PLVA656A,215
PLVA656A,215
    NEXPERIA(安世)
    SOT-23
    齐纳/稳压二极管 5.6V 250mW SMT SOT23 250mA
PLVA656A,215 数据手册
Important notice Dear Customer, On 7 February 2017 the former NXP Standard Product business became a new company with the tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS semiconductors with its focus on the automotive, industrial, computing, consumer and wearable application markets In data sheets and application notes which still contain NXP or Philips Semiconductors references, use the references to Nexperia, as shown below. Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/, use http://www.nexperia.com Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use salesaddresses@nexperia.com (email) Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on the version, as shown below: - © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights reserved Should be replaced with: - © Nexperia B.V. (year). All rights reserved. If you have any questions related to the data sheet, please contact our nearest sales office via e-mail or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and understanding, Kind regards, Team Nexperia DISCRETE SEMICONDUCTORS DATA SHEET dbook, halfpage M3D088 PLVA6xxA series Low-voltage avalanche regulator diodes Product data sheet Supersedes data of 1999 May 25 2004 Jan 14 NXP Semiconductors Product data sheet Low-voltage avalanche regulator diodes FEATURES PLVA6xxA series PINNING • Very low dynamic impedance at low currents: approximately 1⁄20 of conventional series PIN • Hard breakdown knee • Low noise: approximately 1⁄10 of conventional series • Total power dissipation: max. 250 mW DESCRIPTION 1 anode 2 not connected 3 cathode • Small tolerances of VZ • Working voltage range: nominal 5.00 to 6.80 V • Non-repetitive peak reverse power dissipation: maximal 30 W. handbook, halfpage 2 1 APPLICATIONS 2 n.c. • Low current, low power, low noise applications • CMOS RAM back-up circuits 1 3 • Voltage stabilizers 3 • Voltage limiters Top view MAM243 • Smoke detector relays. DESCRIPTION Fig.1 Simplified outline (SOT23) and symbol. High performance voltage regulator diodes in small SOT23 plastic SMD packages. The series consists of PLVA650A to PLVA668A. MARKING TYPE NUMBER MARKING CODE(1) PLVA650A *9A PLVA653A *9B PLVA656A *9C PLVA659A *9D PLVA662A *9E PLVA665A *9F PLVA668A *9G Note 1. * = p: Made in Hong Kong. * = t: Made in Malaysia. * = W: Made in China. 2004 Jan 14 2 NXP Semiconductors Product data sheet Low-voltage avalanche regulator diodes PLVA6xxA series ORDERING INFORMATION TYPE NUMBER PLVA6xxA PACKAGE NAME DESCRIPTION − VERSION plastic surface mounted package; 3 leads SOT23 LIMITING VALUES In accordance with the Absolute Maximum Rating System (IEC 60134). SYMBOL PARAMETER CONDITIONS MIN. 250 mA − 250 mA continuous forward current IZRM repetitive peak working current PZSM non-repetitive peak reverse power dissipation tp = 100 μs; Tj = 150 °C − Ptot total power dissipation Tstg Tj 30 W − 250 mW storage temperature −65 +150 °C junction temperature − 150 °C Tamb = 25 °C; note 1 Note 1. Device mounted on an FR4 printed circuit-board. 2004 Jan 14 UNIT − IF tp = 100 μs; δ = 10% MAX. 3 NXP Semiconductors Product data sheet Low-voltage avalanche regulator diodes PLVA6xxA series ELECTRICAL CHARACTERISTICS Tj = 25 °C; unless otherwise specified. SYMBOL PARAMETER CONDITIONS V PLVA650A 4.80 5.00 5.20 V PLVA653A 5.10 5.30 5.50 V PLVA656A 5.40 5.60 5.80 V PLVA659A 5.70 5.90 6.10 V PLVA662A 6.00 6.20 6.40 V PLVA665A 6.30 6.50 6.70 V PLVA668A 6.60 6.80 7.00 V PLVA650A − 4.30 − V PLVA653A − 5.20 − V PLVA656A − 5.51 − V PLVA659A − 5.85 − V PLVA662A − 6.19 − V PLVA665A − 6.49 − V − 6.80 − V − − 700 Ω PLVA653A − − 250 Ω PLVA656A to PLVA668A − − 100 Ω PLVA650A − 0.20 − mV/K PLVA653A − 1.60 − mV/K PLVA656A − 1.90 − mV/K PLVA659A − 2.40 − mV/K PLVA662A − 2.65 − mV/K PLVA665A − 2.90 − mV/K PLVA668A − 3.40 − mV/K PLVA650A − − 20 000 nA PLVA653A − − 5 000 nA PLVA656A − − 1 000 nA PLVA659A − − 500 nA PLVA662A − − 100 nA PLVA665A − − 50 nA PLVA668A − − 10 nA IZ = 250 μA working voltage IZ = 10 μA PLVA668A dynamic resistance PLVA650A IR 2004 Jan 14 UNIT 0.9 IF = 10 mA working voltage SZ MAX. − forward voltage VZ RZ TYP. − VF VZ MIN. temperature coefficient reverse current 1 kHz superimposed; IZAC is 10% of IZDC; IZ = 250 μA IZ = 250 μA VR = 80% VZ nominal 4 NXP Semiconductors Product data sheet Low-voltage avalanche regulator diodes SYMBOL IR IR ΔVZ Vn PARAMETER reverse current PLVA6xxA series CONDITIONS MIN. TYP. MAX. UNIT VR = 50% VZ nominal PLVA650A − 34 − nA PLVA653A − 22 − nA PLVA656A − 1.1 − nA PLVA659A − 0.9 − nA PLVA662A − 0.9 − nA PLVA665A − 0.9 − nA PLVA668A − 0.8 − nA PLVA650A − 21 − μA PLVA653A − 3.5 − μA PLVA656A − 1.3 − μA PLVA659A − 1.0 − μA PLVA662A − 0.05 − μA PLVA665A − 0.04 − μA PLVA668A − 0.006 − μA reverse current VR = 90% VZ nominal line regulation PLVA659A to PLVA668A ILO = 10 μA; IHI = 1 mA − − 0.1 V PLVA656A ILO = 50 μA; IHI = 1 mA − − 0.1 V PLVA650A ILO = 100 μA; IHI = 1 mA − − 0.4 V PLVA653A ILO = 100 μA; IHI = 1 mA − − 0.2 V f = 1 kHz; B = 1 kHz; IZ = 250 μA − − 1.0 μV -----------Hz noise voltage density THERMAL CHARACTERISTICS SYMBOL PARAMETER Rth(j-tp) thermal resistance from junction to tie-point Rth(j-a) thermal resistance from junction to ambient CONDITIONS note 1 Note 1. Device mounted on an FR4 printed circuit-board. 2004 Jan 14 5 VALUE UNIT 330 K/W 500 K/W NXP Semiconductors Product data sheet Low-voltage avalanche regulator diodes PLVA6xxA series PACKAGE OUTLINE Plastic surface-mounted package; 3 leads SOT23 D E B A X HE v M A 3 Q A A1 1 2 e1 bp c w M B Lp e detail X 0 1 2 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 max. bp c D E e e1 HE Lp Q v w mm 1.1 0.9 0.1 0.48 0.38 0.15 0.09 3.0 2.8 1.4 1.2 1.9 0.95 2.5 2.1 0.45 0.15 0.55 0.45 0.2 0.1 OUTLINE VERSION SOT23 2004 Jan 14 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 04-11-04 06-03-16 TO-236AB 6 NXP Semiconductors Product data sheet Low-voltage avalanche regulator diodes PLVA6xxA series DATA SHEET STATUS DOCUMENT STATUS(1) PRODUCT STATUS(2) DEFINITION Objective data sheet Development This document contains data from the objective specification for product development. Preliminary data sheet Qualification This document contains data from the preliminary specification. Product data sheet Production This document contains the product specification. Notes 1. Please consult the most recently issued document before initiating or completing a design. 2. The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nxp.com. above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. DISCLAIMERS General ⎯ Information in this document is believed to be accurate and reliable. However, NXP Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Terms and conditions of sale ⎯ NXP Semiconductors products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nxp.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by NXP Semiconductors. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. Right to make changes ⎯ NXP Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license ⎯ Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use ⎯ NXP Semiconductors products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an NXP Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. NXP Semiconductors accepts no liability for inclusion and/or use of NXP Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Export control ⎯ This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Quick reference data ⎯ The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications ⎯ Applications that are described herein for any of these products are for illustrative purposes only. NXP Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values ⎯ Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions 2004 Jan 14 7 NXP Semiconductors Customer notification This data sheet was changed to reflect the new company name NXP Semiconductors, including new legal definitions and disclaimers. No changes were made to the technical content, except for package outline drawings which were updated to the latest version. Contact information For additional information please visit: http://www.nxp.com For sales offices addresses send e-mail to: salesaddresses@nxp.com © NXP B.V. 2009 All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. The information presented in this document does not form part of any quotation or contract, is believed to be accurate and reliable and may be changed without notice. No liability will be accepted by the publisher for any consequence of its use. Publication thereof does not convey nor imply any license under patent- or other industrial or intellectual property rights. Printed in The Netherlands R76/03/pp8 Date of release: 2004 Jan 14 Document order number: 9397 750 12445
PLVA656A,215 价格&库存
很抱歉,暂时无法提供与“PLVA656A,215”相匹配的价格&库存,您可以联系我们找货
PLVA656A,215
    PLVA656A,215
    • 1+0.64240
    • 200+0.41470
    • 1500+0.36080
    • 3000+0.31900
    库存:1
