL Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1A whisker test Polarity: Indicated by cathode band Weight: 0.016g (approximately) SOD-123FL ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device ES1DFL ES1GFL ES1JFL EDF EGF EJF UNIT Repetitive peak reverse voltage VRRM 200 400 600 V Reverse voltage, total rms value VR(RMS) 140 280 420 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 1 A IFSM 30 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: D2103 ES1DFL – ES1JFL Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 35 °C/W Junction-to-ambient thermal resistance RӨJA 85 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP MAX UNIT - 1.0 V - 1.3 V - 1.7 V - 5 µA - 100 µA trr - 35 ns CJ 8 - pF ES1DFL Forward voltage (1) ES1GFL IF = 1A, TJ = 25°C VF ES1JFL Reverse current @ rated VR (2) Reverse recovery time Junction capacitance Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms TJ = 25°C IR TJ = 125°C IF = 0.5A , IR = 1.0A Irr = 0.25A 1MHz, VR = 4.0V ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING ES1xFL SOD-123FL 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 200V(ES1DFL) to 600V(ES1JFL) 2 Version: D2103 ES1DFL – ES1JFL Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 16 14 CAPACITANCE (pF) 1 12 10 8 6 4 2 f=1.0MHz Vsig=50mVp-p 0 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=125°C 1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C 1 0.1 TJ=25°C 0.01 0.1 0.001 0.8 1.0 1.2 1.4 0.3 0.4 0.5 0.6 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Pulse width 300μs 1% duty cycle Pulse width 1.6 0.7 1.8 0.8 2.0 0.9 2.2 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 40 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (μA) Fig.4 Typical Forward Characteristics 100 0.1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 2 8.3ms single half sine wave 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: D2103 1.2 ES1DFL – ES1JFL Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.6 Reverse Recovery Time Characteristic and Test Circuit Diagram 4 Version: D2103 ES1DFL – ES1JFL Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-123FL SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code YW = Date Code F = Factory Code Version: D2103 ES1DFL – ES1JFL Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: D2103
ES1JFL 价格&库存
很抱歉,暂时无法提供与“ES1JFL”相匹配的价格&库存,您可以联系我们找货
ES1JFL
    ES1JFL
      库存:410000
      ES1JFL
        ES1JFL
          • 1+0.237201+0.03060
          库存:7173
          ES1JFL
          • 10000+0.4269010000+0.05504
          • 20000+0.3878920000+0.05001
          • 30000+0.3680030000+0.04745
          • 50000+0.3456550000+0.04456
          • 70000+0.3324070000+0.04286
          • 100000+0.31953100000+0.04120
          库存:9745
          ES1JFL
          • 1+2.470401+0.31849
          • 10+1.5237710+0.19645
          • 100+0.95111100+0.12262
          • 500+0.69868500+0.09008
          • 1000+0.617051000+0.07955
          • 2000+0.548062000+0.07066
          • 5000+0.473255000+0.06101
          库存:9745
