Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
DISCRETE SEMICONDUCTORS
DATA SHEET
PDZ-B series
Voltage regulator diodes
Product data sheet
Supersedes data of 2002 Feb 18
2004 Mar 22
NXP Semiconductors
Product data sheet
PDZ-B series
FEATURES
PINNING
• Total power dissipation: max. 400 mW
PIN
• Small plastic package suitable for surface mounted
design
1
2
• Wide variety of voltage ranges: nominal 2.4 to 36 V
(E24 range)
• Tolerance approximately ±2%.
handbook, halfpage
• General voltage regulation.
cathode
anode
1
APPLICATIONS
DESCRIPTION
2
Top view
MAM387
The marking bar indicates the cathode.
DESCRIPTION
Fig.1
Low-power general purpose voltage regulator diodes in a
small plastic SMD SOD323 (SC-76) package.
Simplified outline (SOD323; SC-76) and
symbol.
MARKING
TYPE
NUMBER
MARKING
CODE
TYPE
NUMBER
MARKING
CODE
TYPE
NUMBER
MARKING
CODE
TYPE
NUMBER
MARKING
CODE
PDZ2.4B
Z0
PDZ5.1B
Z8
PDZ11B
ZG
PDZ24B
ZQ
PDZ2.7B
Z1
PDZ5.6B
Z9
PDZ12B
ZH
PDZ27B
ZR
PDZ3.0B
Z2
PDZ6.2B
ZA
PDZ13B
ZJ
PDZ30B
ZS
PDZ3.3B
Z3
PDZ6.8B
ZB
PDZ15B
ZK
PDZ33B
ZT
PDZ3.6B
Z4
PDZ7.5B
ZC
PDZ16B
ZL
PDZ36B
ZU
PDZ3.9B
Z5
PDZ8.2B
ZD
PDZ18B
ZM
PDZ4.3B
Z6
PDZ9.1B
ZE
PDZ20B
ZN
PDZ4.7B
Z7
PDZ10B
ZF
PDZ22B
ZP
ORDERING INFORMATION
TYPE
NUMBER
PDZ2.4B to
PDZ36B
2004 Mar 22
PACKAGE
NAME
DESCRIPTION
plastic surface mounted package; 2 leads
2
VERSION
SOD323
NXP Semiconductors
Product data sheet
PDZ-B series
LIMITING VALUES
In accordance with the Absolute Maximum Rating System (IEC 60134).
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
IF
continuous forward current
IZSM
non-repetitive peak reverse current
tp = 100 μs; square wave;
Tamb = 25 °C prior to surge
Ptot
total power dissipation
Tamb = 25 °C; note 1;
see Fig.2
Tstg
Tj
UNIT
200
mA
see Table 2
400
mW
storage temperature
−65
+150
°C
junction temperature
150
°C
Note
1. Device mounted on a printed-circuit board measuring 11 × 25 × 1.6 mm.
THERMAL CHARACTERISTICS
SYMBOL
PARAMETER
CONDITIONS
Rth(j-s)
thermal resistance from junction to soldering point
Rth(j-a)
thermal resistance from junction to ambient
note 1
Note
2004 Mar 22
3
VALUE
UNIT
130
K/W
340
K/W
NXP Semiconductors
Product data sheet
PDZ-B series
CHARACTERISTICS
Table 1 Total series
Tj = 25 °C unless otherwise specified.
SYMBOL
PARAMETER
VF
forward voltage
IR
reverse current
PDZ2.4B
PDZ2.7B
PDZ3.0B
PDZ3.3B
PDZ3.6B
PDZ3.9B
PDZ4.3B
PDZ4.7B
PDZ5.1B
PDZ5.6B
PDZ6.2B
PDZ6.8B
PDZ7.5B
PDZ8.2B
PDZ9.1B
PDZ10B
PDZ11B
PDZ12B
PDZ13B
PDZ15B
PDZ16B
PDZ18B
PDZ20B
PDZ22B
PDZ24B
PDZ27B
PDZ30B
PDZ33B
PDZ36B
2004 Mar 22
CONDITIONS
4
MAX.
UNIT
IF = 10 mA; see Fig.3
IF = 100 mA; see Fig.3
0.9
1.1
V
V
VR = 1 V
VR = 1 V
VR = 1 V
VR = 1 V
VR = 1 V
VR = 1 V
VR = 1 V
VR = 1 V
VR = 1.5 V
VR = 2.5 V
VR = 3 V
VR = 3.5 V
VR = 4 V
VR = 5 V
VR = 6 V
VR = 7 V
VR = 8 V
VR = 9 V
VR = 10 V
VR = 11 V
VR = 12 V
VR = 13 V
VR = 15 V
VR = 17 V
VR = 19 V
VR = 21 V
VR = 23 V
VR = 25 V
VR = 27 V
50
5
5
3
3
2
2
1
500
500
500
500
500
100
100
100
100
50
50
50
50
50
50
50
50
50
50
μA
μA
μA
μA
μA
μA
μA
μA
μA
μA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
nA
5
TEMP. COEFF.
SZ (mV/K)
at IZ = 5 mA
(see Figs 4 and 5)
DIODE CAP.
Cd (pF) at
f = 1 MHz;
VR = 0
NON-REPETITIVE PEAK
REVERSE CURRENT
IZSM (A) at tp = 100 μs;
Tamb = 25 °C
MAX.
MAX.
at IZ
(mA)
MAX.
at IZ
(mA)
TYP.
MAX.
MAX.
2.43
2.69
2.85
3.32
3.60
3.89
4.17
4.55
4.96
5.48
6.06
6.65
7.28
8.02
8.85
9.77
10.78
11.74
12.91
14.34
15.85
17.56
19.52
21.54
23.72
26.19
29.19
32.15
35.07
2.63
2.91
3.07
3.53
3.85
4.16
4.48
4.75
5.20
5.73
6.33
6.93
7.60
8.36
9.23
10.21
11.22
12.24
13.49
14.98
16.51
18.35
20.39
22.47
24.78
27.53
30.69
33.79
36.87
1 000
1 000
1 000
1 000
500
500
600
600
250
100
80
60
60
60
60
60
60
80
80
80
80
80
100
100
120
150
200
250
300
0.5
0.5
0.5
0.5
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
100
100
95
95
90
90
90
90
60
50
50
40
10
10
10
10
10
10
10
15
30
40
40
40
60
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
−1.6
−2.0
−2.1
−2.4
−2.4
−2.5
−2.5
−1.4
0.3
1.9
2.7
3.4
4.0
4.6
5.5
6.4
7.4
8.4
9.4
11.4
12.4
14.4
16.4
18.4
20.4
23.4
26.6
29.7
33.0
450
440
425
410
390
370
350
325
300
275
250
215
170
150
120
110
108
105
103
99
97
93
88
84
80
73
66
60
59
8.0
8.0
8.0
8.0
8.0
8.0
8.0
8.0
5.5
5.5
5.5
5.5
3.5
3.5
3.5
3.5
3.0
3.0
2.5
2.0
1.5
1.5
1.5
1.3
1.3
1.0
1.0
0.9
0.8
Product data sheet
MIN.
PDZ-B series
PDZ2.4B
PDZ2.7B
PDZ3.0B
PDZ3.3B
PDZ3.6B
PDZ3.9B
PDZ4.3B
PDZ4.7B
PDZ5.1B
PDZ5.6B
PDZ6.2B
PDZ6.8B
PDZ7.5B
PDZ8.2B
PDZ9.1B
PDZ10B
PDZ11B
PDZ12B
PDZ13B
PDZ15B
PDZ16B
PDZ18B
PDZ20B
PDZ22B
PDZ24B
PDZ27B
PDZ30B
PDZ33B
PDZ36B
DIFFERENTIAL RESISTANCE
rdif (Ω)
NXP Semiconductors
TYPE
NUMBER
WORKING VOLTAGE
VZ (V)
at IZ = 5 mA
2004 Mar 22
Table 2 Per type
NXP Semiconductors
Product data sheet
PDZ-B series
GRAPHICAL DATA
MBK245
500
MBG781
300
handbook, halfpage
handbook, halfpage
Ptot
(mW)
IF
(mA)
400
200
300
200
100
100
100
150
200
Tamb (°C)
0.8
1
VF (V)
Tj = 25 °C.
Fig.3
Forward current as a function of forward
voltage; typical values.
Fig.2 Power derating curve.
MGL273
MGL274
handbook, halfpage
handbook, halfpage
12
SZ
(mV/K)
SZ
(mV/K)
4.3
11
10
−1
9.1
5
3.9
8.2
7.5
6.8
3.6
−2
6.2
5.6
5.1
4.7
3.0
2.4
2.7
−3
IZ (mA)
−5
60
PDZ2.4B to PDZ4.3B.
Tj = 25 °C to 150 °C.
PDZ4.7B to PDZ12B.
Fig.4
Fig.5
Temperature coefficient as a function of
working current; typical values.
2004 Mar 22
6
8
12
16
IZ (mA)
NXP Semiconductors
Product data sheet
PDZ-B series
PACKAGE OUTLINE
Plastic surface-mounted package; 2 leads
SOD323
A
D
E
X
v
HD
M
A
Q
1
2
bp
A
A1
(1)
c
Lp
detail X
2 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
max
bp
c
D
E
HD
Lp
Q
v
mm
1.1
0.8
0.05
0.40
0.25
0.25
0.10
1.8
1.6
1.35
1.15
2.7
2.3
0.45
0.15
0.25
0.15
0.2
Note
1. The marking bar indicates the cathode
OUTLINE
VERSION
SOD323
2004 Mar 22
REFERENCES
IEC
JEDEC
JEITA
SC-76
7
EUROPEAN
PROJECTION
ISSUE DATE
03-12-17
06-03-16
NXP Semiconductors
Product data sheet
PDZ-B series
DATA SHEET STATUS
DOCUMENT
STATUS(1)
PRODUCT
STATUS(2)
DEFINITION
Objective data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary data sheet
Qualification
This document contains data from the preliminary specification.
Product data sheet
Production
This document contains the product specification.
Notes
1. Please consult the most recently issued document before initiating or completing a design.
2. The product status of device(s) described in this document may have changed since this document was published
and may differ in case of multiple devices. The latest product status information is available on the Internet at
URL http://www.nxp.com.
DISCLAIMERS
above those given in the Characteristics sections of this
document is not implied. Exposure to limiting values for
extended periods may affect device reliability.
General ⎯ Information in this document is believed to be
accurate and reliable. However, NXP Semiconductors
does not give any representations or warranties,
expressed or implied, as to the accuracy or completeness
of such information and shall have no liability for the
consequences of use of such information.
Terms and conditions of sale ⎯ NXP Semiconductors
products are sold subject to the general terms and
conditions of commercial sale, as published at
http://www.nxp.com/profile/terms, including those
pertaining to warranty, intellectual property rights
infringement and limitation of liability, unless explicitly
otherwise agreed to in writing by NXP Semiconductors. In
case of any inconsistency or conflict between information
in this document and such terms and conditions, the latter
will prevail.
Right to make changes ⎯ NXP Semiconductors
reserves the right to make changes to information
published in this document, including without limitation
specifications and product descriptions, at any time and
without notice. This document supersedes and replaces all
information supplied prior to the publication hereof.
No offer to sell or license ⎯ Nothing in this document
may be interpreted or construed as an offer to sell products
that is open for acceptance or the grant, conveyance or
implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Suitability for use ⎯ NXP Semiconductors products are
not designed, authorized or warranted to be suitable for
use in medical, military, aircraft, space or life support
equipment, nor in applications where failure or malfunction
of an NXP Semiconductors product can reasonably be
expected to result in personal injury, death or severe
property or environmental damage. NXP Semiconductors
accepts no liability for inclusion and/or use of NXP
Semiconductors products in such equipment or
applications and therefore such inclusion and/or use is at
the customer’s own risk.
Export control ⎯ This document as well as the item(s)
described herein may be subject to export control
regulations. Export might require a prior authorization from
national authorities.
Quick reference data ⎯ The Quick reference data is an
extract of the product data given in the Limiting values and
Characteristics sections of this document, and as such is
not complete, exhaustive or legally binding.
Applications ⎯ Applications that are described herein for
any of these products are for illustrative purposes only.
NXP Semiconductors makes no representation or
warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values ⎯ Stress above one or more limiting
values (as defined in the Absolute Maximum Ratings
System of IEC 60134) may cause permanent damage to
the device. Limiting values are stress ratings only and
operation of the device at these or any other conditions
2004 Mar 22
8
NXP Semiconductors
Customer notification
This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal
definitions and disclaimers. No changes were made to the technical content, except for package outline
drawings which were updated to the latest version.
Contact information
For additional information please visit: http://www.nxp.com
For sales offices addresses send e-mail to: salesaddresses@nxp.com
© NXP B.V. 2009
All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner.
The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed
without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license
under patent- or other industrial or intellectual property rights.
Printed in The Netherlands
R76/05/pp9
Date of release: 2004 Mar 22
Document order number: 9397 750 12615
很抱歉,暂时无法提供与“PDZ5.6B,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.12400
- 100+2.59600
- 750+2.40900
- 1500+2.29900
- 3000+2.20000
- 国内价格
- 1+3.79750
- 30+3.67500
- 100+3.43000
- 500+3.18500
- 1000+3.06250
- 2000+2.94000
- 国内价格 香港价格
- 3000+0.290003000+0.03752
- 6000+0.257816000+0.03336
- 9000+0.241399000+0.03123
- 15000+0.2228915000+0.02884
- 21000+0.2119421000+0.02742
- 30000+0.2012730000+0.02604
